P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
52 registered members (bullwinkle, 2015_PSD, alchargo, BobsArmory, bmod305, blufeb95, 6 invisible), 1,090 guests, and 19 spiders.
Topics300,572
Posts5,178,518
Members70,527
Replacing Drywall In The Bathroom (Insulation) #4110828 05/30/16 06:56 PM
W
Warstud Offline OP
W
Was in the process of removing the wallpaper in the bathroom when I noticed some blackish stuff coming thru the drywall which I assume is mold. So I decided just to tear it all out and put up some mold resistant drywall. Should I put some insulation and vapour barrier on the inside walls to.... while I"m at it?
Re: Replacing Drywall In The Bathroom (Insulation) [Re: Warstud] #4110834 05/30/16 07:03 PM
RTexasF Offline
Yes, without question. I used to do it for a living. You will need to remove every trace of mold or it will eventually return.
Re: Replacing Drywall In The Bathroom (Insulation) [Re: Warstud] #4110925 05/30/16 08:26 PM
spasm3 Online Happy
Online Happy
I would check any plumbing for leaks.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Replacing Drywall In The Bathroom (Insulation) [Re: Warstud] #4110932 05/30/16 08:31 PM
B
barkingspider Offline
B
Check plumbing for leaks, fix them, remove old insulation, completely dry out the framing and inside the wall, install new insulation, install green board type drywall, finish it and you are good to go.
04 Avalanche Z71 4x4
Re: Replacing Drywall In The Bathroom (Insulation) [Re: Warstud] #4110958 05/30/16 09:11 PM
R
Rolla07 Offline
R
I would have someone test the air before and after the work is done to make sure you arent breathing in higher than normal mold spores.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Replacing Drywall In The Bathroom (Insulation) [Re: Warstud] #4111137 05/31/16 06:14 AM
O
Oldmoparguy1 Offline
O
Opening up the wall was the right thing to do. You must identify the source of the moisture and apply the proper fix. Then let it dry thoroughly and kill the mold. My favorite cleanup is 50/50 bleach/water and spray the whole area down, then let that dry. I always use green board in a bathroom, but it depends on the circumstances.
I currently have a 4'X5' hole in the hallway wall where a shower control failed in the master bath. Found the issue while dealing with another issue. because of the location of the repairs, regular wallboard will be fine.
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: Replacing Drywall In The Bathroom (Insulation) [Re: Oldmoparguy1] #4111680 05/31/16 05:33 PM
W
Warstud Offline OP
W
It doesn't surprise me there's mold .The house was built in 1960 and never had a Ceiling Exhaust Fan.
Re: Replacing Drywall In The Bathroom (Insulation) [Re: Warstud] #4112310 06/01/16 09:59 AM
stockrex Offline
Baths are high moisture rooms, and without a vent fan the outside wall will have condensation inside the wall and mold.
1. Install a vent fan
2. use mold resistant dry wall
3. use good insulation on outside walls, make sure you put it behind the pipes and don't compress the insulation, add more on top of piles if need, feel free to use rigid insulation per code.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Replacing Drywall In The Bathroom (Insulation) [Re: Warstud] #4112615 06/01/16 03:22 PM
T
Thermo1223 Offline
T
Roxul or Rockwool, I will never use fiberglass again.
Does not mold or wick up water like fiberglass does. That with greenboard and you are home free.
2016 VW Tiguan
2013 Ford Fiesta
