Chrome Polish
by rrretiree7 - 01/22/20 11:57 PM
2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Mikemac2008, Jeff1024, EricWestland, Brian200001, Phildrum
70507 Registered Users
38 registered members (AZjeff, AurionX2, bmod305, Bigpetee, Bailes1992, Black_Thunder, 3 invisible), 1,701 guests, and 24 spiders.
Topics300,451
Posts5,176,097
Members70,507
Is my starter going bad? #4115011 06/04/16 11:41 AM
F
Farmer Offline OP
F
On my 2010 Dodge Ram 3500 6.7L, the starter acts up once in awhile. Maybe 1-3 times a week for the last two weeks. It engages, starter spins once then kicks out. I have to attempt to start it maybe 3-5 times before it starts.
Batteries are fully charged reading 12.6V
Re: Is my starter going bad? [Re: Farmer] #4115020 06/04/16 11:55 AM
MolaKule Offline
Global Moderator
Global Moderator
Sounds like a starter but I would first go to Advanced Auto etc., and have them load the battery to determine its condition.
What is the charging voltage at idle with the driving lights on?
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Is my starter going bad? [Re: MolaKule] #4115023 06/04/16 12:00 PM
F
Farmer Offline OP
F
14 Volts. I haven't checked with a multi meter but that's what the gauge on the dash says.
Re: Is my starter going bad? [Re: Farmer] #4115026 06/04/16 12:03 PM
E
Elevguy Offline
E
Check out turbo diesel register.com great forum for cummins dodges
Re: Is my starter going bad? [Re: Farmer] #4115032 06/04/16 12:11 PM
B
BigD1 Offline
B
Don't put 100% faith in Advance Auto starter testing rig, or other testing rigs if you go that route. Just recently a Honda starter barely passed on their machine, but I knew it had to be bad. Put in a brand new battery, and most of the time it would not crank just like before. Installed a new starter, and it's been cranking first kick every time now.
Maybe you can get by with just changing the solenoid if it is a serviceable part.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: Is my starter going bad? [Re: Farmer] #4115037 06/04/16 12:14 PM
N
NHGUY Offline
N
The relay may be cutting out.
Re: Is my starter going bad? [Re: Farmer] #4115038 06/04/16 12:16 PM
A
abycat Offline
A
starter solenoid is my bet. Have had the exact same symptoms many times and starter fixed it every time. check around and see if you can get it rebuilt for cheap.
2017 dodge caravan gt
2011 nissan versa hb
Re: Is my starter going bad? [Re: Farmer] #4115050 06/04/16 12:35 PM
Chris142 Offline
The starter test stand can't put the starter under a load.pretty useless unless the starter is completely kaput
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Is my starter going bad? [Re: Farmer] #4115068 06/04/16 01:02 PM
E
eljefino Offline
E
IDK if you have a bendix style starter, where its own inertia kicks the gear down a helix shaft, but if the friction and drag clips aren't set up right, the gear will pop back home prematurely.
Regardless, the cure is a new starter. wink
Just be glad you're getting a warning.
Re: Is my starter going bad? [Re: Farmer] #4115076 06/04/16 01:18 PM
W
Warstud Offline
W
If you can hear the motor spinning after turning the key off means the motor is working the solenoid isn't engaging. Before buying a new one I would clean up all the connections at the solenoid first.
Re: Is my starter going bad? [Re: Farmer] #4115837 06/05/16 12:42 PM
F
Farmer Offline OP
F
Okay, I'll clean up the connections before getting a new one... I priced a reman, it was $250. frown
Re: Is my starter going bad? [Re: Farmer] #4115846 06/05/16 01:01 PM
supton Offline
That does sound steep--did that include a core charge?
What is an OEM replacement go for, if ordered online? Sounds like you can at least limp along for now, while shopping for best price.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Is my starter going bad? [Re: Farmer] #4116396 06/06/16 12:45 AM
F
Farmer Offline OP
F
No core charge. I didn't ask how much the core charge was either. I priced one at Napa, $296 not including core charge.
I was driving quite a bit today, no starter issues today. It definitely comes and goes.
Re: Is my starter going bad? [Re: Farmer] #4116677 06/06/16 09:38 AM
Colt45ws Offline
See if you can just get a solenoid for it. Thats what kicks the drive into the flywheel.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Is my starter going bad? [Re: Farmer] #4117195 06/06/16 06:27 PM
T
Trav Offline
T
It sounds like a bad drive or solenoid, I would bet on the drive from your description.
If you need a new starter here is a brand new Denso for close to reman price.
http://www.amazon.com/Denso-Starter-Motor-Dodge-2007-2010/dp/B0052XNC0A?&tag=rnwap-20
