2018 Ram 2500 with 21k miles. Delo 400 XSP 5w40
by bigbadbowtie - 02/27/20 11:08 AM
For those always asking about tiny Computers
by jayjr1105 - 02/27/20 11:05 AM
Original 2016 VW Passat cabin filter
by Vaca - 02/27/20 11:02 AM
Original 2016 VW Passat air filter
by Vaca - 02/27/20 10:54 AM
Napa Exceptional Customer Service
by Fitz98 - 02/27/20 10:38 AM
Astra 400 ?
by WyrTwister - 02/27/20 09:58 AM
Will thinner oil damage anything when it is burned?
by Fordiesel69 - 02/27/20 09:38 AM
Old news for Hyundai/Kia?
by Farnsworth - 02/27/20 09:33 AM
Looking for AA 25% off coupon code.
by JustChuck - 02/27/20 09:17 AM
New to the LS460 and The World Of Lexus. Questions!
by gr8gatzby - 02/27/20 08:41 AM
New old guy back.
by BJD2020 - 02/27/20 07:45 AM
Help me Decide
by Gebo - 02/27/20 07:36 AM
FWD - Death traps with miss matched tires.
by Fordiesel69 - 02/27/20 07:13 AM
Napa Gold Sale
by Toto - 02/27/20 06:52 AM
2016 or 17 Honda CR-V
by Loogie - 02/27/20 05:20 AM
RIP Clive Cussler
by PimTac - 02/27/20 04:48 AM
Pirelli Cinturato P7 Allseason PLUS "II"
by Char Baby - 02/27/20 03:31 AM
CCI clean .22 ammo - polymer coated HV
by Shannow - 02/27/20 03:23 AM
5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
95 registered members (AZjeff, Alfred_B, 1978elcamino, 2dogs, atikovi, 2010Civic, 4 invisible), 2,108 guests, and 18 spiders.
Topics301,989
Posts5,206,915
Members70,808
Coolant loss, no external leak or coolant in oil #4115742 06/05/16 10:41 AM
A
AnarchyX Offline OP
A
I've got an '04 Impala with 73k miles and my reservoir is showing coolant loss. I took it to Firestone and they did a pressure check and they found no leaks. There's no coolant in the oil either, and the car drives great. No check engine light either.
I had my headgasket blow in my GMC envoy and it chugged and surged when driving. This is nothing at all like that. It's frustrating, especially since it drives just fine and nothing was found.
I read that it might be an intake manifold leak, but if it is, why is there no coolant in the oil and why is it driving fine?
Any help or ideas would be appreciated.
Re: Coolant loss, no external leak or coolant in oil [Re: AnarchyX] #4115745 06/05/16 10:45 AM
T
TmanP Offline
T
I know, this can be frustrating. I would give a second look at the intake manifold gasket. It could be a smaller leak-- how much coolant are you losing??
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: Coolant loss, no external leak or coolant in oil [Re: AnarchyX] #4115747 06/05/16 10:45 AM
SatinSilver Offline
A UOA would confirm if any coolant is in the oil. How fast is it disappearing? Some loss over the course of a year can be normal. If it's going from the full mark to the low mark on the overflow tank over 3 months then there's an issue. Which could be a leaking water pump if it's disappearing quickly.
Re: Coolant loss, no external leak or coolant in oil [Re: AnarchyX] #4115751 06/05/16 10:49 AM
O
Ojustracing Offline
O
Common on these are intake manifold gaskets and if its a 3.8 I have replace a bunch of upper intake plenums for coolant loss around the EGR tube. Which motor 3.4 or 3.8?
Fleet Mechanic, ASE Master Automobile Technician, ASE Master Medium/Heavy Truck L-1/L-2 Advanced Level Specialist. IFPS Mobile Hydraulic Mechanic
Re: Coolant loss, no external leak or coolant in oil [Re: TmanP] #4115752 06/05/16 10:50 AM
A
AnarchyX Offline OP
A
It depends. I drove 1300 miles - all highway - and didn't lose a drop. In this past week I've lost about 6 ounces, or almost 2 inches in the resrvoir.
Re: Coolant loss, no external leak or coolant in oil [Re: Ojustracing] #4115755 06/05/16 10:52 AM
A
AnarchyX Offline OP
A
3.8
And actually it did throw an EGR code over a month ago but that was also when I was having a problem with my gas cap. When I replaced the gas cap there were no more codes.
Re: Coolant loss, no external leak or coolant in oil [Re: AnarchyX] #4115762 06/05/16 11:03 AM
007 Offline
Do you puff any white smoke at a cold start?
Re: Coolant loss, no external leak or coolant in oil [Re: AnarchyX] #4115764 06/05/16 11:05 AM
O
Ojustracing Offline
O
If nothing external I would suspect the intake gasket. Pay very close attention to the upper manifold where to EGR tube goes in. The plastic erodes and there is coolant right behind it.
Re: Coolant loss, no external leak or coolant in oil [Re: 007] #4115765 06/05/16 11:05 AM
A
AnarchyX Offline OP
A
Nope, and it just passed the vehicle inspection 4 weeks ago.
Re: Coolant loss, no external leak or coolant in oil [Re: Ojustracing] #4115767 06/05/16 11:06 AM
A
AnarchyX Offline OP
A
So is it possible I'm losing coolant through the EGR valve? And is that why it's not getting into the oil?
Re: Coolant loss, no external leak or coolant in oil [Re: AnarchyX] #4115774 06/05/16 11:16 AM
O
Ojustracing Offline
O
Its not going through EGR valve itself. It leaks on the outlet end of the tube into the manifold(air stream). They start small. When they get really bad will hydro-lock the motor and you will know something is wrong. GM thought it would be a good idea to put a metal pipe that fills with hot exhaust gas tight against a piece of plastic. If not external leak. I still say intake gasket. Very common!!!!!
Re: Coolant loss, no external leak or coolant in oil [Re: AnarchyX] #4115781 06/05/16 11:26 AM
K
Kuato Offline
K
Might want to have a look inside the tailpipe. If it is wet, or smells like coolant when running it is a head gasket leak into the exhaust.
Thick vs Thin test: 15k / 43k miles complete
Re: Coolant loss, no external leak or coolant in oil [Re: Ojustracing] #4115788 06/05/16 11:31 AM
A
AnarchyX Offline OP
A
So do you think the dealer would be able to find what firestone didn't? Would they be able to do more than a pressure test?
Sorry for all the questions, this is just new to me.
Also, about how much would it cost to have this fixed?
Re: Coolant loss, no external leak or coolant in oil [Re: AnarchyX] #4115802 06/05/16 11:53 AM
W
Wheel Offline
W
I'm thinking it could be intake manifold (but that would probably show on a pressure test) or the start of a HG leaking into the combustion chamber. Did they do a leakdown test, or just pressure test the cooling system ? How do the plugs look ?
2009 Subaru Legacy (N/A)
Quaker State Ultimate Durability and NAPA filter
Re: Coolant loss, no external leak or coolant in oil [Re: Wheel] #4115824 06/05/16 12:29 PM
A
AnarchyX Offline OP
A
They just said they did a pressure test.
