2018 Ram 2500 with 21k miles. Delo 400 XSP 5w40
by bigbadbowtie - 02/27/20 11:08 AM
For those always asking about tiny Computers
by jayjr1105 - 02/27/20 11:05 AM
Original 2016 VW Passat cabin filter
by Vaca - 02/27/20 11:02 AM
Original 2016 VW Passat air filter
by Vaca - 02/27/20 10:54 AM
Napa Exceptional Customer Service
by Fitz98 - 02/27/20 10:38 AM
Astra 400 ?
by WyrTwister - 02/27/20 09:58 AM
Will thinner oil damage anything when it is burned?
by Fordiesel69 - 02/27/20 09:38 AM
Old news for Hyundai/Kia?
by Farnsworth - 02/27/20 09:33 AM
Looking for AA 25% off coupon code.
by JustChuck - 02/27/20 09:17 AM
New to the LS460 and The World Of Lexus. Questions!
by gr8gatzby - 02/27/20 08:41 AM
New old guy back.
by BJD2020 - 02/27/20 07:45 AM
Help me Decide
by Gebo - 02/27/20 07:36 AM
FWD - Death traps with miss matched tires.
by Fordiesel69 - 02/27/20 07:13 AM
Napa Gold Sale
by Toto - 02/27/20 06:52 AM
2016 or 17 Honda CR-V
by Loogie - 02/27/20 05:20 AM
RIP Clive Cussler
by PimTac - 02/27/20 04:48 AM
Pirelli Cinturato P7 Allseason PLUS "II"
by Char Baby - 02/27/20 03:31 AM
CCI clean .22 ammo - polymer coated HV
by Shannow - 02/27/20 03:23 AM
5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
94 registered members (1978elcamino, askani79705, 2015_PSD, Astro14, ARCOgraphite, Amenhotep, 8 invisible), 2,108 guests, and 16 spiders.
Topics301,989
Posts5,206,932
Members70,808
high metals vs oci #4113486 06/02/16 02:43 PM
M
meborder Offline OP
M
Just curious if there is any real correlation between the two.
My last uoa showed higher metals than I liked, but the oil looked otherwise ok.
So I'm at 7500 miles on my current fill and not sure if I should change or go ahead and push to 10k since the oil itself was fine.
I'm getting the feeling that the metals just are what they are based on the use, and on a per mile basis a shorter run wont really help anything.
Thoughts?
http://www.bobistheoilguy.com/forums/ubb...0kO#Post4018725
The only thing different between the oua above and the current fill is I'm using a FRAM ultra instead of the Bosch distance plus.
Too many cars using too many different oils to list in 150 characters.
Re: high metals vs oci [Re: meborder] #4113489 06/02/16 02:57 PM
cat843 Offline
You will get xxx ppm of iron and other metals per 1000 miles. Some engines will have more and some less. Many people use UOAs to develop a baseline. If you UOA show 20 ppm per 7500 OCI consistently then one goes to 50, you know something is wrong, probably air intake.
Cat-Man-843
Re: high metals vs oci [Re: meborder] #4113499 06/02/16 03:14 PM
B
BrocLuno Offline
B
You are in S Dakota so you will either have all season oil, or spring/fall changes. If spring/fall changes are your norm, I'd run one batch of SAE30 HD in the spring to the fall and see what the UOA looks like?
that iron might be cylinder wear on start-up... It might also be a not to great a fit between the air cleaner and the base or top? I'd be looking at all that...
Note: the lowest wear at all temps is with straight 30 ...
Re: high metals vs oci [Re: meborder] #4113500 06/02/16 03:17 PM
N
Nate1979 Offline
N
The purpose of a UOA is generally two fold:
1) Determine how dirty the oil is, compare to condemnation limits and determine whether to change or not. Condemnation limits for metals are usually much higher than is ever posted on this site. TBN, viscosity, moisture, oxidation, etc are probably more critical.
2) Catch issues before they become a big problem - coolant, fuel, air filter issue, etc.
2015 GMC Sierra 2500 6.0L
2010 Subaru Forester 2.5X
Re: high metals vs oci [Re: BrocLuno] #4113713 06/02/16 08:46 PM
CT8 Offline
Well yeah most people think for some reason a high VI is a good thing . Not on a finished oil,the base oil maybe. A 10w-30 is a thin oil with viscosity improvers that coil up when hot yet they straighten out [sheer] when they are between sliding surfaces so with 10W-30 multi visc oil when between the parts actually is a much thinner oil than with a straight 30.
2015 F150 2.7
2018 F350 6.2
Re: high metals vs oci [Re: meborder] #4113728 06/02/16 09:01 PM
K
Kuato Offline
K
Three different oils it's hard to compare. But - the Castrol is showing a LOT more iron than the other two oils. Agree it could be cold startup wear, but am concerned that the Castrol might not be a good oil for this engine. In your place I'd try another oil next winter to see if the results are the same...your engine might just put out more oil on cold starts, or it might have an issue with the Castrol. (the same as the Jeep 4.0 has an issue with M1).
Basically, stick with the same oil for several OCIs so you're comparing apples to apples.
Thick vs Thin test: 15k / 43k miles complete
Re: high metals vs oci [Re: CT8] #4113807 06/02/16 11:28 PM
Z
zeng Offline
Z
+1
During oil selection ,I never look at VI ..........
unless the applications is under 'stress' as in differentials .......in which case, I would select one with a lower VI for shear-stability property ....never mind if it's mineral or otherwise. blush
Re: high metals vs oci [Re: Kuato] #4113902 06/03/16 05:39 AM
M
meborder Offline OP
M
I could sample the current fill, which would be an apples to apples comparison.
But the real question is at what oci? I'm at 7500 (might be 8500) now on the same extended performance castrol. But can I go to 10k+?
The high metals make me nervous, but the oil appeared fine. I'm just not sure if the two are directly related or not. The Ashland oil had high metals as well, so it makes me wonder. The fill with relatively low metals was not representative of this vehicles normal use (was done as a check to see if 5w30 is ok)
The ultimate goal is a 10k oci, because then I'm only under there twice a year.
Re: high metals vs oci [Re: meborder] #4114528 06/03/16 07:34 PM
K
Kuato Offline
K
Be interesting to see the UOA. I'm sure there's a suitable oil for your engine that will go 10k.
