Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
33 registered members (aleneros, Aerojoe, BBDartCA, Bailes1992, ArrestMeRedZ, 7 invisible), 1,287 guests, and 28 spiders.
Topics300,415
Posts5,175,283
Members70,497
CANNOT find this part #4113349 06/02/16 11:58 AM
Throt Offline OP
Hi all,
Working on putting new front brake lines on a 1999 GMC K1500 Suburban SLT 5.7 and CANNOT find the passenger side preformed in regular metal. The only thing I can find that includes the passenger side is a full stainless set, which is $300 and which I do not need. RockAuto has "Front Forward" but it only shows the driver side in the picture. No passenger side. I have searched EVERYWHERE.
Grandpa doesn't want to form them himself. Thanks
'18 Honda Accord Touring, 1.5T, 18,750mi, 1/2 M1 AFE 0w20, 1/2 PPPP 5w30 w/ M1 filter.
'19 Elantra, 2.0NA, 6,500mi, FF/Filter, hers (lease)
Re: CANNOT find this part [Re: Throt] #4113376 06/02/16 12:38 PM
B
bullwinkle Offline
B
Why wouldn't you want the nickel/copper ones? Won't rust, super easy to bend, that's what I put on the rear of the C3500 in my sig, piece of cake.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: CANNOT find this part [Re: Throt] #4113379 06/02/16 12:42 PM
E
exranger06 Offline
E
You probably won't have any choice but to bend up a line yourself.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: CANNOT find this part [Re: Throt] #4113408 06/02/16 01:11 PM
01rangerxl Offline
Do you need #21 or #4, or both?
#4 is readily available, part # 15711830, and lists for $50. It's $30 on Amazon.
GM specifies bulk 3/16" tubing for #21. Even on much newer vehicles, sometimes sections of the brake lines will only be sold as bulk. We recently had to use bulk 3/16" tubing from GM and GM tube nuts at work to complete a warranty repair on I think a 2014 Malibu.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: CANNOT find this part [Re: Throt] #4113465 06/02/16 02:04 PM
bdcardinal Offline
Ford is the same way, on a lot of applications there is no service part for brake tubing. You can tell because instead of a base number on the illustration there will be a blue star.
You can try from Classic Tube. I got a complete brake line set from them for my 1995 Mustang.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: CANNOT find this part [Re: Throt] #4113466 06/02/16 02:10 PM
T
Trav Offline
T
The front lines on these are super easy to do and even easier with NiCopp line. The PITA line is the one going to the rear.
Cut the fitting off with a pair of side cutters and remove them with a 6pt socket,mark their location, remove the lines from their clips and your good to go.
Advance has NiCopp and the fittings in stock just take the fitting in to match them, the line can easily be bent into shape by hand just follow the old ones as a guide and add an inch on each end for the cut off fittings.
Put the correct fitting on the line, flair and install it, bleed. Its an easy DIY job on this one.
Re: CANNOT find this part [Re: Throt] #4113475 06/02/16 02:27 PM
bdcardinal Offline
If GM tells the size of the fittings and tube that is awesome. Ford doesn't give us any info on the parts end. I just tell people to cut the fittings off the old lines and match them up at a jobber brake parts house.
Re: CANNOT find this part [Re: Throt] #4113488 06/02/16 02:53 PM
M
Merkava_4 Offline
M
Unbolt line #21 and take it to a brake shop for matching up. Find a real brake shop, not one of those corporate chain stores. Big Rig shops are usually the best. Located next to the main freeway.
Re: CANNOT find this part [Re: Throt] #4113577 06/02/16 05:50 PM
DuckRyder Offline
Did you call inline tube? They will probably sell you an individual line though they list sets mostly...
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: CANNOT find this part [Re: bdcardinal] #4113604 06/02/16 06:24 PM
01rangerxl Offline
Sometimes they do, sometimes they don't. Unfortunately, the catalog didn't give the size for fitting #20. GM's catalog descriptions range from very specific size information to "BOLT."
There was a part number for #20. I'll get it tomorrow.
Re: CANNOT find this part [Re: Throt] #4113608 06/02/16 06:28 PM
bdcardinal Offline
Ford also does the famous "miscellaneous hardware" for a part description, thanks.
Re: CANNOT find this part [Re: Throt] #4113643 06/02/16 07:26 PM
splinter Offline
Have you tried LMC truck parts?
I've had good luck sourcing 'NLA' hardware from them. Always received good service, too!
----> www.lmctruck.com
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Past performance is no guarantee of future results.
Re: CANNOT find this part [Re: splinter] #4113681 06/02/16 08:09 PM
chad8 Offline
Is this it?
http://www.ebay.com/itm/95-99-CHEVY-GMC-TAHOE-YUKON-SUBURBAN-1500-4X4-FRONT-BRAKE-LINE-KIT-STEEL-/252196530249?hash=item3ab815a849:i:252196530249&vxp=mtr
Re: CANNOT find this part [Re: splinter] #4113741 06/02/16 09:11 PM
01rangerxl Offline
As great as LMC's selection is, I think they only have hard line sets for GMT800 trucks. The Suburban the OP is working on is a GMT400.
Re: CANNOT find this part [Re: bdcardinal] #4113992 06/03/16 07:48 AM
T
Trav Offline
T
IIRC It is 1/4" line with 5/16 double flair fittings.
