Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
88 registered members (BeerCan, Blkstanger, Astro14, Alfred_B, ARB1977, 8 invisible), 1,877 guests, and 20 spiders.
Topics301,600
Posts5,198,891
Members70,737
Compressing pistons #4114399 06/03/16 04:13 PM
M
mjoekingz28 Offline OP
M
Let us say I am doing a front brake job on a regular car. I remove the caliper and pull the pads, THEN I unscrew the bleeder and push the piston in and then put it back like new so the new, full pads will fit the rotors.
My question is will I run into problems with fluid contamination, air in the system, or anything else that I cant think of right now?
Re: Compressing pistons [Re: mjoekingz28] #4114402 06/03/16 04:15 PM
d00df00d Online Content
Online Content
Yes. You'll get a tiny bit of moisture in the brake fluid and the system will have to be bled.
2008 BMW M3 Sedan 6MT
Re: Compressing pistons [Re: mjoekingz28] #4114403 06/03/16 04:18 PM
DSparks Offline
Shouldnt be that much of an issue as long as it didnt get any air in the caliper with the bleeder open....I usually use a big [censored] c-clamp to push the piston in and do it without opening the bleeder....
Re: Compressing pistons [Re: mjoekingz28] #4114411 06/03/16 04:28 PM
F
Falken Offline
F
When I did my Honda Fit brakes 20,000km ago (I also learned this in Auto Mechanics from a teacher):
Unscrew the bleeder before you push in the piston, this prevents copper oxide and gunk from being forced back into your ABS pump.
If you gravity bleed when you are done, with a vinyl hose attached, your brakes will be great.
If you can hit the brakes on gravel to cycle the ABS pump afterwards as well, you will have solid, firm brakes.
Re: Compressing pistons [Re: mjoekingz28] #4114442 06/03/16 05:30 PM
R
Rolla07 Offline
R
No need to unscrew the bleeder, save the hassle and just push in the piston.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Compressing pistons [Re: mjoekingz28] #4114484 06/03/16 06:36 PM
supton Offline
In years past I would just push back the piston. No ABS back then. Today, I'd think it'd have to be a very large piston to drive fluid all the way back to the ABS pump. Might as well try to crack the bleeder. I don't think just cracking the bleeder will get air in, not unless if the piston were somehow pulled out in the process, or you waved the caliper around extensively with the bleeder cracked--I'd hold it steady while pushing in, then tighten back down while it's still in the same spot.
2011 Toyota Camry, base, 2.5L/6MT, 201k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Compressing pistons [Re: mjoekingz28] #4114485 06/03/16 06:37 PM
clinebarger Offline
Never push the funky old Brake Fluid that is in your Calipers back through the ABS & Master cylinder.
Open the bleeder, Push the piston in, Install your Pads & reinstall the Caliper, Pump the brake pedal a couple times, Open the bleeder & whatever air is in the caliper will gravity bleed out.
2001 Chevy Camaro L92/4L80E
Re: Compressing pistons [Re: mjoekingz28] #4114516 06/03/16 07:15 PM
X
Xrs2zz Offline
X
I cracked the bleeder before pushing the piston back, but I attached a tube to the bleeder first.
That way no air got back in because the tube was filled with old fluid and I closed the bleeder after the piston fully retracted. I have a nice firm pedal and it's been 3 months since I did the brakes.
I did a full fluid exchange last year, so I didn't bother bleeding the fluid after I was done.
2003 Toyota Matrix Xrs-207k Miles
