Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
33 registered members (aleneros, Aerojoe, BBDartCA, Bailes1992, ArrestMeRedZ, 7 invisible), 1,292 guests, and 28 spiders.
Topics300,415
Posts5,175,283
Members70,497
Engine Tick, Chevy LM7 5.3L 2007. Lifter? #4116931 06/06/16 01:45 PM
O
Oro_O Offline OP
O
We were working on my dad's 2007 Express van, tracing an A/C line leak. I noticed a distnct loud rapid ticking; it seemed to come from near the front of the valve cover on the left side. We were busy and I did not get a stethoscope out to localize it further. I made a video of it but I can't get it to link or embed correctly here.
Here is a youtube video that is identical to me and more distinct than my video since it's in an open engine bay on a Silverado and not the semi-covered van's bay:
https://www.youtube.com/watch?v=vyhl7N6WVbI
It does not sound like an exhaust leak to me but rather too mechanical. Safe to assume it is a lifter on likely cyl 1 or 3? The van has about 146k on it with strong maintenance history. It got conventional 5w-30 on schedule at Jiffy Lube 2007 to 2015, then it got Castrol Edge 5w-30 and is the current fill, 2,300mi on fill since last September. They are driving less frequently and short trips (both retired) so a synthetic switch seemed in order. I do not recall the sound at the last oil change last year this time and I have not been under the hood since then. I doubt I could have missed it last spring/summer. My dad is hard of hearing and cannot hear it.
Anyone know this issue on these engines and have a recommendation? I was thinking of going to a 10w-30 FS HM oil for a higher ZDDP and HTHS, these do not seem to be strengths of the Castrol now that I look at the numbers.
Re: Engine Tick, Chevy LM7 5.3L 2007. Lifter? [Re: Oro_O] #4116954 06/06/16 02:11 PM
4
440Magnum Offline
4
Exhaust leak: the clicking will get louder on rev-up, quieter on coast-down, louder under load, quieter under coasting.
Lifter: clicking volume doesn't change with load.
Being that its a Chevy engine with nut-and-stud mounted rockers, my money is on a loose rocker (or dozen) that needs to be brought back in spec. Don't try to fix a mechanical adjustment with an oil change.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Engine Tick, Chevy LM7 5.3L 2007. Lifter? [Re: 440Magnum] #4116984 06/06/16 02:36 PM
O
Oro_O Offline OP
O
I'm not familiar with these engines. You need to adjust the rockers periodically? In a 2007?
Last vehicle I had that needed that was a 1976 Honda 750K SOHC (granted, I sold it just a few years ago).
I don't believe in ignoring mechanical issues, but am not experienced with this engine.
Re: Engine Tick, Chevy LM7 5.3L 2007. Lifter? [Re: Oro_O] #4117019 06/06/16 03:05 PM
ls1mike Online Content
Online Content
No.
An exhaust leak is common. How many miles?
Re: Engine Tick, Chevy LM7 5.3L 2007. Lifter? [Re: Oro_O] #4117040 06/06/16 03:21 PM
4
440Magnum Offline
4
Woops, that's an corporate LSx, isn't it? I saw "Vortec" on the engine cover and my mind went to "Smallblock Chevy."
Even the SBC isn't *supposed* to need periodic adjustment, but if the factory didn't set the preload right normal wear can sometimes make a tick develop, which can be adjusted out.
But my bet is an exhaust leak anyway... but you can tell that by the "load / no-load" difference in sound test.
Re: Engine Tick, Chevy LM7 5.3L 2007. Lifter? [Re: 440Magnum] #4117236 06/06/16 07:00 PM
dailydriver Offline
If it is NOT an exhaust leak, then it is wise to check the rocker arm pre-load and torque (22 lb.ft.) settings, and trueness of the pushrods (roll them on a perfectly flat surface to check) FIRST since they are easy to get to under the valve covers, and IF it is actually the lifters (most likely, sadly), the heads MUST come off to change them out on the Gen 3 & 4/LSxes. frown
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Engine Tick, Chevy LM7 5.3L 2007. Lifter? [Re: Oro_O] #4117353 06/06/16 09:33 PM
cdm1993 Offline
For what it's worth we had a Suburban 2005 1500 with the 5.3 with a bad lifter tick. If it is a lifter tick in your situation you could go ahead and try Marvel Mystery Oil. That is what I did with that Suburban and the tick went away within an hour of driving. That was last year, and still no tick.
I also have a 1997 5.7 Vortec K 1500 that had a very bad lifter / rod (one of the two, could not distinguish which) ticking sound that was solved by putting in one quart of Marvel Mystery Oil and 4 quarts of normal PCMO oil. The tick also went away very quickly in this situation. This was several months ago, and the engine is still quiet.
I have always and still am skeptical of oil additives but MMO has worked well for me and you could give it a shot and it may work well for you.
Re: Engine Tick, Chevy LM7 5.3L 2007. Lifter? [Re: cdm1993] #4117577 06/07/16 08:29 AM
4
440Magnum Offline
4
I can distinguish which it was from halfway across the country: It had to be a lifter BECAUSE it went away. Rod knocks don't go away until the rod exits the side of the block or seizes the engine.
Lifter check valves can get sticky causing a normally adjusted (or preloaded in the case of shaft-mounted rockers or non-adjustable torque-down studs like an LSx) valvetrains to tick. That's one case where a light solvent can sometimes clear the noise (or even an "Italian tune-up). But I don't hear that very often in modern engines with modern oils (or even old engines with modern oils).
Re: Engine Tick, Chevy LM7 5.3L 2007. Lifter? [Re: 440Magnum] #4117791 06/07/16 01:41 PM
O
Oro_O Offline OP
O
+1. wink
Thank you all for the information. I asked him to get a helper and see if varies at speed/load.
If it appears to be a lifter, I'll try MMO for a period. I have used it successfully on some of my vehicles and on some OPE. In fact there is an unopened quart of it in his garage, I bought it for him earlier this spring and told him to experiment with it in gas and to clean carbs in the OPE and motorcycles. I will update when we ID it and see what transpires.
Re: Engine Tick, Chevy LM7 5.3L 2007. Lifter? [Re: 440Magnum] #4117882 06/07/16 04:22 PM
cdm1993 Offline
I now understand. Thank you for clearing that up.
