Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
26 registered members (CB22, Char Baby, bbhero, Black_Thunder, Bailes1992, 3 invisible), 1,366 guests, and 28 spiders.
Topics300,415
Posts5,175,286
Members70,497
Mercruiser fuel cooler module #4113563 06/02/16 05:23 PM
Donald Offline OP
My brother has a 2005 Sea Ray with twin Mercruiser GM big blocks. Each engine has a fuel cooler module to cool the fuel. It's cooled with sea water even though the basic engine is FWC.
Apparently the inside of the fuel cooler module is painted and that paint is now flacking off getting into the fuel pressure regulator, fuel rail and injectors. He cannot run the engine and must be towed to a Mercruiser dealer.
Anyone hear of this? Does Mercruiser pick up the entire tab or parts only? I told him to push Mercruiser hard to pick up the entire tab.
2015 Ford F-250 w/Powerstroke
Re: Mercruiser fuel cooler module [Re: Donald] #4113568 06/02/16 05:37 PM
B
BigCahuna Offline
B
He has a warranty on an 11 year old boat that would cover that?.,,,
Re: Mercruiser fuel cooler module [Re: Donald] #4113575 06/02/16 05:49 PM
R
Rand Offline
R
That sounds bizarre. I could see them coating the inside of the cooler where the saltwater flows to prevent corrossion.. but coating the inside where the fuel flows?
Those are known to clog with salt/deposits and require cleaning.
When clogged the fuel is too hot and the engine will only run a short amount of time.
Are you positive that was diagnosed correctly?
Re: Mercruiser fuel cooler module [Re: BigCahuna] #4113576 06/02/16 05:49 PM
W
Wampahoofus Offline
W
+1 Mercury has no obligation to pick up the tab on an 11 year old product.
13 Triumph T100 - Delvac 1300 15W-40
03 Chrysler 300M - PYB 5W-30
Re: Mercruiser fuel cooler module [Re: Donald] #4113639 06/02/16 07:15 PM
Donald Offline OP
Mercruiser has a TSB on it. Mercruiser had an improperly designed/manufactured part. This was the third generation of the fuel cooler module. Given that the replacement fuel cooler module is a different design and Mercruiser will pay for the parts it says to me they are admitting there is a problem with the design of the fuel cooler module. Maybe the paint could not stand up to E10 fuel. Mercruiser should have thought about that. Maybe advise owners to replace the fuel cooler module before the paint starts flaking off.
You expect problems due to wear, and maybe manufacturing defects, but not design issues.
Re: Mercruiser fuel cooler module [Re: Donald] #4113783 06/02/16 10:02 PM
DoubleWasp Offline
It's Mercruiser. Of course it has a design flaw.
I wouldn't expect them to be terribly nice about it at all. They rarely are.
It's going to come down to the dealer. If they shove hard enough, Merc should at least cover parts. Labor? Maybe, but not likely.
The "Cool-Fuel" system is part of why I run only big block carb engines.
Re: Mercruiser fuel cooler module [Re: Donald] #4114208 06/03/16 11:40 AM
B
bubbatime Offline
B
If they replace the parts, awesome.
But I would not count on it. Not on a 11 year old boat.
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Mercruiser fuel cooler module [Re: Wampahoofus] #4114280 06/03/16 01:16 PM
SteveSRT8 Offline
+ a thousand or so. I can't believe anyone would think they deserve warranty on an old boat no matter your personal feelings about mercury...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
