Like 360kid its API SL which is an old spec. Mobil 1 probably doesn't want to reduce the ZDDP levels it would have to to meet the current specs. Tech
Originally Posted By: 360kid
I bought some Mobile 1 High Mileage oil and just happened to notice that the specs it meets is pretty slim compared to regular Mobil 1. Owners manual states it requires GM6094m, 2007 Chevy Impala 3.5L Flex Fuel. Is this standard a big deal or is the Mobil 1 High Mileage okay anyway?
Like 360kid its API SL which is an old spec and therefore it won't pass the latest manufacturers specs. either. However, the M1HM 10w40 does meet API SN because that viscosity grade is not required to have reduced ZDDP levels. Mobil 1 probably doesn't want to reduce the ZDDP levels it would have to to meet the current specs. The reduced ZDDP levels were done to protect the emissions system, particularly the catalytic convertor. Technically speaking, you shouldn't use that oil in your car, because your car should be using API SM or newer oils. But as you will see, other people will think it ok and you probably are as long your are not burning oil through the exhaust system.
