Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
Low VI gear oils
by dparm - 01/25/20 05:28 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
27 registered members (Bookmaker, bachman, blufeb95, brages, bbhero, BlakeB, 4 invisible), 921 guests, and 23 spiders.
Topics300,571
Posts5,178,490
Members70,527
Who uses Fram 7317 instead of 6607? #4112749 06/01/16 06:45 PM
N
NormanBuntz Offline OP
N
I want to use a Fram Pro Synthetic 7317 filter on my Infiniti M35, instead of the 6607 it calls for. Then I can also use the same filter for my Honda and Subaru.
The gasket ID and OD is only .048 inches less on the 7317 than on the 6607. Bypass pressure ratings are the same, and the 7317 is only .85 inches longer. Knowing my filter mounting base plate should accommodate it, I can't foresee any problem.
Anyone else use the 7317 on any Nissans and Infinitis?
Firesign Theater: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 11K, 2nd owner
2007 Honda Ridgeline RTS, 96K, 1st owner
2007 Infiniti M35, 115K, 1st owner
Re: Who uses Fram 7317 instead of 6607? [Re: NormanBuntz] #4112752 06/01/16 06:47 PM
B
bbhero Online Content
Online Content
B
Yes sir I have one on now. No problems at all. Good to go in my opinion.
Nissan Altima 3.5 Coupe
Cam2 full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Who uses Fram 7317 instead of 6607? [Re: NormanBuntz] #4112760 06/01/16 06:51 PM
Y
yvon_la Offline
Y
Super tech st 6607 version 2016 for the win (white)
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
Re: Who uses Fram 7317 instead of 6607? [Re: NormanBuntz] #4112834 06/01/16 08:31 PM
E
edwardh1 Offline
E
yes on a 99 I30 but it calls for that filter
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Who uses Fram 7317 instead of 6607? [Re: yvon_la] #4112838 06/01/16 08:34 PM
slacktide_bitog Offline
Almost everybody does smile
ST9688 for the win smile
Re: Who uses Fram 7317 instead of 6607? [Re: slacktide_bitog] #4112883 06/01/16 09:09 PM
B
Online Content
B
The 7317 and 6607 has a diameter of 2.69 ... so does the st 9688 diameter of 3.02 cause a issue at all??
Re: Who uses Fram 7317 instead of 6607? [Re: bbhero] #4112918 06/01/16 09:43 PM
dkryan Offline
+1
2014 Nissan Altima 2.5 SL
Valvoline M-E 5w-30/Fram Ultra
2005 Toyota Highlander 3.3L
QSUD 5w-30/Fram Ultra
2019 Subaru Outback 2.5L Limited
Idemitsu Zeepro 0w-20/Wix XP
Re: Who uses Fram 7317 instead of 6607? [Re: slacktide_bitog] #4112948 06/01/16 10:24 PM
Y
yvon_la Offline
Y
Question :is the. St9688 like the 7317 or the 6607 ?(2016 edition .is it with a combo valve or classic team style with valve deep. In the center tube
Truck driver
Re: Who uses Fram 7317 instead of 6607? [Re: NormanBuntz] #4112963 06/01/16 10:49 PM
T
TeddyVelvet Offline
T
I actually have a Honda 15400-PLM-A02 (rebranded TG7317) on my father's G35. No clearance or bypass issues so far!
2003 Acura 3.2TL
2003 Acura RSX Type S
2005 Kia Sedona EX
Re: Who uses Fram 7317 instead of 6607? [Re: NormanBuntz] #4113098 06/02/16 07:27 AM
Sayjac Offline
Quote:
I actually have a Honda 15400-PLM-A02 (rebranded TG7317) on my father's G35....
Similar construction, both use silicone adbv and fiber endcaps. Rated, tested efficiency not so much. TG rated ~99%@20um, A02 ISO tested ~66%@20um. Note, that info given just as a point of information not a recommendation.
As for the question, when my son owned his G37 he ran the 7317/14610 size instead of the spec 6607/14612, no issues. In my observation, for no apparent reason Nissan frequently specs the shorty 6607/14612 where 7317/14610 will easily fit. Same specs, just a longer filter and more media area.
Run the 7317.
Re: Who uses Fram 7317 instead of 6607? [Re: NormanBuntz] #4113205 06/02/16 09:21 AM
K
K20FA5 Offline
K
I run the TG7317 on my Frontier, it calls for the 6607 in the filter book. It's just easier, since the Hondas I work on also call for the 7317. I can keep one part in "stock" that way.
I'm not sure why Fram calls for the smaller filter??? The OEM filter and Wix, Purolator, etc, are all the 7317 size???
Mine-2018 Chevy Silverado LT Z71 5.3L-M1 AFE 0W-20 / Wix WL10255
Wife-2017 Volvo XC90 T6 Inscription Polestar 2.0L twin charged-Liqui Moly Special Tech V 0W-20 / OEM filter
Re: Who uses Fram 7317 instead of 6607? [Re: K20FA5] #4113211 06/02/16 09:31 AM
Sayjac Offline
Originally Posted By: K20FA5
...I'm not sure why Fram calls for the smaller filter??? The OEM filter and Wix, Purolator, etc, are all the 7317 size???
That is curious. Looks like the 2.5L Frontier specs the shorty, but as noted 4.0L the 7317/14610/57356. Though it won't hurt to run the shorty, thinking Fram needs to update the 4.0L.
