Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
32 registered members (bbhero, aleneros, Aerojoe, BBDartCA, Bailes1992, 7 invisible), 1,283 guests, and 28 spiders.
Topics300,415
Posts5,175,283
Members70,497
Carpet cleaners #4115176 06/04/16 03:48 PM
grampi Offline OP
I'm looking for a portable spot cleaner that is 1) built better than the retail units sold at places like Wal-Mart, Lowe's, and Home Depot, and 2) small and light weight.
I've run the gamut of units like Bissell's Green Machine, and probably most of the other brands that have models that are basically the same thing. All work okay when new, but they usually don't even last a year before something goes wrong with them. Fed up with having to buy a new one every year, I decided to go with more of a commercial type unit, the Mytee S-300 Tempo Spotter. It's an awesome unit, puts down a lot of solution, great suction, built like a tank, and I doubt anything would ever go wrong with it. However, the main unit is very heavy and cumbersome to carry around, and the large diameter hose is difficult to handle for me, almost impossible for my wife to use.
Is there one made that fits somewhere in the middle? I need something that's built well enough to last, and is light enough and easy enough for my wife to handle. I realize such a unit is going to be expensive, but I don't care. It would be worth the price if such a unit is available...
Re: Carpet cleaners [Re: grampi] #4115241 06/04/16 05:12 PM
sleddriver Offline
I take care of small carpet cleaning jobs using a wet shop vac, hot water & TuffStuff, if necessary. 80% of the time, hot water extraction works.
I heat about 800mL of water in a beaker to around 165F. Fire up the Rigid vac, pour a little hot water on the stain, then immediately vac it up. To do a small area, I use a plastic spray bottle and a 6" sweep nozzle.
Cheap + very effective and I didn't have to buy anything.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Carpet cleaners [Re: grampi] #4115389 06/04/16 07:52 PM
spackard Offline
Not putting you off from buying a HD machine, but I still have a household-duty carpet cleaner working after more than 10 years.
Every time I use it I flush everything with water afterwards. I figure not flushing the solution out of the machine is what kills a lot of the machines (in storage, in between uses).
Re: Carpet cleaners [Re: grampi] #4115396 06/04/16 08:08 PM
Donald Offline
I bought a professional machine geared for spotting and car upholstery cleaning. It's 3 gal tank and pretty east to use and carry. Mytee and others make them.
Only a professional machine has the type of vacuum motor to really extract the dirty water.
I have gone through a couple of SpotBots that lasted a year or so each before I bought the professional machine.
2015 Ford F-250 w/Powerstroke
Re: Carpet cleaners [Re: spackard] #4115548 06/05/16 05:42 AM
grampi Offline OP
I've always done that with every unit I've had. The problem I always have with them is they always stop spraying the cleaning solution...
Re: Carpet cleaners [Re: grampi] #4115587 06/05/16 06:47 AM
G
gman2304 Offline
G
Scour pawn shops or CL and and when you find a Kirby vacuum with the shampoo attachment, you'll never have to buy another vacuum or carpet shampooer again. Mine is 25 years old, still works great, has a lifetime motor guarantee. They are still made in the USA, you can still find parts easily if you need them, the shampoo attachment works great and they are built like a tank. You can find used ones for $100 or less.
Re: Carpet cleaners [Re: gman2304] #4115607 06/05/16 07:19 AM
grampi Offline OP
But they aren't any easier to handle. Kirby's weigh a ton!
Re: Carpet cleaners [Re: grampi] #4115689 06/05/16 09:26 AM
J
JustinH Offline
J
Bought a new household grade unit at Lowes last year for $99.
Hoover brand.
Works fine, we use it twice a year.
Not for heavy traffic just light duty work, also has upholstery cleaner.
'16 Ford Escape
'11 Scion XB
Re: Carpet cleaners [Re: JustinH] #4115698 06/05/16 09:33 AM
grampi Offline OP
Hoover brand.
Sounds similar to the ones we used to buy....used frequently, they don't work for long...
Re: Carpet cleaners [Re: grampi] #4115702 06/05/16 09:41 AM
T
Triple_Se7en Offline
T
Too many shampooers are used incorrectly. After soaping the carpet, the machine must go thru another cycle of thorough rinsing. Otherwise soap crystalizes and clogs things (over the years) in the shampooer.
Also, water filters help lengthen the shampooers life, in cases where no city water is available.
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: Carpet cleaners [Re: grampi] #4115709 06/05/16 09:55 AM
SHOZ Offline
I have a Bissell green machine. Seems every time I want to use it I have to take the heater apart to clean it out or no flow.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Carpet cleaners [Re: grampi] #4115944 06/05/16 03:04 PM
G
gman2304 Offline
G
'But they aren't any easier to handle. Kirby's weigh a ton!'
They do weigh a ton and you don't want to carry one up and down stairs but they handle very easily. The rear wheels drive the machine through a 'hydrostatic like' transmission and I or my wife can vacuum with one hand easily. The shampoo attachment attaches/detaches from the vacuum in less than a minute and is easily rinsed clean in the kitchen sink. No left over shampoo residue in the machine at all.
Re: Carpet cleaners [Re: sleddriver] #4116026 06/05/16 03:59 PM
CT8 Offline
I do that as well. The Man that comes with the van the scrubbing machine does the best job by far though.
2015 F150 2.7
2018 F350 6.2
Re: Carpet cleaners [Re: grampi] #4116120 06/05/16 05:15 PM
CKN Offline
I buy the Bissell upright cleaners with the hand tools. My last one was $98.00 dollars at Walmarts Black Friday sale.
They work good for a couple/three years then I throw them away and have to buy another.
Re: Carpet cleaners [Re: Triple_Se7en] #4116122 06/05/16 05:16 PM
CKN Offline
The new Bissell now has a "clear water" adjustment. The older ones did not have this.
