Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
23 registered members (Black_Thunder, bbhero, AndyB, adams355, Bailes1992, 2 invisible), 1,617 guests, and 29 spiders.
Topics300,415
Posts5,175,292
Members70,497
Carbide Tipped Metal Cutting Blades #4113327 06/02/16 11:40 AM
G
George7941 Offline OP
G
This is my present set up, the machine is about fifty years old but still works. The abrasive wheel takes along time to cut. The piece of 1/4 in thick metal you see on the table was cut with this abrasive wheel but it takes about five minutes to cut an inch. The arbor is 5/8 in and wheel speed is about 2000 rpm.
Will a carbide tipped blade cut faster? The blades are expensive, will they last long enough to justify their cost?
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Carbide Tipped Metal Cutting Blades [Re: George7941] #4113347 06/02/16 11:56 AM
T
The_Eric Offline
T
We use one in a chop style saw- but it's designed for the blade/work and it's lasted about 2 years so far with no signs of dulling.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Carbide Tipped Metal Cutting Blades [Re: The_Eric] #4113421 06/02/16 01:24 PM
K
Kira Offline
K
Sometimes you're better off cutting with a Porta-Band style tool, no?
Re: Carbide Tipped Metal Cutting Blades [Re: George7941] #4113422 06/02/16 01:26 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Depending on speeds and feeds, the carbide blade may heat up too much, when compared with abrasive blades.
A softer abrasive blade will cut faster at the expense of greater wear.
A band saw will give the best cut if you have access to one.
Re: Carbide Tipped Metal Cutting Blades [Re: Kestas] #4113432 06/02/16 01:37 PM
G
G
I don't have access to a band saw.
I will buy the carbide tipped blade and try it out. If there is overheating, it is easy enough to slow the wheel down on my set up by using a different diameter pulley.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Carbide Tipped Metal Cutting Blades [Re: George7941] #4113457 06/02/16 01:59 PM
Astro14 Offline
Carbide is great for wood, and cuts softer metals, like aluminum or brass, reasonably well, but it's too brittle for hard metals like steel. What are you cutting?
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Carbide Tipped Metal Cutting Blades [Re: George7941] #4113483 06/02/16 02:38 PM
K
Kawiguy454 Offline
K
Ive seen band saws for cutting bar stocks and used abrasive wheels for cutting myself.
For what you have there a plasma cutter would do it in seconds with very smooth cut edge. And if you need repeat-ability you can make a template. Lotos makes an inexpensive unit.
If your sticking with that table saw I would change the pulley and get the abrasive wheel spinning faster.
Re: Carbide Tipped Metal Cutting Blades [Re: George7941] #4113509 06/02/16 03:24 PM
M
Merkava_4 Offline
M
Those carbide tipped metal cutting blades are for cutting light gauge steel like rain gutters. Your problem is the 2000 RPM. With a cutoff wheel on my right angle grinder, I can cut 1/4 inch steel in no time flat, but the wheel is spinning at 11,000 RPM.
Re: Carbide Tipped Metal Cutting Blades [Re: Astro14] #4113524 06/02/16 03:50 PM
G
G
Most commonly, 1/4 thick to 1/2 in thick mild steel.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Carbide Tipped Metal Cutting Blades [Re: George7941] #4113537 06/02/16 04:24 PM
L
larryinnewyork Offline
L
Looking at your set-up, I would not use a carbide blade.
If you do, I would predict you'll cut off 1 or more fingers.
In metal working, your work-piece needs to be securely fastened in a vise with a controlled feed rate.
I bought new blades for my hack-saw and was surprised to see how fast it cut.
Re: Carbide Tipped Metal Cutting Blades [Re: George7941] #4113597 06/02/16 06:08 PM
sleddriver Offline
Do not use a carbide-tipped blade to cut steel. Period. Use an abrasive wheel or a hacksaw.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Carbide Tipped Metal Cutting Blades [Re: George7941] #4113611 06/02/16 06:31 PM
P
punisher Offline
P
I have a 14" cold cut chop saw (Ironton from Northern $199 on special). So far (after about 5 months) it is the best thing since sliced bread. Nothing too heavy yet, mainly 1/8-3/16 flat stock and angle, lots of tubing. Blade is still "fresh". Goes through steel like butter, especially compared to my old Makita 14" abrasive. Main thing is the cold cut saw requires almost no cleanup vs an abrasive cut. Huge time saver.
Drawback- blades go for $90 each, vs 4 for $18 for Dewalt 14" abrasive disks/blades.
Only real drawback, the steel metal shards/shavings that come off that carbide blade are SHARP. They get in everything. They embed in the soles of boots/shoes, and get tracked around, and the first bare foot that hits them, tweezer time. I made it a week before I hit Home depot and grabbed a magnetic sweeper for $30. Life saver. No matter how much you sweep with a regular broom, the amount of stuff that magnet picks up is surprising.
Aluminum gets cut with my trusty Hitachi miter saw. Wood, aluminum, it don't care.
Re: Carbide Tipped Metal Cutting Blades [Re: George7941] #4113691 06/02/16 08:25 PM
tom slick Offline
My shop uses a carbide tiped blade for cutting thick steel every day, the saw and blade are specifically designed for cutting steel. Because you are actually cutting there is no limit on material thickness, the material doesn't get hot, the cut is very straight, and has very little burr. It's called a dry cut saw.
http://www.steelmax.com/product-category/metal-cutting-saws/metal-cutting-saw/
http://makitatools.com/en-us/Modules/Tools/ToolDetails.aspx?Name=LC1230
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Carbide Tipped Metal Cutting Blades [Re: tom slick] #4114178 06/03/16 10:45 AM
sleddriver Offline
With a special, hand-held steel cutting saw + blade + experience, OK. With a steel-cutting chop saw, OK.
I'll yield.
With the old TS the OP is using, where the blade rotates towards your face, holding the work by hand and using a "regular" carbide blade?
No way Jose..........
M1 10W-30 HM
Re: Carbide Tipped Metal Cutting Blades [Re: sleddriver] #4114330 06/03/16 02:36 PM
T
Tempest Offline
T
I'll yield.
I'd have to agree. Looks like a kickback waiting to happen.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
