Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
93 registered members (Avery4, ArrestMeRedZ, Astro14, Alfred_B, avi1777, 8 invisible), 1,970 guests, and 18 spiders.
Topics301,600
Posts5,198,916
Members70,737
snapper blade control is stiff #4110869 05/30/16 07:44 PM
E
edwardh1 Offline OP
E
21 inch self propelled snapper, bought from a neighbor, mower is 3 years old, not used a lot,, on one of the cable operated items the "blade control" is stiff. this is the bail that your hand pulls up to the handle, and stops the blade.
where do you lube it? I have started spraying lube down the tube sheath, no big changes yet - I sprayed some at the edge of the assembly next to the cowling- where is it most likely to need lube?
Is there a diagram anywhere?
thanks
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: snapper blade control is stiff [Re: edwardh1] #4110884 05/30/16 07:53 PM
K
Kuato Offline
K
You can disassemble the entire cable, pulling the center steel out of the sheath; it's likely just a bit rusted/corroded. Motor oil has worked for me in the past, both lubing up the cable and getting some oil into the sheath before reinserting the cable. You could also use grease, but the oil trick always worked for me.
Just be careful if the end is frayed though, you will have trouble getting it back in/through and may have to cut the entire thing a little shorter, if you have the slack.
Thick vs Thin test: 15k / 43k miles complete
Re: snapper blade control is stiff [Re: edwardh1] #4111005 05/30/16 10:22 PM
M
Merkava_4 Offline
M
TRI-FLOW DRY.
Lube both ends of the cable where it enters the sheath.
Re: snapper blade control is stiff [Re: edwardh1] #4111045 05/31/16 12:17 AM
B
bubbatime Offline
B
The return spring on the engine is likely the culprit. Some are pretty stiff. Lubricate the lever on the engine that moves.
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: snapper blade control is stiff [Re: edwardh1] #4111154 05/31/16 06:38 AM
O
Oldmoparguy1 Offline
O
I've used ATF, my all purpose light oil lube.
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: snapper blade control is stiff [Re: edwardh1] #4111156 05/31/16 06:39 AM
O
O
opps
