Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
27 registered members (CB900F2, adams355, Char Baby, CapriRacer, bmod305, 4 invisible), 956 guests, and 19 spiders.
Topics300,304
Posts5,172,833
Members70,467
Most Online3,728
Jan 11th, 2020
2005 honda accord #4112809 06/01/16 08:05 PM
dslofti Offline OP
I have a accord that calls for 5w20, it has bout 175k on it. I see no leaks or oil weeping around, I just it bout 2500 miles ago with mobil 1 5w20. It is now almost down to the add bar on the dip stick. I thought bout trying mobil 1 high milege but I don't want my seals to start leaking. Or maybe just go to mobil super 5000 see if that helps. What do you guys think?
Re: 2005 honda accord [Re: dslofti] #4112812 06/01/16 08:13 PM
J
JXW Offline
J
I would be more concerned with the trans if it is an automatic. That is the weak spot you are facing.
I don't think oil brand will likely determine the future outcome of your engine, seals etc.
2007 Tundra SR5, 4x4, 5.7l PP 5w20
2006 HD FLTRI, 20w-50 Redline, 95ci,
2015 Kubota BX2670
2010 BMW 328i x drive, 6M, Redline 5w-30
2010 Honda Fit Sport
Re: 2005 honda accord [Re: dslofti] #4112815 06/01/16 08:16 PM
wemay Offline
If leaking is excessive, I'd go with the Mobil 1 HM. I doubt the HM oil would make it leak any more than Mobil1 has. HM oils are usually on the thicker end of the viscosity range than their non-hm counterparts. If you're very concerned the HM oil may clean out any crude, making the leaks worse and that you're spending money on a premium synthetic that's just going to leak out, then try the Mobil Super.
2019 VW Passat Wolfsburg TSI
Castrol Edge Professional LL IV FE 0W-20, OEM
2013 Hyundai Santa Fe Sport 2.0T
Mobil1 Annual Protection 5W30, M1-104
Re: 2005 honda accord [Re: dslofti] #4112823 06/01/16 08:21 PM
dslofti Offline OP
It's not leaking a drop just burns it a little
Re: 2005 honda accord [Re: dslofti] #4112837 06/01/16 08:34 PM
wemay Offline
Then I'd try a HM oil.
Re: 2005 honda accord [Re: dslofti] #4112876 06/01/16 09:07 PM
A
asker123 Offline
A
welcome to the league..Accord 2003 owner here. Car burns oil...about 1 liter every 1000 miles...even more when I drive it hard
I am also continueing with mobil 1 5w20 for the time being...
I heard that valvoline maxlife does the wonder but we don't get the full synthetic version here in Canada , only the synthetic blend..
not sure what to do...
Honda Accord 2003 4 cyl
Mobil1 EP 0W20, M1-110 oil filter
OEM engine air filter
Honda brand ATF-dw1, Type 2 Coolant , Brake Oil
Re: 2005 honda accord [Re: dslofti] #4112949 06/01/16 10:27 PM
oilmutt Offline
What is Mobil 500 suppose to help?
'05 Chevy Malibu 6cyl,119k, Syn. Oil (owned)
'16 Toyota Camry,4cyl 25k Syn oil (leased)
'92 Ford Tempo ,4cly 26k Conv oil (managed)
Re: 2005 honda accord [Re: dslofti] #4112995 06/02/16 01:07 AM
U
UltrafanUK Offline
U
How much oil is it burning ??
Changing to an HM oil will not start an oil leak.
If you are concerned out the oil consumption rate, first of all make sure the CCV (Crank Case Vent) is not blocked. Then I would move up a grade to an 0 or 5w30 and either switch to a major brand (Mobil are good) HM oil, or if the problem is serious, try a can of stop leak additive. If you do decide to use an oil additive, use one made by a real good engine oil company, like Liqui Moly, not some back street snake oil mixers.
Re: 2005 honda accord [Re: dslofti] #4113224 06/02/16 09:45 AM
W
wolfehunter Offline
W
Check your PCV. If it was never replaced I would replace it with an OEM.
11 GMC Sierra 1500 100K
06 Toyota Sequoia 74K
07 Honda Accord 207K
70 Chevelle SS 112K
Re: 2005 honda accord [Re: dslofti] #4113257 06/02/16 10:26 AM
T
tmus2122 Offline
T
My 2007 Accord that has 280,000 miles and started to use a little oil too. I tried some Restore and it help a lot, almost no usage now, of course I switched to 5w30 non-sys oil too.
http://www.amazon.com/Restore-00009-4-Cy...=restore+engine
16 Honda Accord(new)Valvoline 0w20
07 Honda Accord >292,000 RK:5w30
06 Honda ST1300 >102,000 VPB:15w40
2000 Chevy Silverado 6.0 >140,000 RK:5w30
Re: 2005 honda accord [Re: dslofti] #4113286 06/02/16 10:59 AM
B
bigt61 Offline
B
I'd run MaxLife Blend 5W-30 - that will give you the best results from a usage standpoint. Give it two OCIs to work.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
