Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
70 registered members (Astro_Guy, 2009Edge, Astro14, 94astro, 2013ecof150, 53' Stude, 8 invisible), 1,290 guests, and 16 spiders.
Topics301,818
Posts5,203,236
Members70,784
Oil Change Frequency - 04 Neon #4111218 05/31/16 08:15 AM
R
racer12306 Offline OP
R
I started driving my Neon daily again back in October when I changed positions that took away a company car. (used to do field work, now in office) I'm currently putting a quart every 1000-1500 miles, which I think is generally "in spec" but it is quite excessive in my opinion.
Feb 2004 - Jan 2008, drove daily to work, college, etc. Battled a little bit of oil consumption early, but I can't really remember how much but I don't remember adding a significant amount. Put about 87000-90000 miles on it during this period. Always synthetic oil, generally Pennzoil Platinum or QSUD.
Jan 2008 - Oct 2015, periodic use, would only start it if I could get it warmed up nicely, even if it meant I had to drive it extra to get it hot. Put probably 12000-15000 miles on it during this period. Still PP or QSUD.
Oct 2015 - present, as mentioned daily use, already put 15000 miles on it since then. Used M1 0w40 (was an experiment to see if the engine would be "happier") with high consumption. Currently using PUP 5w20 (went with 5w20 because the 2005 was spec'd for 5w20 with no engine differences) with the same consumption. I do need to try 5w30 just to rule out it being an oil weight issue, although I don't suspect it is.
Currently has 118,000 miles
Current drive is 4% neighborhood/local, 7% rural hwy and 89% interstate and is 55 miles each way.
Couple questions:
1. Any tricks to try to reduce this consumption? I'm not pulling the engine apart.
2. Assuming I have to keep putting this quantity of oil, I will be switching to SuperTech Conventional, but then the question is, how often to change the oil? Assuming that I am replenishing the oil with a fresh quart every 1000-1500 miles, the sump is quasi changed every 5000-7500 miles. Is it reasonable to change the filter every 7500-10000 miles and maybe dump the sump at that interval as well?
Additional thoughts?
16 Ford Focus/2.0/6A
04 Dodge Neon SXT/2.0/MTX
17 Chrysler Pacifica/3.6/9A
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111223 05/31/16 08:35 AM
J
JC1 Offline
J
I would try a high milage oil like maxlife to see if that helps a bit. I think I'd start out with 5w-30.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111224 05/31/16 08:36 AM
T
TeddyVelvet Offline
T
If that were my Neon, I'd find a friend with a Sam's Club membership and buy the 12 quart boxes of Certified oil at 10W-30 or whatever's available. In my experience with notorious oil burners, no oil can truly fix a burning issue. High mileage oils can maybe sometimes slow it down a little, but not to any long term appreciable degree. Barring any emotional attachment to the Neon, I'd buy cheap and run it to the ground!
2003 Acura 3.2TL
2003 Acura RSX Type S
2005 Kia Sedona EX
Re: Oil Change Frequency - 04 Neon [Re: TeddyVelvet] #4111248 05/31/16 09:05 AM
R
R
I've never been a huge believe in the HM oils, but I could give a couple changes a try to see what happens.
Pretty much the plan. Only car I have an emotional attachment with is a former 85 Monte Carlo SS, I'd buy it back tomorrow if given the opportunity.
What's impressive is, while it's using so much oil, it certainly hasn't affected fuel economy. Regularly getting 34-35 MPG.
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111310 05/31/16 10:14 AM
9
901Memphis Offline
9
Yes if you're consumption oil and replenishing it the intervals can be extended
2012 Chevy Cruze LT 1.4T - 69k - M1HM 5w30 + Fram Ultra
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111369 05/31/16 11:38 AM
N
Noey Offline
N
Just a quick q...is it burning oil or is it leaking it?
"I don't know nothin' 'bout birthin' babies!"
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111381 05/31/16 11:49 AM
M
Miller88 Offline
M
It'd a Dodge neon. Top it up, change the filter and change the filter on a regular basis. When it hits the 30,000 mile blown headgasket interval, then change the oil!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Oil Change Frequency - 04 Neon [Re: Miller88] #4111390 05/31/16 12:06 PM
R
R
There may be some minor seepage from the pan gasket, but certainly not this much. Nothing on the driveway either.
Good ol Neon joke.
OEM headgasket, still going strong at 118000 miles.
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111396 05/31/16 12:16 PM
9
901Memphis Offline
9
I have had good results with ATP 205 re seal with leaky gaskets on my very high mileage Altima. It's worth a shot if you don't have success with Maxlife which I agree with trying. You could use them together but if it solves your problem you won't know which item fixed it.
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111405 05/31/16 12:32 PM
R
R
Is there a point to ATP 205 when it doesn't really leak? The seepage around the pan is hardly anything, just a wet seal, no other evidence of oil anywhere.
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111421 05/31/16 12:52 PM
P
Powerglide Offline
P
Replace the PCV valve too.
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111428 05/31/16 01:00 PM
R
R
Brand new PCV valve less than 5000 miles ago.
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111575 05/31/16 03:46 PM
B
bullwinkle Offline
B
MaxLife synthetic is a good choice, if you want to stay synthetic, or just get Defy or any old HM & dump it in there! Hopefully it doesn't take out your catalytic converter.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Oil Change Frequency - 04 Neon [Re: racer12306] #4111576 05/31/16 03:47 PM
B
Branson304 Offline
B
Step up a viscosity grade with Pennzoil High Mileage & see what happens. Perhaps a 10W-40. If that doesn't slow it down & you're still adding a fresh quart every 1K-1.5K, I wouldn't dump the sump until at least 10,000 miles & use the cheapest oil you can get. I don't see a need to change the oil if you've technically replenished the entire sump over a normal oil change interval.
Re: Oil Change Frequency - 04 Neon [Re: Branson304] #4112097 06/01/16 06:07 AM
R
R
The car didn't seem to happy with 0w40 in it over last winter, so I'd be wary about giong with 10w40. Definitely want to stick with a xw30.
Picked up a jug of Maxlife Blend last night for the next change. We'll see what happens.
