Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
23 registered members (Black_Thunder, bbhero, AndyB, adams355, Bailes1992, 2 invisible), 1,617 guests, and 29 spiders.
Topics300,415
Posts5,175,292
Members70,497
Did I damage my trans by using the wrong fluid? #4116030 06/05/16 04:00 PM
H
Headnsouth Offline OP
H
Recently changed the trans filter and replaced what trans fluid that was in the pan from my 05 G35 sedan 116k miles. About 4 qts. It turns out I used the wrong trans fluid.
I used castrol transmax CTV instead of castrol transmax for imports. I dumped the pan and refilled letting the fluid warm up and I checked and rechecked for a while. Everything seems ok. The car shifts fine but I'm wondering if I should I flush out more of the CVT? I know the manual states use only J matic fluid but read that transmax was a fine alternative.
16 Infinity Q50 RS 28K
03 GMC Sierra100K
05 Infinity G35 150K
Re: Did I damage my trans by using the wrong fluid? [Re: Headnsouth] #4116037 06/05/16 04:06 PM
E
Ethan1 Offline
E
I would get that CVT fluid the heck out ASAP
Re: Did I damage my trans by using the wrong fluid? [Re: Ethan1] #4116069 06/05/16 04:27 PM
MolaKule Offline
Global Moderator
Global Moderator
For sure.
The additive packages are vastly different.
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Did I damage my trans by using the wrong fluid? [Re: Headnsouth] #4116074 06/05/16 04:33 PM
H
H
Sounds like the best thing I can do is the poor man's flush?
03 GMC Sierra100K
Re: Did I damage my trans by using the wrong fluid? [Re: Headnsouth] #4116136 06/05/16 05:47 PM
T
Trav Offline
T
Do a line off fluid exchange on this car ASAP.
Re: Did I damage my trans by using the wrong fluid? [Re: Headnsouth] #4116208 06/05/16 06:57 PM
O
Oro_O Offline
O
Not sure what you mean by that, but get the correct fluid and drain/fill the pan, then swap out via the cooler lines. See this thread about doing it on a G35 - newer a little than yours but I think about identical:
http://g35driver.com/forums/v36-general-...e-make-diy.html
Since you really want it out, I'd do a pan fill, and swap the total system volume (~12 qts). So I'd get 4 gallons. Then I'd do the PS system too. Those get overlooked.
Re: Did I damage my trans by using the wrong fluid? [Re: Headnsouth] #4116417 06/06/16 03:07 AM
H
H
Thanks for all of the reply's confirming its best to swap out all of the fluid. I haven't been driving the car since I F'd up the fluid change.
Code:
http://www.thenewx.org/forum/11-powertrain-driveline/22319-transmission-fluid-flush-poor-mans-how.html
03 GMC Sierra100K
Re: Did I damage my trans by using the wrong fluid? [Re: Headnsouth] #4116545 06/06/16 08:00 AM
B
Bgallagher Offline
B
Code:
Good thinking. As mentioned already, I would get that fluid out as soon as you can. They are very different and could cause damage. Castrol Transmax (import) would work well as well as Valvoline maxlife. Either or.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
