Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
21 registered members (hpb, Langanobob, BlakeB, blufeb95, FordCapriDriver, 2 invisible), 586 guests, and 17 spiders.
Topics300,304
Posts5,172,820
Members70,467
Most Online3,728
Jan 11th, 2020
How to tell if you have keyless entry if no fobs #4115598 06/05/16 07:07 AM
callbay Offline OP
2002 Buick Regal. New to me but no key fobs.
It does have electric door locks.
I want to get new fobs but I don't know how to tell if they will work or not.
Thanks!
Re: How ttell if you have keyless entry if no fobs [Re: callbay] #4115600 06/05/16 07:08 AM
E
eljefino Offline
E
RPO codes on the sticker in glovebox or on spare tire.
Should be code AU0 (zero)
Re: How ttell if you have keyless entry if no fobs [Re: callbay] #4115627 06/05/16 08:12 AM
R
RF Overlord Offline
R
Most vehicles with factory-installed keyless entry will have a keypad on the driver's door.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - MC 5W-20 / FL820S
'00 Grand Marquis GS - being resurrected. Slowly.
Re: How to tell if you have keyless entry if no fobs [Re: callbay] #4115632 06/05/16 08:17 AM
T
TmanP Offline
T
I'm 99% sure that the Regal came standard with remote keyless entry. All you have to do:
-buy a remote
1) Sit in the drivers seat
2) Remove key from ignition cylinder
3) Close all the doors
4) Press and hold the UNLOCK on the door lock switch
5) While holding the door lock switch in the UNLOCK position, insert
and remove the ignition key twice. DO NOT ROTATE THE IGNITION CYLINDER.
6) Insert the ignition key a third time, leaving the key in the
ignition cylinder. The ignition MUST remain in the LOCK position for
the rest of the procedure.
7) Release the door lock switch. You will hear 3 chimes. This chime
feedback indicates the transmitter programming is active.
8) Press and hold the LOCK and UNLOCK buttons on the remote for 12
seconds. You will hear two chimes. This chime feedback indicates the
transmitter has been accepted.
9) Repeat step 8 for each additional transmitter
10) Remove ignition key from cylinder to exit programming.
11) Verify functions of remotes.
Here's a link to a remote. $29. http://www.carandtruckremotes.com/r012.html
Your RPO sheet should be on the left side underneath the spare tire cover.
Good luck!
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: How to tell if you have keyless entry if no fobs [Re: callbay] #4115636 06/05/16 08:25 AM
W
Warstud Offline
W
Just go here and type in your VIN
http://www.keylessride.com/
Re: How ttell if you have keyless entry if no fobs [Re: RF Overlord] #4115722 06/05/16 10:07 AM
T
TmanP Offline
T
Unfortunately this isn't true for GM cars or trucks. For Fords it would be, but OP's Buick wouldn't.
Re: How ttell if you have keyless entry if no fobs [Re: TmanP] #4115773 06/05/16 11:14 AM
I
itguy08 Offline
I
Not even for Fords. Wife's 03 Escape had keyless entry fobs but no keypad on the door. Even today I think some Fords (Super Duty, some F150's, Mustang, Focus, Fiesta, maybe Fusion) don't have pads either.
The OP could also try and see if his car is still in one of those online window sticker generators. You could try looking here: www.researchmaniacs.com . Or a quick call to the dealer's parts counter with the VIN would help. Just tell them you need a clicker for the car. Give them the VIN and it should tell if it has it or not.
Re: How to tell if you have keyless entry if no fobs [Re: Warstud] #4115776 06/05/16 11:20 AM
DBMaster Offline
There really IS a web site for everything, isn't there?
Re: How to tell if you have keyless entry if no fobs [Re: callbay] #4115777 06/05/16 11:22 AM
DBMaster Offline
I bought a 1999 Isuzu Oasis (19998 Honda Odyssey badged for Isuzu) in 2001 from Car Max. I thought it had keyless entry, but was missing the fobs. I called Isuzu with the VIN and they were easily able to confirm that is actually did NOT have keyless entry.
Re: How ttell if you have keyless entry if no fobs [Re: RF Overlord] #4115894 06/05/16 02:05 PM
bdcardinal Offline
The number keypads are exclusive to Ford. They can be added as an accessory to vehicles that were not factory equipped. I have the add-on on my Mustang and put it on the cowl panel.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: How to tell if you have keyless entry if no fobs [Re: callbay] #4116637 06/06/16 09:04 AM
callbay Offline OP
Thanks, guys. BITOG is awesome!
