P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
52 registered members (bullwinkle, 2015_PSD, alchargo, BobsArmory, bmod305, blufeb95, 5 invisible), 1,120 guests, and 19 spiders.
Topics300,572
Posts5,178,518
Members70,527
Clutch pedal softness #4114923 06/04/16 09:06 AM
Drew99GT Offline OP
this is kind of a weird "issue" with my car; it's always had it to some degree. Mind you, It does have new Master and slave cylinders (That have been properly bled) with less than 10,000 miles and I don't have any issue with the clutch fully releasing, problems shifting into reverse etc. that might warrant further investigation into the hydraulics or even the clutch itself.
Occasionally, especially after doing a lot of driving, after the car sits and cools off for several hours, when I first push the pedal in, it will be soft for about the first 1/4 length of pedal travel. After a few times using the pedal, it will firm up. It feels like there is slop/play in the clutch itself, like the pressure plate isn't returning fully or the throwout bearing/release fork has some slop in it.
Has anyone ever experienced this in a car? Like I said, even with that soft pedal, I can immediately shift to reverse and feel there is still at least an inch of play at the bottom of the pedal before it starts engaging the clutch, so it is fully disengaging with the pedal all the way in. That is why I don't think it's a hydraulic issue. Car is a 1994 Corolla with 180,000 miles and still on the original clutch.
Thoughts??? Thanks!
Re: Clutch pedal softness [Re: Drew99GT] #4114953 06/04/16 10:05 AM
CT8 Offline
The hydraulics are taking up the play in the mechanical parts most likely.
2015 F150 2.7
2018 F350 6.2
Re: Clutch pedal softness [Re: Drew99GT] #4114981 06/04/16 10:56 AM
M
mehullica Offline
M
Sounds like there's still air in one of the cylinders. Or one of the seals in the slave is leaking pressure or warped.
Re: Clutch pedal softness [Re: Drew99GT] #4115090 06/04/16 01:44 PM
A
andyd Offline
A
Or all or none of the above. Its a 22 yr old furren econo-box. Just about anything could be making the take up wonky. What are your plans for this old Corolla? I would certainly consider a total DIY clutch job. 180K decently maintained miles is a good indication that there are plenty of miles left.
Thick oil is better grin2
Re: Clutch pedal softness [Re: Drew99GT] #4115193 06/04/16 04:08 PM
G
Gokhan Offline
G
If bleeding the system doesn't solve the problem, you need to rebuild the clutch master and/or release cylinders.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 3,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
