Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
25 registered members (Aerojoe, Bailes1992, ArrestMeRedZ, 14Accent, Ag76, 3 invisible), 1,277 guests, and 29 spiders.
Topics300,415
Posts5,175,280
Members70,497
Is GM6094m that important? #4115642 06/05/16 08:33 AM
3
360kid Offline OP
3
I bought some Mobile 1 High Mileage oil and just happened to notice that the specs it meets is pretty slim compared to regular Mobil 1. Owners manual states it requires GM6094m, 2007 Chevy Impala 3.5L Flex Fuel. Is this standard a big deal or is the Mobil 1 High Mileage okay anyway?
Re: Is GM6094m that important? [Re: 360kid] #4115656 06/05/16 08:47 AM
2
2KBMW Offline
2
It will be OK.That GM 6094m spec is the old GM oil spec before Dexos 1. Is it the 5W30 grade? If not, that is why you may not see it.
Re: Is GM6094m that important? [Re: 360kid] #4115670 06/05/16 09:00 AM
3
360kid Offline OP
3
Mobile 1 HM 5w30, meets API SL, which is pretty old standard. I assume it fails to meet the standards due to the HM additives?
I have been using Valvoline Maxlife HM Syn Blend for the last bunch of years and the leaking/consumption of 1 qt per 3000 miles has slowed significantly to maybe a 1/4 qt. I don't even top off anymore between changes. So, the HM stuff works. I just grabbed the Mobil 1 HM because it was cheaper. MaxLife Syn blend used to be $17, now it's $27. Mobil 1 HM was only $22. It just doesn't meet the specs.
Re: Is GM6094m that important? [Re: 360kid] #4115701 06/05/16 09:37 AM
N
NH73 Offline
N
Like 360kid its API SL which is an old spec. Mobil 1 probably doesn't want to reduce the ZDDP levels it would have to to meet the current specs. Tech
Like 360kid its API SL which is an old spec and therefore it won't pass the latest manufacturers specs. either. However, the M1HM 10w40 does meet API SN because that viscosity grade is not required to have reduced ZDDP levels. Mobil 1 probably doesn't want to reduce the ZDDP levels it would have to to meet the current specs. The reduced ZDDP levels were done to protect the emissions system, particularly the catalytic convertor. Technically speaking, you shouldn't use that oil in your car, because your car should be using API SM or newer oils. But as you will see, other people will think it ok and you probably are as long your are not burning oil through the exhaust system.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: Is GM6094m that important? [Re: 360kid] #4115748 06/05/16 10:47 AM
3
360kid Offline OP
3
Anyone have any experience with Penzoil Platinum High Mileage Oil? I assume it's just their regular Platinum oil with seal conditioners in it. Must be kind of new as I can't find much on it.
Re: Is GM6094m that important? [Re: 2KBMW] #4115779 06/05/16 11:22 AM
T
Tech819 Offline
T
This is right
2017 Impreza Sport Hatch M1 0w20 OEM filter
2003 Corolla Magnatec 5w30 OEM Filter
2018 VW Golf Motul 5w40 OEM filter
Re: Is GM6094m that important? [Re: 360kid] #4116011 06/05/16 03:45 PM
G
Gene K Offline
G
M1 HM has to much of the good stuff...
By the VML if you want less.
Gene
2014 Mustang GT 5.0 SC - 675 bhp
ST Synthetic 10W30 / FL500S
2018 F150 4x4 3.5 EB
OEM Oil & Filter
2018 Lincoln MKX 3.7
OEM Oil & Filter
