Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Chevron Delo XLE 15W-40 CK4 (semi synthetic)
by HDoilDude - 01/23/20 08:45 PM
Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
3 American Volunteers lost in Oz fires....
by Shannow - 01/23/20 02:13 PM
Need a tire pressure gauge
by nomas - 01/23/20 02:11 PM
Why Waffle Sipes - but very little depth
by Cressida - 01/23/20 02:05 PM
Perseus, AJEwing, Mailman1995, DougCFL, Sayafi
70514 Registered Users
42 registered members (adams355, Antiquity, 10WSmuckers, AZjeff, A310, 4WD, 2 invisible), 1,898 guests, and 23 spiders.
Topics300,480
Posts5,176,839
Members70,514
Pinion Leak - Leave it / Fix it? #4112158 06/01/16 07:30 AM
Y
Yota Offline OP
Y
I recently bought a 2004 Dakota. The previous owner replaced all fluids before my purchase. I have a slight drip in the rear pinion. 1 or 2 dime size drips over night. I think it is slightly overfilled and not sure what weight was used. (calls for 140w). Question that I can find an answer to that maybe somebody has experience with...Will the leak occur during driving or when sitting?? I have to take the truck on a 500 mile trip and am not sure if more oil will leak when moving or when sitting still? Also...I have read bad stories of folks replacing the seal only to make matters worse. Leave it?
'13 Avalon 55k
'05 Corolla 156k
'03 Matrix 165k
'16 Pilot 76k
"00 Saturn 100K
Re: Pinion Leak - Leave it / Fix it? [Re: Yota] #4112170 06/01/16 07:38 AM
B
bubbatime Offline
B
That's a big leak. It will also most likely sling oil while driving, so you are losing oil at a rapid pace. It needs fixed unless you want to burn up the rear axle.
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Pinion Leak - Leave it / Fix it? [Re: Yota] #4112173 06/01/16 07:42 AM
53' Stude Offline
at my work and on my jeep I would fix it
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Pinion Leak - Leave it / Fix it? [Re: 53' Stude] #4112185 06/01/16 07:55 AM
69GTX Offline
I'd monitor the level after a specific mileage to ensure it remains nothing more than a drip. My wife took in our '98 Z28 back around 2005 and 90K miles for a small drip on the rear pinion similar to yours. They convinced her to have it addressed. It ended up costing over $1,000 which was insane. I'm pretty sure that leak could have been monitored. It would have made more sense to sell the car than pay that kind of bill.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Pinion Leak - Leave it / Fix it? [Re: Yota] #4112188 06/01/16 07:59 AM
R
Rand Offline
R
It doesn't hold that much oil a few ounces a month would be catastrophic shortly unless topped up.
Re: Pinion Leak - Leave it / Fix it? [Re: Yota] #4112216 06/01/16 08:21 AM
B
BrocLuno Offline
B
Low probability, but could be the vent is clogged... If so it'll push out fluid as it warms. Then drip off as it sits. Check vent. If vent OK, you gotta put a seal in it ...
Re: Pinion Leak - Leave it / Fix it? [Re: BrocLuno] #4112290 06/01/16 09:42 AM
T
turtlevette Offline
T
Try stop leak first. If the pinion nut doesn't end up in the same exact spot, the crush sleeve will crush further if too tight or be too loose and the pinion depth will be off causing an improper mesh pattern.
Both my vette and ta leak and i'm reluctant to change the seals.
Re: Pinion Leak - Leave it / Fix it? [Re: Yota] #4112301 06/01/16 09:48 AM
O
OneEyeJack Offline
O
Over filled?
Re: Pinion Leak - Leave it / Fix it? [Re: BrocLuno] #4112368 06/01/16 11:02 AM
01rangerxl Offline
Vents are always a good thing to check first on a diff with signs of leakage. It seems like on half of the older trucks where I pay attention to it, it's either clogged or the tube is broken.
I would repair a drip to the ground personally. That's a sizable amount for a differential to be losing.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: Pinion Leak - Leave it / Fix it? [Re: Yota] #4112389 06/01/16 11:25 AM
Srt20 Offline
Pinion leaks are common on dodges. Improper pinion nuts, pinion nut torque, etc is all a problem on dodge trucks. There is recalls on it for the fullsize trucks. Might want to check into it for the Dakotas.
Re: Pinion Leak - Leave it / Fix it? [Re: Srt20] #4112455 06/01/16 12:36 PM
Y
Yota Offline OP
Y
Thanks all for your insight and taking a few minutes to respond! Not being much of a mechanic - I have learned quite a bit reading your posts from all'yall.
'13 Avalon 55k
'05 Corolla 156k
'03 Matrix 165k
'16 Pilot 76k
"00 Saturn 100K
Re: Pinion Leak - Leave it / Fix it? [Re: turtlevette] #4112907 06/01/16 09:27 PM
clinebarger Offline
Incorrect, Crush Sleeve & Pinion Bearing preload does not effect Pinion Depth., Sure...You get it way loose & the Pinion can move forward & cause issues, Too tight will burn the Pinion Bearings up.
Check for play in the Pinion Bearings, Measure the Pinion Nut Depth with a Dial Caliper before removing the Nut, Tighten .002" deeper after seal replacement.
2001 Chevy Camaro L92/4L80E
Re: Pinion Leak - Leave it / Fix it? [Re: Yota] #4113861 06/03/16 03:39 AM
L
Lubener Offline
L
I would leave it for now and monitor the level. I regretted having a small pinion leak repaired under warranty long ago and have had a gear whine ever since. The dealer kept saying that's normal.
The "thinking" man's friend.
Re: Pinion Leak - Leave it / Fix it? [Re: Yota] #4114886 06/04/16 08:24 AM
O
oldhp Offline
O
Mark the pinion nut in relation to the yoke. Mark the yoke to pinion spline location. Change the seal. Install yoke back to same spline alignment. Clean the threads, use a couple drops of red Loctite. Tighten pinion nut to same mark plus 1/4" of a inch extra. Changed a lot of pinion seals, never had a problem.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Pinion Leak - Leave it / Fix it? [Re: Yota] #4114938 06/04/16 09:31 AM
W
WyrTwister Offline
W
First , I would check to see if it is over filled . If not , top it off with what ever gear oil the manufacturer calls for .
Then monitor it .
I inherited a 1991 Chevy Caprice 5.0l automatic . Around 46,000 original miles . It developed a pinion seal leak , just setting still .
Went to O'Reilly auto parts for a seal . They listed 2 & I bought both . Jacked up the car & put it on jack stands . Dropped the drive shaft & pulled the yoke . Removed the old seal and installed the seal ( of the 2 ) that fit . Filled the diff back up with dino gear lube .
Been good so far . Took the other seal back for credit .
So , I recommend you replace the seal if it is leaking very much .
God bless
Wyr
Wyr
God bless
