Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
101 registered members (77GrandPrix, 4WD, aleneros, 2003f7, 2010Civic, 8 invisible), 2,429 guests, and 39 spiders.
Topics300,411
Posts5,175,220
Members70,497
Rislone or stp ethanol fuel treatment #4111493 05/31/16 02:17 PM
I
Indiana79 Offline OP
I
I'm just curious if anyone has any feedback on rislone ethanol treatment or stp ethanol gas treatment. They both seam to be new products. I seen them for sale on ebay and I may buy some to try out but first I wanted to see if anyone used either.
Re: Rislone or stp ethanol fuel treatment [Re: Indiana79] #4111582 05/31/16 03:52 PM
Donald Offline
I will stick with Techron.
2015 Ford F-250 w/Powerstroke
Re: Rislone or stp ethanol fuel treatment [Re: Indiana79] #4111636 05/31/16 04:46 PM
splinter Offline
What conditions, issues and/or symptoms are you attempting to 'treat' with these types of treatments?
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Past performance is no guarantee of future results.
Re: Rislone or stp ethanol fuel treatment [Re: splinter] #4111850 05/31/16 09:24 PM
I
I
Well I'm trying to solve the issue of fuel going bad in my small equipment that sits for months at a time. I have tried startron and stabil and still had clogged up carbs.
Re: Rislone or stp ethanol fuel treatment [Re: Indiana79] #4112217 06/01/16 08:21 AM
J
John_Conrad Online Content
Online Content
J
Iv'e had good luck using stabil for about 20 years or so and my storage time is usually about 6 months.
You could give PRI fuel stabilizer a try, link below or you might just completely drain the fuel out of the small equipment.
I have not personally tried the PRI, but I would if I had a need for longer storage times.
https://www.amazon.com/PRI-Fuel-Stabiliz...ywords=pri+fuel
P.S.
When you add the stabil, do you allow for a good mix with the fuel and run the small engines so that the additive is well distributed through out the fuel line, carburetor and etc?
Safety doesn't happen by accident.--author unknown
Re: Rislone or stp ethanol fuel treatment [Re: John_Conrad] #4113680 06/02/16 08:07 PM
I
I
Well I usually add the stabil to my empty gas can before I fill it up that way it goes in everything. I even use a little more than what's recommended. My issue is the equiptment I let up at my cabin in the shed. It goes from oct- June with out being used most of the time.
Re: Rislone or stp ethanol fuel treatment [Re: Indiana79] #4113933 06/03/16 06:24 AM
demarpaint Offline
I used to do that. Now what I do is buy gas, and tape a note on a cabinet in my garage with the date I bought the gas on. Every 3 months I add whatever gas was left in the gas can to one of the tanks on my van. Then I refill the gas can with fresh gas and update the note. At the end of the season I add fresh gas with stable and MMO to the OPE, I run the engine to get it warmed up, fog it, and change the oil. That method seems to be working well.
God Bless Our Troops
Re: Rislone or stp ethanol fuel treatment [Re: Indiana79] #4115402 06/04/16 08:20 PM
I
I
John I may try the pri g you recommended or the crc phase 4 stabilizer I read about online I do appreciate the recommendation. I try to only buy my gas from busy stations anymore to see if that helps. At my house I began starting my equipment more often in the off season but at my cabin I don't get up there enough to do that. I really thought startron was the answer but I guess not. I emailed startron to complain but never received a reply from them.
Re: Rislone or stp ethanol fuel treatment [Re: Indiana79] #4116807 06/06/16 11:40 AM
J
Online Content
J
i am no expert, in fact I came here to learn,
but i did research the ingredients in pri and was impressed with what their sds sheet stated. i also researched those ingredients and found that they are supposed to do what the bottle says it does. so I feel it's worth a try.
any more and to what degree than that and mr. mola or other chemists would need to help.
any chance to get gasoline that is E0 in or about your area?
Re: Rislone or stp ethanol fuel treatment [Re: Indiana79] #4117100 06/06/16 04:24 PM
I
I
The closest e0 station is about 25 miles away. I will give the pri g a try. I wish they would come out with little Diesel engines on stuff like snowblowers and lawn mowers we we wouldn't have as many problems but I'm sure they would have there drawbacks too.
Re: Rislone or stp ethanol fuel treatment [Re: Indiana79] #4117798 06/07/16 01:53 PM
J
Online Content
J
best of luck and please post back with your experience on the pri g, it seems like it should do the trick if you don't want to drain fuel and or are able to rotate the ethanol fuel a little more often to keep it from breaking down.
