Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
19 registered members (LvR, Bailes1992, dogememe, earlyre, hpb, harry j, 2 invisible), 535 guests, and 21 spiders.
Topics300,304
Posts5,172,822
Members70,467
Most Online3,728
Jan 11th, 2020
Hybrid Heat Pump and Oil Furnace Combo- Winter Set #4113279 06/02/16 10:47 AM
A
AirgunSavant Offline OP
A
I just got this combo setup last week.
It uses a Wi-Fi thermostat.
My question is to the east coast guys........
What temp do you set yours out to switch over from heat pump to oil in the winter?
My electric is pretty cheap at 7.9 cents a KWH.
Thanks
Re: Hybrid Heat Pump and Oil Furnace Combo- Winter Set [Re: AirgunSavant] #4113329 06/02/16 11:40 AM
M
mikered30 Offline
M
When it gets below 35 sustained at night. No need for the emergency heat to kick on.
Re: Hybrid Heat Pump and Oil Furnace Combo- Winter Set [Re: mikered30] #4113373 06/02/16 12:33 PM
A
A
Thanks I was thinking in that range as well!
Re: Hybrid Heat Pump and Oil Furnace Combo- Winter Set [Re: AirgunSavant] #4113405 06/02/16 01:09 PM
J
Jetronic Offline
J
I'm thinking to add a heat exchanger myself.
How much heating power does yours have, and what's the efficiency?
Didn't think you could use them at those temperatures, figured the evaporator would be solid ice. Good news I suppose, but how hot can you get the water at those temperatures?
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: Hybrid Heat Pump and Oil Furnace Combo- Winter Set [Re: AirgunSavant] #4113544 06/02/16 04:35 PM
N
Nebroch Offline
N
What brand/model your system is? These hybrid systems are very clever, they balance the power grid too (consumption tends to go up when temperature goes down).
Re: Hybrid Heat Pump and Oil Furnace Combo- Winter Set [Re: Nebroch] #4113773 06/02/16 09:48 PM
A
A
Both units are the Bryant Preferred series. Bryant also supplies the thermostat.
Re: Hybrid Heat Pump and Oil Furnace Combo- Winter Set [Re: Jetronic] #4113776 06/02/16 09:54 PM
A
A
The HP is 16 SEER and the furnace is 87% as its oil and not propane. I have propane in another house and I like it better and only if you own your own tank. But this house was setup for oil with the oil tank already in the basement etc., so I just went with oil again.
I did not go crazy with a high Seer on the HP because I did the math and this place is tops on energy efficiency and there would be no payback
