Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
134 registered members (53' Stude, 87sammy, 2010Civic, AC1DD, AandPDan, 12 invisible), 2,398 guests, and 25 spiders.
Topics300,410
Posts5,175,174
Members70,497
Brand Recommendation - AC Condenser #4115731 06/05/16 10:23 AM
E
exranger06 Offline OP
E
I need an AC condenser for my mom's 1994 Ford Explorer. OEM Motorcraft part is discontinued, so my only choice is aftermarket. I replaced it once before 6 years ago with a Napa one, and that one is now leaking. I suppose another Napa one will last another 6 years, and my mom probably will be driving something else by then, but I would like something good quality. (I've had cheap condensers fail in less than a year, so I would like to avoid that again) Rockauto has a TYC brand for $65, an "APDI/PRO" for $60, and a "various manufacturer" for $70. Would you recommend any of those, or know of any better ones?
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Brand Recommendation - AC Condenser [Re: exranger06] #4115733 06/05/16 10:27 AM
SatinSilver Offline
How much is the Napa one? That would be my first inclination. Not sure about those other brands you mentioned on Rock. Those could be one year deals.
Re: Brand Recommendation - AC Condenser [Re: exranger06] #4115811 06/05/16 12:09 PM
E
E
I can get another Napa one for about $85 with my employee discount. But it's special order and I'd probably have to pay another $15 or so for shipping.
Re: Brand Recommendation - AC Condenser [Re: exranger06] #4115923 06/05/16 02:48 PM
I
i_hate_autofraud Offline
I
What I watch for in a replacement A/C condensers, etc, is if steel parts are used next to aluminum fins and tubes. That'll cause a corrosion leak in 1 -2 yrs.
When I figured that out, I got the vary same replacement condenser and was able to take the steel frame off the core, paint the exposed tubes and inside the frame, then I got some .005" mylar plastic and lined the frame during re-assembly. Now the aluminum and steel have no contact and it's been leak free for the last 5 yrs! Note: some OEM condensers pull the same stunt but cover the evidence with paint! Check with a magnet!
Re: Brand Recommendation - AC Condenser [Re: exranger06] #4116059 06/05/16 04:22 PM
G
Gokhan Offline
G
Why don't you let the A/C shop handle this? I expect that there are quite a few other problems in the system as well and you don't have a vacuum pump to evacuate the system. Chances are that you need to replace the drier, possibly the expansion valve, weld the leaking pipes, check the compressor and oil, etc.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 2,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Brand Recommendation - AC Condenser [Re: Gokhan] #4116099 06/05/16 04:55 PM
E
E
How do you know I don't have a vacuum pump? As a matter of fact, I DO have a vacuum pump, as well as several hundred dollars worth of AC tools. I have the stuff to do basically any AC repair, except recover refrigerant. And all the refrigerant already leaked out of this truck, so that's not an issue.
This truck already had the entire AC system rebuilt 6 years ago (which I did myself), and I know it doesn't need anything else besides the leaking condenser.
Re: Brand Recommendation - AC Condenser [Re: exranger06] #4116109 06/05/16 05:05 PM
G
Gokhan Offline
G
It sounds good.
I would go by visual as far as the brand is concerned.
Re: Brand Recommendation - AC Condenser [Re: exranger06] #4116121 06/05/16 05:16 PM
G
Gokhan Offline
G
You probably need to replace the drier as well, as they go bad when the system is empty.
Re: Brand Recommendation - AC Condenser [Re: exranger06] #4116651 06/06/16 09:17 AM
Z
zzyzzx Offline
Z
I would think that anything except the "various manufacturers" (Rock Auto code name for total junk) should be OK.
