Fuchs Titan ATF 6400
by Chuckh - 02/27/20 12:52 PM
2018 Ram 2500 with 21k miles. Delo 400 XSP 5w40
by bigbadbowtie - 02/27/20 11:08 AM
For those always asking about tiny Computers
by jayjr1105 - 02/27/20 11:05 AM
Original 2016 VW Passat cabin filter
by Vaca - 02/27/20 11:02 AM
Original 2016 VW Passat air filter
by Vaca - 02/27/20 10:54 AM
Napa Exceptional Customer Service
by Fitz98 - 02/27/20 10:38 AM
Astra 400 ?
by WyrTwister - 02/27/20 09:58 AM
Will thinner oil damage anything when it is burned?
by Fordiesel69 - 02/27/20 09:38 AM
Old news for Hyundai/Kia?
by Farnsworth - 02/27/20 09:33 AM
Looking for AA 25% off coupon code.
by JustChuck - 02/27/20 09:17 AM
New to the LS460 and The World Of Lexus. Questions!
by gr8gatzby - 02/27/20 08:41 AM
New old guy back.
by BJD2020 - 02/27/20 07:45 AM
Help me Decide
by Gebo - 02/27/20 07:36 AM
FWD - Death traps with miss matched tires.
by Fordiesel69 - 02/27/20 07:13 AM
Napa Gold Sale
by Toto - 02/27/20 06:52 AM
2016 or 17 Honda CR-V
by Loogie - 02/27/20 05:20 AM
RIP Clive Cussler
by PimTac - 02/27/20 04:48 AM
Pirelli Cinturato P7 Allseason PLUS "II"
by Char Baby - 02/27/20 03:31 AM
CCI clean .22 ammo - polymer coated HV
by Shannow - 02/27/20 03:23 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
113 registered members (2015_PSD, 1978elcamino, AndyB, ArrestMeRedZ, ARCOgraphite, Amenhotep, 8 invisible), 2,138 guests, and 18 spiders.
Topics301,990
Posts5,206,957
Members70,808
Spark such way? #4110712 05/30/16 04:48 PM
Y
yvon_la Offline OP
Y
Does a spark on spark plug go from head to sparkplug center core?would adding a ground on the head prevent spark?
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
Re: Spark such way? [Re: yvon_la] #4110717 05/30/16 04:58 PM
skyactiv Offline
Grounding the top of the spark plug will shut the spark off. Some old power equipment engines had a eyelet type spark plug wire and you'd flip over a piece of metal that would ground the spark plug, shutting the engine off.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Spark such way? [Re: yvon_la] #4110730 05/30/16 05:19 PM
MolaKule Offline
Global Moderator
Global Moderator
Assuming the polarity of the head is true negative potential (and wire and tip is positive potential), yes, since electron current flow is from negative to positive.
Head bolts should provide a good ground from head to block.
Just curious, are you getting spark noise in your radio?
I'm a Student Pilot. Frightening, isn't it?
Re: Spark such way? [Re: yvon_la] #4110732 05/30/16 05:20 PM
CT8 Offline
The Whole engine is the ground .If the engine was isolated from the negative in the ignition circuit there wouldn't be a spark.
2015 F150 2.7
2018 F350 6.2
Re: Spark such way? [Re: yvon_la] #4110738 05/30/16 05:26 PM
E
eljefino Offline
E
The "head" as you mention it sounds like the "side electrode" as many would consider it.
Traditionally, spark goes down the center tip, jumps the gap, and is grounded by the electrode/ head and "used up".
The first generation distributorless ignition systems sent the spark down the center electrode, jumped to the electrode, went through the shell and cylinder head to another shell, electrode, jumped another gap before it was "finished". The ignition coils' +/- were positive and negative compared to the rest of the vehicles' common ground.
Adding a ground to the tip would screw up the spark, for sure.
Plugs can short themselves out with carbon tracking on the insulator nose within-- carbon is a pretty good conductor and just has to be better than the air gap. This can also happen externally if your coil wire boots break down-- once electricity finds a path, it gravitates toward it again.
Re: Spark such way? [Re: yvon_la] #4110847 05/30/16 07:18 PM
Chris142 Online Content
Online Content
My Jeep fires 3 plugs one way and the other 3 plugs the other way
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Spark such way? [Re: yvon_la] #4110955 05/30/16 09:06 PM
J
JimPghPA Offline
J
It does not matter what direction the spark jumps. In other words, it does not matter what the polarity is. And the spark could even be AC.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Spark such way? [Re: yvon_la] #4110987 05/30/16 09:58 PM
J
JimPghPA Offline
J
The head is already grounded by the bolts that hold it to the block. Somewhere there is a ground wire (negative) from the battery to the engine (at the block, or the head, or some bracket on the motor). Adding a ground on the head would have no effect.
JimPghPa
Re: Spark such way? [Re: yvon_la] #4111222 05/31/16 08:27 AM
Y
yvon_la Offline OP
Y
Ok ty guys, as for :the head is already grounded via bolt !it depend if it's the part you want to ground is iron or aluminium. In most case the part made of aluminium is not properly grounded.
Truck driver
Re: Spark such way? [Re: yvon_la] #4111403 05/31/16 12:30 PM
J
JimPghPA Offline
J
Aluminum is a good conductor, and even if the head were made of aluminum, it would still be grounded to the block by the head bolts.
If you wanted the head to not be grounded it would require plastic head gaskets, plastic head bolts, and a plastic or rubber valve assembly and no one would try to build such a motor because it simply would not hold up to the stresses a motor has to handle.
JimPghPa
Re: Spark such way? [Re: yvon_la] #4111478 05/31/16 02:02 PM
P
PandaBear Offline
P
The high voltage low current flow that the plug uses should go though the engine (head), the coil (or distributor's coil), the wires (or just the coil on plug itself), and the plugs, that's it. The low voltage high current input from the battery that gets converted to high voltage low current would go from battery, fuse box, and a bunch of cables.
Unless your existing wire is corroded, adding additional engine grounding wouldn't do anything.
p.s. Ground can have different meaning depends on how you look at things. On a waste spark the ground could be just the engine block / head, and the non "ground" electrodes of the spark plugs that connects to the coil pack could be labeled "positive" and "negative", etc. Ground is just a name given to a reference point in a system of "flow", like electrical current.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Spark such way? [Re: Chris142] #4111488 05/31/16 02:12 PM
MolaKule Offline
Global Moderator
Global Moderator
A Bi-Polar Jeep? smile
Re: Spark such way? [Re: yvon_la] #4111712 05/31/16 06:06 PM
E
eljefino Offline
E
Whatever increased resistance is between the spark plugs threads and aluminum pales to the resistance in the plug's internal resistor and the plug wires. This doesn't really matter at 30K volts and milliamps.
