Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
106 registered members (87sammy, 2165, 830Lee, 2010Civic, 2K2AcuraTL, 11 invisible), 2,304 guests, and 26 spiders.
Topics306,040
Posts5,286,224
Members71,593
Beltorama #4116189 06/05/16 07:34 PM
G
Gokhan Online Content OP
OP Online Content
G
I've replaced the drive belts on my Corolla. I went with Bando EPDM, except for the conventional (nonribbed, noncogged) A/C belt, for which there is no correct aftermarket part. So, that one got Toyota OEM made by Mitsuboshi, luckily very cheap. Bando is also an OEM for Toyota. All belts seem to be of high quality.
The hardest part of the job was putting the wrench on some of the bolts where there is little space from the wall. I needed some extension on the wrench as well. Sockets wouldn't go in there.
I used the following exact formula for the belt tension, assuming my right index finger applies 10 lb of perpendicular pressure:
(Deflection of belt) = (0.25)*(span length of belt between the two pulleys where the force is applied)*(perpendicular force applied on belt midway between the two pulleys)/(belt tension)
I've also replaced the A/C idler pulley with a Dayco one. The Dayco has a made-in-Taiwan standard tightly sealed NTN bearing. The Toyota OEM 88440-12160-83 has a Nippondenso custom bearing. OEM is a heavier pulley, of same or very similar geometry, with a loosely sealed bearing. To my dismay, it was unavailable in USA at the time I needed it. The Dayco pulley seemed to fit well but it has more seal friction because it's the tight-seal type. I'm not sure if the OEM pulley had gone bad but I was occasionally hearing some pulley noise coming from somewhere. The coating on the OEM pulley was also gone.
Toyota/Nippondenso OEM 88440-12160-83 A/C idler pulley. Note that one of the edges is thinner than the other -- same with Dayco. The Nippondenso (ND) date code on the pulley bearing dust cover is May (E = 5) 1983.
Dayco 89039 pulley:
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Beltorama [Re: Gokhan] #4116265 06/05/16 09:08 PM
B
Bottom_Feeder Offline
B
That Toyota belt looks like ancient stock.
Re: Beltorama [Re: Gokhan] #4116291 06/05/16 09:38 PM
N
nobb Offline
N
Is the bearing on the Dayco idler serviceable? Just press out and in? My 4Runner has the same stock idler with the unserviceable bearing but apparently some model years had ones with a circlip that allows the bearing to be removed.
Re: Beltorama [Re: nobb] #4116340 06/05/16 11:12 PM
G
OP Online Content
G
There is no point in trying to replace the bearing because the bearing costs more than the pulley assembly including the bearing.
Re: Beltorama [Re: Bottom_Feeder] #4116345 06/05/16 11:19 PM
G
OP Online Content
G
I doubt it because I believe Toyota has a storage-time limit on rubber parts. The date code seems to be 12 29 060 but I'm not sure if it means the 29th week of 2012.
Re: Beltorama [Re: Gokhan] #4116382 06/06/16 12:47 AM
Colt45ws Offline
The copyright on the packaging is 1986 which would concern me a fair bit.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Beltorama [Re: Colt45ws] #4116391 06/06/16 01:23 AM
G
OP Online Content
G
I am pretty sure that 12 29 060 means Year 2012, Week 29, Batch 060.
Note that this Toyota/Mitsuboshi belt is also made in USA. I didn't know Mitsuboshi had a US factory.
