2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
Effects of increasing engine RPM?
by Avery4 - 01/27/20 11:09 AM
New C8-R Vettes at Rolex 24
by racin4ds - 01/27/20 10:39 AM
Thoughts on redline?
by BTLew81 - 01/27/20 10:15 AM
Yak trax
by John_Conrad - 01/27/20 10:00 AM
Castrol GTX 20w50
by VQLT - 01/27/20 09:33 AM
Mevotech Terrain Tought ttx?
by buck91 - 01/27/20 08:54 AM
House electric questions
by supton - 01/27/20 08:37 AM
How an automatic transmission works
by supton - 01/27/20 08:08 AM
AC Delco UPF48R and UPF64R $1.50 rebate at Rock Auto
by Snagglefoot - 01/27/20 07:15 AM
Netgear Nighthawk M1 and Router setup
by Tribe21 - 01/27/20 06:24 AM
Alignment questions: is camber/caster not usually touched?
by FordBroncoVWJeta - 01/26/20 10:47 PM
Pricing used tires
by PumpPusher - 01/26/20 10:21 PM
STP Motor Oil at HF
by kstanf150 - 01/26/20 10:07 PM
9 years for the 4 cylinder Eco-boost
by Snagglefoot - 01/26/20 09:39 PM
So I picked this up..
by Mad_Hatter - 01/26/20 08:49 PM
New here and question about oil.
by Sunstealth - 01/26/20 08:42 PM
Burner718, masstrnsprtcmplx, tampasaint, rdmjone, BigGeo
70537 Registered Users
134 registered members (440Magnum, 53' Stude, 2002 Maxima SE, 2015_PSD, 1978elcamino, 2strokeNorthstar, 11 invisible), 2,647 guests, and 17 spiders.
Topics300,630
Posts5,179,760
Members70,537
2004 Saturn Ion Kendall 5w30 blend ~7500 #4113178 06/02/16 08:48 AM
M
MinamiKotaro Offline OP
M
This is the first analysis of oil from the replacement engine, which is also a 2004 model that came out of a Malibu, I think. It supposedly had 40,000 on it.
Oil used was Kendall GT-1 5w30 blend. Don't know why calcium is highlighted.
1967 VW Beetle: Delo 15w40/ST4386
2004 Saturn Ion: Magnatec 5w30/DW5436
2014 Polaris Ranger 570: Delo 5-40/Wix 51356
Re: 2004 Saturn Ion Kendall 5w30 blend ~7500 [Re: MinamiKotaro] #4113307 06/02/16 11:19 AM
B
bigt61 Offline
B
Looks good. I'm sure even SuperTech would be fine if you keep it topped off. Any top off oil added during the run?
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: 2004 Saturn Ion Kendall 5w30 blend ~7500 [Re: bigt61] #4113655 06/02/16 07:42 PM
M
M
No.
Re: 2004 Saturn Ion Kendall 5w30 blend ~7500 [Re: MinamiKotaro] #4113822 06/03/16 12:03 AM
M
mjoekingz28 Offline
M
Any reason why someone killed a Ecotec.
I love mine.
In a 7000-7500 OCI in a 5qt sump. I use, not quite, 5qt initial fill then end up adding a little here, a little there. It seems to get thirstier in the latter half of the oil change interval. I probably Add a full quart or two....but keep n mnd you can burn through a quart and never be below add, so you BURNED a quart but didn't ADD a drop!
Re: 2004 Saturn Ion Kendall 5w30 blend ~7500 [Re: MinamiKotaro] #4113824 06/03/16 12:07 AM
M
mjoekingz28 Offline
M
My Cobalt seemed to have been run almost entirely on Firestone changes for 125,000 from day 1(2006) until 2014. I even partook a time or two snce I was worrysome about trying something new (cartridge filters). I think they would run the Kendall hi-mile oil.
It just got plugs and a fuel filter around 125-150k and a stumbling when approaching stops. It wont quit but will act like it wants to........2.2 4spd auto
