Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
2015 Ram Engine Oil
by nemtulea - 01/19/20 12:02 PM
Fram TG7317 1000 miles
by KenshinHimura - 01/19/20 11:57 AM
2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Thetarmac, lbstyling, tanpw, JPz521l, KirklanC
70481 Registered Users
116 registered members (65convertible, 3Aone, 750IX, A310, 14 invisible), 3,167 guests, and 27 spiders.
Topics300,325
Posts5,173,325
Members70,481
Most Online3,825
Jan 19th, 2020
Beltorama #4116189 06/05/16 06:34 PM
G
Gokhan Offline OP
G
I've replaced the drive belts on my Corolla. I went with Bando EPDM, except for the conventional (nonribbed, noncogged) A/C belt, for which there is no correct aftermarket part. So, that one got Toyota OEM made by Mitsuboshi, luckily very cheap. Bando is also an OEM for Toyota. All belts seem to be of high quality.
The hardest part of the job was putting the wrench on some of the bolts where there is little space from the wall. I needed some extension on the wrench as well. Sockets wouldn't go in there.
I used the following exact formula for the belt tension, assuming my right index finger applies 10 lb of perpendicular pressure:
(Deflection of belt) = (0.25)*(span length of belt between the two pulleys where the force is applied)*(perpendicular force applied on belt midway between the two pulleys)/(belt tension)
I've also replaced the A/C idler pulley with a Dayco one. The Dayco has a made-in-Taiwan standard tightly sealed NTN bearing. The Toyota OEM 88440-12160-83 has a Nippondenso custom bearing. OEM is a heavier pulley, of same or very similar geometry, with a loosely sealed bearing. To my dismay, it was unavailable in USA at the time I needed it. The Dayco pulley seemed to fit well but it has more seal friction because it's the tight-seal type. I'm not sure if the OEM pulley had gone bad but I was occasionally hearing some pulley noise coming from somewhere. The coating on the OEM pulley was also gone.
Toyota/Nippondenso OEM 88440-12160-83 A/C idler pulley. Note that one of the edges is thinner than the other -- same with Dayco. The Nippondenso (ND) date code on the pulley bearing dust cover is May (E = 5) 1983.
Dayco 89039 pulley:
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 2,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Beltorama [Re: Gokhan] #4116265 06/05/16 08:08 PM
B
Bottom_Feeder Offline
B
That Toyota belt looks like ancient stock.
Re: Beltorama [Re: Gokhan] #4116291 06/05/16 08:38 PM
N
nobb Offline
N
Is the bearing on the Dayco idler serviceable? Just press out and in? My 4Runner has the same stock idler with the unserviceable bearing but apparently some model years had ones with a circlip that allows the bearing to be removed.
Re: Beltorama [Re: nobb] #4116340 06/05/16 10:12 PM
G
Gokhan Offline OP
G
There is no point in trying to replace the bearing because the bearing costs more than the pulley assembly including the bearing.
Re: Beltorama [Re: Bottom_Feeder] #4116345 06/05/16 10:19 PM
G
Gokhan Offline OP
G
I doubt it because I believe Toyota has a storage-time limit on rubber parts. The date code seems to be 12 29 060 but I'm not sure if it means the 29th week of 2012.
Re: Beltorama [Re: Gokhan] #4116382 06/05/16 11:47 PM
Colt45ws Offline
The copyright on the packaging is 1986 which would concern me a fair bit.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Beltorama [Re: Colt45ws] #4116391 06/06/16 12:23 AM
G
Gokhan Offline OP
G
I am pretty sure that 12 29 060 means Year 2012, Week 29, Batch 060.
Note that this Toyota/Mitsuboshi belt is also made in USA. I didn't know Mitsuboshi had a US factory.
