Shutting Down Threads Because of "Speculation"
by e55amgbenz007 - 02/18/20 10:10 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
111 registered members (53' Stude, aquariuscsm, 750IX, ARB1977, 2K2AcuraTL, allepunta, 6 invisible), 2,119 guests, and 27 spiders.
Topics301,605
Posts5,198,990
Members70,737
Higher Grade with Higher Miles #4116183 06/05/16 06:28 PM
G
Gene K Offline OP
G
Any evidence to support higher grade with higher miles?
Lots of guys down south with 400,000+ mile pickups that did the 5W30 PCMO to 150,000 / 10W30 HDEO to 300,000 / 15W40 HDEO at 300,000+ type deal. Any evidence this is actually beneficial?
Gene
2014 Mustang GT 5.0 SC - 675 bhp
ST Synthetic 10W30 / FL500S
2018 F150 4x4 3.5 EB
OEM Oil & Filter
2018 Lincoln MKX 3.7
OEM Oil & Filter
Re: Higher Grade with Higher Miles [Re: Gene K] #4116198 06/05/16 06:48 PM
E
Ethan1 Offline
E
I'm not sure how we would gather "evidence", per se, but there are plenty of anecdotes about "looser tolerances" on older trucks.
Re: Higher Grade with Higher Miles [Re: Gene K] #4116218 06/05/16 07:07 PM
T
tig1 Offline
T
No.
2007 Ford Fusion 253,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Higher Grade with Higher Miles [Re: Gene K] #4116220 06/05/16 07:12 PM
crazyoildude Offline
heavy oil is not always better.. going up one grade from say 5w20 to 5w30 may not be so bad on most engines.
Check To See That The Oil Jugs You Buy Have The Exact Amount Of Oil In Them And Have An Inner Seal Under The Cap. I Use Mobil 1 And Fram Ultra Filters
Re: Higher Grade with Higher Miles [Re: Gene K] #4116224 06/05/16 07:15 PM
demarpaint Offline
I'd move up a grade with higher miles if I started to use oil, otherwise I'd leave it alone.
God Bless Our Troops
Re: Higher Grade with Higher Miles [Re: Gene K] #4116233 06/05/16 07:23 PM
What engines?
Re: Higher Grade with Higher Miles [Re: Gene K] #4116316 06/05/16 09:22 PM
DoubleWasp Offline
OEM's have been moving up a grade on a lot of brand new engines recently.
Dont think it will harm an older one.
Re: Higher Grade with Higher Miles [Re: Gene K] #4116350 06/05/16 10:27 PM
B
BrocLuno Offline
B
That sort of run-up has always worked for me. But I don't have any cars or light trucks that have recently made it over 287,000 miles. Not because they were not running fine (they were), but at that point they would no longer pass Calif SMOG testing w/o a new cat and the vehicles were not worth it ...
The '62 Ford F-100 went 400K plus doing that sort of oil up-grade. But that was many years ago ...
Re: Higher Grade with Higher Miles [Re: Gene K] #4116351 06/05/16 10:27 PM
SuperDave456 Offline
Define "Higher Mileage"
100,000 miles is just broken in.
200,000 miles is starting to sound like "higher mileage"
300,000 mileage run what suits your fancy, you got your money and then some out of her.
Re: Higher Grade with Higher Miles [Re: Gene K] #4116352 06/05/16 10:30 PM
Z
zeng Offline
Z
Plain bearings with abrasion scratches over times,even if bearing clearances hasn't enlarged, would require higher operating viscosity at similar conditions of engine rpm and load than an original bearings.........
just to maintain similar MOFT, and by extension film strength. blush
It makes sense to up a grade or two for used bearings ..... and used interfaces at cylinder liners and cams.
Edit:spelling
Re: Higher Grade with Higher Miles [Re: Gene K] #4116357 06/05/16 10:45 PM
3
3800Series Offline
3
I had a old Volvo with 289k miles had bad compression but refused to die. Pretty much everything that could break on this car had by the time two of my son's had it as there first car.
It leaked and rattled decided one day to try 10w50 (or 15w50 been several years back) anyways the car became dead silent. You could stand by the hood and wouldn't know if it was running after the thicker oil was added.
But I also had a '01 Chevy 1500 with 360k miles and it ran perfectly fine till the day it blew the head gasket. Used 10w30 and 7,500 mile OCI it's whole life.
I guess it would really just depend on the vehicle.
Re: Higher Grade with Higher Miles [Re: zeng] #4116397 06/06/16 12:49 AM
U
UltrafanUK Offline
U
CORRECT!
One easy way to figure out if the engine is worn is to keep track of the oil consumption figures. In general terms I would only move up one grade from OEM spec, BUT I would find out what that spec was for use outside the USA, as the one quoted from a US site might be biased by fuel economy regulations.
It also helps with an old worn engine to use an oil with more anti wear additives and detergents, although I would only switch to an HM oil when the oil consumption increases.
It's also very important to select an OCI that matches the condition and use of the engine, as older engines tend to contaminate their oil more. The best way to figure out what the OCI should be for an older engine, is to get a used oil analysis (UOA) done.
