Next 504/507 oil change
by sloinker - 01/26/20 03:02 PM
Salsa, do you buy it or make your own?
by 53' Stude - 01/26/20 02:29 PM
Cracklins/pork skins anyone?
by 53' Stude - 01/26/20 01:55 PM
RIP Kobe Bryant
by sloinker - 01/26/20 01:54 PM
Re-purposing an old iPad
by KrisZ - 01/26/20 01:10 PM
Put my dog down
by dja4260 - 01/26/20 01:09 PM
Oil choices for 240Z race car
by michaelsvintage - 01/26/20 12:54 PM
About Ballistol
by MGF1964 - 01/26/20 12:44 PM
Pop Quiz!
by Mad_Hatter - 01/26/20 12:41 PM
Tire Pressure Gauge
by Smoky14 - 01/26/20 12:06 PM
Castrol Gold Jug
by JohnnyJohnson - 01/26/20 11:22 AM
Honda/Multi-Vehicle ATF Comparison Chart
by jayjr1105 - 01/26/20 11:06 AM
4runner oil level.
by laserred96gt - 01/26/20 10:17 AM
Redline SL1 and Diesel Engines
by BigJohn - 01/26/20 09:53 AM
2011 Silverado red or orange dex cool?
by Corollaman - 01/26/20 08:39 AM
The Worst Muscle Cars Made. The Pinto was a M.C.?
by atikovi - 01/26/20 07:57 AM
2012 Ford Escape Transfer Case
by radtech91 - 01/26/20 07:49 AM
P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
duppyman, MBDon, Socioil, kwashabcp, ronster
70530 Registered Users
96 registered members (1WildPig, 2K2AcuraTL, 4WD, 750IX, Alfred_B, 15 invisible), 2,654 guests, and 22 spiders.
Topics300,593
Posts5,178,929
Members70,530
how would you fix this leaking T joint? #4116153 06/05/16 06:05 PM
X
xfactor9 Offline OP
X
This pipe feeds water into my house. The PVC T-joint is leaking exactly where the black dot is (but on the underside). Cutting it out is a last resort because there's an L-fitting to the right which leaves no spare pipe. So I'd have to dig even more and replace both fittings. Plus this is a T joint which is very hard to replace.
There has to be a better way to fix this?
Re: how would you fix this leaking T joint? [Re: xfactor9] #4116162 06/05/16 06:14 PM
M
mk378 Offline
M
I would cut out the T and the L and replace. Do it once, do it right that sort of thing. It's only a couple dollars worth of parts.
The Tee probably cracked because the pipes are tweaked into position putting a lot of strain on it. Further cracking is likely if you try to patch it.
Re: how would you fix this leaking T joint? [Re: xfactor9] #4116174 06/05/16 06:21 PM
cptbarkey Offline
If you are daunted by the task just keep digging and have the plumber finish it off. You saved $$$ already for labor.
Re: how would you fix this leaking T joint? [Re: xfactor9] #4116215 06/05/16 07:03 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I cant see how digging the L out and redoing the whole thing where there is more pipe is a big deal. If its close enough that there is no extra pipe if you cut out, then the additional digging would be minimal...
Re: how would you fix this leaking T joint? [Re: xfactor9] #4116234 06/05/16 07:24 PM
spackard Offline
I've done this with sprinkler stuff before:
https://www.youtube.com/watch?v=JCMQ6OA84OA
Not sure I'd trust it with a joint under pressure 24/7.
Re: how would you fix this leaking T joint? [Re: xfactor9] #4116238 06/05/16 07:26 PM
N
Nukeman7 Offline
N
Just clean it up really well, scuff the area with emery cloth and apply plumber's quick setting epoxy putty.
Plumber's Epoxy Putty
Data Sheet
It will set up in 15 minutes and last a lifetime. I have used it to reseal PVC piping that cracked from freezing, so that hole will be a piece of cake!
Re: how would you fix this leaking T joint? [Re: JHZR2] #4116242 06/05/16 07:29 PM
X
xfactor9 Offline OP
X
The issue is that it's a T joint so 2 of the 3 pipes have to be flexed in order to insert the new joint. The run on the left is only 18 inches. The run on the right is probably very short, I'm guessing <12 inches straight into the ground. The run on the bottom might be 4-5 feet but it's buried so it probably won't flex much. That doesn't seem to allow for enough flex to get the new joint in
Re: how would you fix this leaking T joint? [Re: xfactor9] #4116319 06/05/16 09:23 PM
DoubleWasp Offline
Fiber Fix It.
Seriously.
