Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
33 registered members (aleneros, Aerojoe, BBDartCA, Bailes1992, ArrestMeRedZ, 7 invisible), 1,287 guests, and 28 spiders.
Topics300,415
Posts5,175,283
Members70,497
Aisin parts Genuine Toyota OEM? #4113221 06/02/16 09:43 AM
Drew99GT Offline OP
I'm gonna have to put another clutch master cylinder in my Corolla since the Oreilly ones are absolute junk.
I found this one online with the same part number as the OEM Toyota for $70 less!
http://www.autohausaz.com/pn/3141012381
Here is a link to an OEM one.
http://parts.bernarditoyota.com/parts/19...p;siteid=216017
Can I assume they are the same??? Apparently Toyota owns 30% of Aisin. shrug
Thanks for any insight.
Re: Aisin parts Genuine Toyota OEM? [Re: Drew99GT] #4113225 06/02/16 09:48 AM
O
Oro_O Offline
O
In general, yes. In this case, it most likely is.
There may be applications that the Aisin is NOT the OE part because of the supply chain variables, but it will be a quality part and you can use it with confidence. Sometimes aftermarket Aisin parts will arrive and you will find a spot where the Toyota OE p/n is ground off; on some parts it's cast right into it and only removed later if it is sold aftermarket vs. shipped for OE assembly.
Re: Aisin parts Genuine Toyota OEM? [Re: Drew99GT] #4113228 06/02/16 09:52 AM
K
kschachn Offline
K
Yeah, I buy a lot of Aisin parts for my Toyotas, generally what I receive is a part with the Toyota logo ground off. Never have I seen a part that is not identical to the one I am replacing.
With European cars you generally know who makes the part and usually those manufacturers sell the part independently from the OEM. That's a bit less certain for Asian manufacturers but for some ones (such as Aisin) it's a pretty good bet. Bottom line I would have no hesitation to install that cylinder on my car even if it wasn't the OEM - which I doubt. Aisin makes superb parts. I use them even when they aren't OEM such as on my Honda.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Aisin parts Genuine Toyota OEM? [Re: Drew99GT] #4113237 06/02/16 10:03 AM
Drew99GT Offline OP
Thanks guys. I ordered it. Hopefully this is the last one. The Oreilly lifetime slave and master cylinders lasted 1 year before leaking.
Re: Aisin parts Genuine Toyota OEM? [Re: Drew99GT] #4113333 06/02/16 11:46 AM
N
nthach Offline
N
And if Aisin doesn't make the part, they'll rebox the OE supplier with their label - they seem to do with with Subaru and Honda water pumps - there might be a Aisin stamp on it but the same markings as the OEM Yamada part.
Re: Aisin parts Genuine Toyota OEM? [Re: Drew99GT] #4113487 06/02/16 02:48 PM
T
Trav Offline
T
Same part, that's a screaming deal.
Re: Aisin parts Genuine Toyota OEM? [Re: Drew99GT] #4113494 06/02/16 03:08 PM
G
Gokhan Offline
G
You can also buy an OEM rebuild kit from the dealer. Rebuilding master cylinders is trivial.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 2,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
