Cracklins/pork skins anyone?
by 53' Stude - 01/26/20 01:55 PM
RIP Kobe Bryant
by sloinker - 01/26/20 01:54 PM
Re-purposing an old iPad
by KrisZ - 01/26/20 01:10 PM
Put my dog down
by dja4260 - 01/26/20 01:09 PM
Oil choices for 240Z race car
by michaelsvintage - 01/26/20 12:54 PM
About Ballistol
by MGF1964 - 01/26/20 12:44 PM
Pop Quiz!
by Mad_Hatter - 01/26/20 12:41 PM
Tire Pressure Gauge
by Smoky14 - 01/26/20 12:06 PM
Castrol Gold Jug
by JohnnyJohnson - 01/26/20 11:22 AM
Honda/Multi-Vehicle ATF Comparison Chart
by jayjr1105 - 01/26/20 11:06 AM
4runner oil level.
by laserred96gt - 01/26/20 10:17 AM
Redline SL1 and Diesel Engines
by BigJohn - 01/26/20 09:53 AM
2011 Silverado red or orange dex cool?
by Corollaman - 01/26/20 08:39 AM
The Worst Muscle Cars Made. The Pinto was a M.C.?
by atikovi - 01/26/20 07:57 AM
2012 Ford Escape Transfer Case
by radtech91 - 01/26/20 07:49 AM
P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
duppyman, MBDon, Socioil, kwashabcp, ronster
70530 Registered Users
100 registered members (53' Stude, 77GrandPrix, 911Don, aba4430, aircooled, 7 invisible), 2,348 guests, and 16 spiders.
Topics300,590
Posts5,178,854
Members70,530
Larger Oil Filter for 2006 Highlander 2.4 Four Cyl #4110527 05/30/16 12:01 PM
Samzone Offline OP
I'm new to Toyota Land, and I'm wondering what is the larger oil filter that matches up to the gasket size of the small motorcycle-sized filter now specified. I'm wishing to use the largest Pure One filter that fits on this car.
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4110541 05/30/16 12:17 PM
T
TeddyVelvet Offline
T
I'll be that guy to say that there's no need to worry about smaller oil filters because they'll still likely have filtering capability even after manufacturer's recommended service interval. If you decide to do your own homework, be sure to pay attention to the bypass rating of the larger filter and match it to the specs of the OEM or recommended ones.
2003 Acura 3.2TL
2003 Acura RSX Type S
2005 Kia Sedona EX
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4110581 05/30/16 01:17 PM
H
HerrStig Offline
H
The filter you want in Purolator is the PL 14477 which is also the 4 cyl Camry filter after 2001. It's a bit taller. Toyota made it an OEM part for 4 cylinder Camrys back to the 90s.
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4110583 05/30/16 01:18 PM
J
JMJNet Offline
J
For Toyota, a lot of us are using PH3600 size filter.
There are a lot of them available like Fram Ultraguard XG3600, Mobil M1-209, Napa Platinum 41516, etc. This is a taller filter but diameter is close to the stock filter and the gasket is about 1 mm larger than stock filter but fit the base nicely.
I have used this size ever since I know about it in my current Sienna and sold Camrys.
There is one that is bigger diameter but it is too big at least on my 2004 Sienna.
  • 2017 Toyota Sienna
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4110721 05/30/16 05:04 PM
T
tojo1968 Offline
T
LOL
No offense...But
Why do you think you think need a bigger filter?
Do you know something that the Toyota engineers and designers (Ya know, founded in 1937 and is the 13th largest company in the world) don't know?
My son's Sentra 2.0 I4 uses a filter almost the same size as my Frontier's 4.0 V6 and I lose no sleep.
Sometimes...cough cough...bigger isn't better! LOL
2016 Frontier SL Crew Cab
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4110734 05/30/16 05:22 PM
MolaKule Offline
Global Moderator
Global Moderator
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4110747 05/30/16 05:34 PM
F
Fsharp Offline
F
If it calls for a ph3600 or ph3614 size filter, a ph8a filter will fit the threads and base and is huge.
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: tojo1968] #4110765 05/30/16 05:53 PM
A
artificialist Offline
A
LOL
No offense...But
The V8 in the Nissan Titan also uses a Purolator 14610 or 14612 or equivalent. I was sure that with all the moving parts a DOHC V8 has, that it would make a larger filter a necessity.
Anyway, a Fram 3600 or equivalent will fit. When my mother had a car that used that filter(2005 Jeep Grand Cherokee 3.7), I would buy a Motorcraft FL400.
2010 Lancer Ralliart Sportback
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4110793 05/30/16 06:17 PM
CELICA_XX Offline
If you have the space and the filter is located in a convenient location... I think the 3600 is a good size. I am using it in many of my Toyota vehicles.
I believe your particular filter on the 2.4L is located at an angle and I am not 100% sure you have the space for the 3600.
The PH8A is most likely too big for the engine compartment of many 4-cyl Toyota products.
15 Toyota Prius - M1 EP 0w20 SN+
06 Acura MDX - M1 EP HM 5w30 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - M1 EP HM 5w30 SN+
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4110968 05/30/16 09:24 PM
B
BrocLuno Offline
B
Any meaningful increase in media surface area reduces the pressure drop across the media, allows more entrapment area; and with larger container increases total oil capacity.
Some oversized filter are only a slight increase, say another cup full. That's not much. But I regularly run 2 qt spin-ons and that is a significant increase in a 4 qt system that originally called for shorty filter. So it depends on how big an "Oversize" you can fit...
The 3600 series is what I have to run on my Saab as I could only go longer, not bigger around. But sometimes it's the opposite. It all depends on the space around it ...
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4111056 05/31/16 01:10 AM
G
Garak Offline
G
I don't generally jump up and down that one should oversize, but I have done so on occasion. A good resource would be the Hastings and Baldwin sites. They actually list upsize (and smaller) filters for a given part number. To me, that's much preferable than cross referencing to a cross reference, and so forth.
Plain, simple Garak.
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4111191 05/31/16 07:34 AM
G
goodtimes Offline
G
Some filters are big on the outside and have less media because they waste a lot of space in the length and make the center tube huge to save on media. The only way to tell is spend a few bucks and cut some new filters open to compare media. The Toyota brand smaller filter probably has more media than many of the larger sizes from other makers.
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4111321 05/31/16 10:26 AM
O
Oro_O Offline
O
After a lot of study, this is basically what I do. The PureOne offers a lot of performance and quality for the money. There are basically three ways to get a PureOne - Bosch Premium, PureOne, and Motorcraft "S" series. Because Toyota was clever about ditching metric for their oil filter stud and going 3/4-16, you have huge options.
A few ideas:
1) First, I'd just go up to the V6 filter size that Toyota specs for many 3.0 to 4.0L applications, and is also used on smaller V8s from many makers. This is equivalent to the "3614" (Fram) size: MC FL-910S, Bosch 3330, PL10241. Should fit no problem on your car.
2) Next size is the "3600" size. These are typically used on larger V8s and "oversize" of our V6 car and what I have often used: MC FL-400S, Bosch 3422, PL20195. This may be too large but you can check.
3) trying to go any larger than this is probably not going to have clearance at the dome end.
4) Be aware, there have been experiences lately of the MC line of filters leaking down. I'm not sure of your engine's filter mounting, but A LOT of Toyota's have the filter base-down and the MC ones are not always handling it. Here's my experience, and in it are links to threads from others with the same experience with the 910s and 400s.
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4078731/Motorcraft_FL-400s_that_leaked
I stocked up on some CQ Premium "blues" on sale for her car and will use them a year or two. Byt then hopefully this issue will get fixed, then I'll go back to MC filters on the Lexus.
Re: Larger Oil Filter for 2006 Highlander 2.4 Four Cyl [Re: Samzone] #4111628 05/31/16 04:39 PM
Samzone Offline OP
Thanks folks! The FL400S fits and is now my new filter. Very available and cheap!
