Shutting Down Threads Because of "Speculation"
by e55amgbenz007 - 02/18/20 10:10 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
111 registered members (53' Stude, aquariuscsm, 750IX, ARB1977, 2K2AcuraTL, allepunta, 6 invisible), 2,124 guests, and 28 spiders.
Topics301,605
Posts5,198,990
Members70,737
Mercruiser Alpha 1 Gen 1 water pump service #4114432 06/03/16 05:13 PM
Donald Offline OP
I have the lower unit pulled to replace the impeller. I found a YouTube video on doing the impeller and it suggested to forget the o-ring near the top of the shaft going to the upper unit. Apparently the shaft goes into a seal you end up not being able to set it properly into the seal if you use the o-ring ring.
In the Gen 2, there is no slot for an o-ring.
2015 Ford F-250 w/Powerstroke
Re: Mercruiser Alpha 1 Gen 1 water pump service [Re: Donald] #4114641 06/03/16 11:04 PM
DoubleWasp Offline
Yes. That ring does make it a bit of a dastard to get in there correctly and efficiently. Just leave it out.
Most of the A1G1's we service have long since had them left out.
