2012 Elantra battery running at 11.7 volts
by schuylkill - 01/26/20 03:31 PM
Chevron Supreme no longer at Costco
by OilUzer - 01/26/20 03:18 PM
Next 504/507 oil change
by sloinker - 01/26/20 03:02 PM
Salsa, do you buy it or make your own?
by 53' Stude - 01/26/20 02:29 PM
Cracklins/pork skins anyone?
by 53' Stude - 01/26/20 01:55 PM
RIP Kobe Bryant
by sloinker - 01/26/20 01:54 PM
Re-purposing an old iPad
by KrisZ - 01/26/20 01:10 PM
Put my dog down
by dja4260 - 01/26/20 01:09 PM
Oil choices for 240Z race car
by michaelsvintage - 01/26/20 12:54 PM
About Ballistol
by MGF1964 - 01/26/20 12:44 PM
Pop Quiz!
by Mad_Hatter - 01/26/20 12:41 PM
Tire Pressure Gauge
by Smoky14 - 01/26/20 12:06 PM
Castrol Gold Jug
by JohnnyJohnson - 01/26/20 11:22 AM
Honda/Multi-Vehicle ATF Comparison Chart
by jayjr1105 - 01/26/20 11:06 AM
4runner oil level.
by laserred96gt - 01/26/20 10:17 AM
Redline SL1 and Diesel Engines
by BigJohn - 01/26/20 09:53 AM
2011 Silverado red or orange dex cool?
by Corollaman - 01/26/20 08:39 AM
The Worst Muscle Cars Made. The Pinto was a M.C.?
by atikovi - 01/26/20 07:57 AM
duppyman, MBDon, Socioil, kwashabcp, ronster
70530 Registered Users
112 registered members (antone, 69Torino, 2009Caraman, Ag76, alchargo, ArrestMeRedZ, 14 invisible), 2,453 guests, and 22 spiders.
Topics300,595
Posts5,178,944
Members70,530
How much does it take to fully mix #4116553 06/06/16 08:09 AM
SpeedyG75VW Offline OP
Just wondering what everyone's opinion is on how much it takes quantity wise to fully mix in an additive. Most instructions for additives say to add to an empty tank before filling up with gas. I would think even with a tank nearly full, the additives would mix well after pumping in a couple gallons of gas....just because of the flow rates and pressure at which the gas is coming out of the nozzle.
Re: How much does it take to fully mix [Re: SpeedyG75VW] #4116572 06/06/16 08:24 AM
E
Ethan1 Offline
E
The gas sloshes around as you drive anyway
Re: How much does it take to fully mix [Re: SpeedyG75VW] #4116590 06/06/16 08:36 AM
B
BrocLuno Offline
B
It's the slosh that will do the mixing. The flow from the nozzle has little to do with it. But it does wash all the additive down the fill pipe smile
Re: How much does it take to fully mix [Re: SpeedyG75VW] #4116601 06/06/16 08:42 AM
4
4wheeldog Offline
4
EFI vehicle recycle substantially more fuel than they burn. A few miles of that agitation in the tank will mix anything up.
This also accounts for why FI vehicles are able to deal with striating ethanol fuels so well.
Re: How much does it take to fully mix [Re: 4wheeldog] #4116614 06/06/16 08:51 AM
4
440Magnum Offline
4
EFI USED to do that in the 90s (and a few carb'd vehicles did that in the '60s, such as 440- and Hemi-powered Chrysler muscle cars).
But return-flow EFI pretty much went away with tightening emissions rules in the mid 90s. The reason for fuel return was to always keep the fuel in the rails (or carb on the older engines) cool, reducing vapor lock. The problem is that the fuel carries heat back to the tank as you drive. The constant circulation heats the fuel in the tank, increasing the evaporation rate, which increases pressure in the tank until the cap vents vapors. Returnless EFI keeps the tank cooler and reduces vapor venting.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: How much does it take to fully mix [Re: SpeedyG75VW] #4116675 06/06/16 09:37 AM
H
HerrStig Offline
H
The regulator in the new single pipe systems in built into the pump and bleeds off some fuel. That flow should help mixing. Some systems have a feedback loop from the ECU to the fuel pump motor to vary speed based on demand.
Re: How much does it take to fully mix [Re: SpeedyG75VW] #4116680 06/06/16 09:40 AM
Char Baby Offline
We should alway add the additive(FSC) prior to filling the tank as many gas tanks have a check valve after the filler neck(in the tank).
And just adding the additive/FSC isn't enough to push open the check valve(causing it to sit in the filler neck) but, the force of filling the tank is certainly enough to push it through! Then, normal driving will mix the two together.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: How much does it take to fully mix [Re: SpeedyG75VW] #4116804 06/06/16 11:38 AM
R
raytseng Offline
R
What confuses me also is is the compulsive need to get your tank to empty before doing an additive.
Don't you think 10gallons of fuel or 5gallons or even 2gallons of fuel is enough to wash the additive down.
2gallons is 2 full milk jugs if you visualize it. If you get your hands soap, you don't need 2 gallons of water to wash the soap off your hands.
So if you really want to do your additive now but you're at 3/4 tank, just go to the station and top off your tank.
And if you don't end up getting all the additive in, or it doesn't mix perfectly, well it'll get washed down the next fillup. You're not running only 1 treated tank completely empty anyway. It's a continuous system.
Re: How much does it take to fully mix [Re: SpeedyG75VW] #4116823 06/06/16 12:03 PM
J
Jetronic Offline
J
if you're considering this additive, you might have used another already.
not much chance of additives clashing if you used up the previous fill first.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: How much does it take to fully mix [Re: raytseng] #4117450 06/07/16 05:05 AM
Char Baby Offline
Right, I agree with raytseng!
No need to be as close to empty before dumping in the additive. As long as(IMO) you are filling the tank after putting in the additive, which may just sit in the filler neck("if" the tank has a check valve). Meaning, pushing the additive through the filler neck with the force of the gas pump. Just my opinion!
"Retired"
