Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
138 registered members (AandPDan, 4WD, 750IX, A310, 67ZL1, 11 invisible), 2,417 guests, and 25 spiders.
Topics300,410
Posts5,175,151
Members70,497
Brake Pads White Paper #4112671 06/01/16 04:46 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Brake Pads White Paper [Re: MolaKule] #4112692 06/01/16 05:33 PM
B
bbhero Offline
B
Well I have questions about this. One is that I have Akebono Performance street brakes pads on my front brakes of my Altima. They have a GG friction rating which means they have a higher coefficient of friction at both hot and cool temps. So are the pads semi metallic or ceramic? I believe they are actually ceramic pads. Also, I be read that the pads rated GG very rarely get overheated or fade. Just seems to run contrary to what this paper states. I'm going to check about these pads and see IF they are ceramic.
Yep these Akebono Street performance brakes are advertised as ceramic brake pads. I just verified that from AAP. So, maybe they are actually a mix of both and that they aren't truly all ceramic or is it they are all ceramic?? Makes me wonder. And aren't GG rated brake pads have a higher coefficient of friction than say EE or FF?? I'm just curious now. Because those letters represent cold and hot performance.
Nissan Altima 3.5 Coupe
Cam2 full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Brake Pads White Paper [Re: MolaKule] #4112705 06/01/16 05:53 PM
B
BigD1 Offline
B
Yes GG is higher on cold and hot than FF, EE, and etc. For my daily drivers, FF is pretty dang good, and is considered a premium brake.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: Brake Pads White Paper [Re: BigD1] #4112721 06/01/16 06:13 PM
B
bbhero Offline
B
Well if GG rated brakes have a higher coefficient of friction than wouldn't they stop a vehicle say 10-20 feet shorter going from 70 mph to a dead stop? And that could easily be the difference between hitting a car in front of you or not making contact at all. The Akebono Street performance brakes were $72 for a front set. Really only $25 more than the FF rated AAP ceramics. Not much more at the end of the day if you think about it.
Re: Brake Pads White Paper [Re: MolaKule] #4113016 06/02/16 03:41 AM
dlundblad Offline
All this time I thought semi metallic created the most dust.
My Jeep has been suffering from excessive front brake dust ever since I put the mid grade Oreilly pads on back in 2011. I know it isnt my caliper slide pins because both calipers are fairly new.
I can't wait to put my Akebono ProACTs on. (Rock Auto clearance - $25 per axle)
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Brake Pads White Paper [Re: bbhero] #4113025 06/02/16 04:27 AM
M
mjoekingz28 Offline
M
Correct! Maybe prices will be low enough where some can buy what they want and not just get whatever has the lowest initial cost in the bottom line on the bill of laden.
Costs are upside down to some. They seemingly will drive across thecounty to save a nickel per gallon on gasoline.
Bite when cold and bite when warm are important to consider. Bite when hot is probably not since the streets do not resemble the superspeedways.
Low dust, environmental smells and breathing the asbestos into our lungs are other factors to look into.
Re: Brake Pads White Paper [Re: bbhero] #4113284 06/02/16 10:57 AM
J
Jetronic Offline
J
No, the limit is always tyre traction. What you get is more ABS action with higher friction rating.
But all the guys buying the highest friction rating brakes use 80,000 mile tyres...
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: Brake Pads White Paper [Re: Jetronic] #4113529 06/02/16 04:12 PM
H
HighViscosity Offline
H
Originally Posted By: Jetronic
[quote=bbhero]
LOL LOL LOL Thats a great observation, and is very true. Another BITOG pearl of wisdom pops into existence.
I said Dance! shoot...................... happy
These are the good old days!
Re: Brake Pads White Paper [Re: Jetronic] #4115466 06/04/16 10:34 PM
B
bbhero Offline
B
So the coefficient of friction does not matter at all?? The tire part is understood and granted. I will definitely say this with zero hesitation... my car brakes WAY better with these GG rated brakes when going from 105 mph down to 50 mph than the prior brakes. No judder. Smooth as can be. I also find i can drive into corners a far amount farther with these brake pads as well.
Re: Brake Pads White Paper [Re: MolaKule] #4115498 06/05/16 01:04 AM
Colt45ws Offline
Its more a thing after repeated stops when it starts fading. But, a single panic stop is going to hit the limit of the tires first.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Brake Pads White Paper [Re: Colt45ws] #4115871 06/05/16 01:38 PM
B
bbhero Offline
B
Well yeah that's understandable and valid no doubt. I know that's why it's rated at cool and hot temps. All things being equal does the higher coefficient really matter in cold stops? It would seem to be that if tires are properly inflated, have good traction, not raining cats and dogs.... does it make a difference with the higher rating when cold? It just would make zero sense if it didn't matter at all. Then why bother with the first part of the rating? Why bother even mentioning the higher coefficient numbers if it doesn't matter whether it be cool at all?
It used to be in NASCAR races at Martinsville, Richmond and Riverside that brakes were a real issue. Furthermore, if someone had a better brake package they could drive deeper into the turn and out brake their competitors and make a pass. The best the brakes were at the beginning of the day. Whoever had the "best" brakes at the end of the day had a good chance to win. So, this would have been demonstrating the cool/hot function of the brakes. The better brakes I would surmise have had a higher coefficient of friction in both temperatures. Aka giving better stopping power or ability to drive with more speed into a turn. Whether it be cool or very hot.
Re: Brake Pads White Paper [Re: MolaKule] #4116766 06/06/16 11:04 AM
J
Jetronic Offline
J
It matters in the amount of effort you have to put on the brake pedal.
Now if your car has a tendency to trigger the ABS on the rear axle first, you could fit a higher friction rating at the front, or a lower rating at the rear and end up with better performing brakes.
But with repeated heavy braking (like racing) you're likely to go way beyond the hot spec as seen on roadgoing pads, and it then comes down to the useable temperature range. Even Nascar cars have enough brake power to lock those slicks up any time they want...
