Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
130 registered members (77GrandPrix, 4WD, 2010Civic, 53' Stude, 15 invisible), 2,617 guests, and 29 spiders.
Topics300,411
Posts5,175,197
Members70,497
Wrong Dipstick? Honda Accord 2.4 Reading Low #4110358 05/30/16 08:09 AM
T
ThirdeYe Offline OP
T
Hey everyone,
One of my friends brought his 2007 Accord 2.4 over yesterday and I offered to do an oil change on it for him. I looked in the owners manual and it stated 4.4 quarts for the 4 cylinder model, with filter. I added 4.5 and we checked the level 3 times on 2 different flat surfaces, and it only showed that the oil level was just up to the bottom hole (one quart low). We added one extra half quart to get it up between the lines, thus having put in a full 5 quarts when it should've only been 4.4. Has anyone else ever experienced this? He bought the car used, so could it be that someone else swapped the dipstick for some reason? Or is it common in these cars to have inaccurate readings? I've never experienced this before.
07 Honda Accord - 622k - Supertech 5W-20/Purolator PureOne PL14610
98 Camaro Z28 (Bright Purple Metallic, 1 of 104) - 127k - Mobil 1 HM 5W-30/Fram Pro Synthetic XG3506
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110375 05/30/16 08:24 AM
N
NormanBuntz Offline
N
Honda is never wrong on its capacities. He should buy a new dipstick from a Honda dealer.
Firesign Theater: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 10K, 2nd owner
2007 Honda Ridgeline RTS, 96K, 1st owner
2007 Infiniti M35, 115K, 1st owner
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110380 05/30/16 08:27 AM
Donald Online Content
Online Content
Things could have changed after the owners manual was written. Its possible but not likely somehow the wrong dipstick got in the vehicle.
Drive it to a Honda dealer and see if the parts person has a new one in stock. If its different then buy the new dipstick.
2015 Ford F-250 w/Powerstroke
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110381 05/30/16 08:29 AM
O
OneEyeJack Offline
O
I had to replace the dipstick on my 84 Civic because the disk that located the position, depth wise on the dipstick came loose.
The closest one to correct reads low so I just remarked it after an oil change.
This made me wonder if this kind of dipstick failure could cause problems. If the disc comes lose the dipstick will slide down and indicate a full condition when the oil very low and an overfull condition when the oil is at the correct level.
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110388 05/30/16 08:38 AM
G
gregk24 Online Content
Online Content
G
I can tell you that my 2006 Accord 2.4 took a full 5 quarts to get to the full line.
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110436 05/30/16 09:36 AM
Z
zfasts03 Online Content
Online Content
Z
My 2007 Accord 2.4 takes a full 5 quarts also.
Draining on level ground it takes about 4.6 or so.
Check out the shape of the bottom of the oil pan, draining on a level surface actually will let less oil drain out.
Having the front up in the air; like having it up on ramps will drain more oil. Depending on the angle of your driveway and the height of your ramps, I could imagine it taking a smidgen over 5.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110443 05/30/16 09:54 AM
dan_erickson Offline
Very well could be the angle of the car when the oil was drained. My transmission will take exactly 3 quarts on a drain and refill if the front end is lifted up and a little more fluid if the car is raised level.
My Grand Prix seems to take a full 5 quarts if the front end is raised up for an oil change when it only calls for 4.5 quarts.
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: dan_erickson] #4110549 05/30/16 12:29 PM
F
ffhdriver Offline
F
Another possibility. I had a '01 Buick that read low with the OM correct quantity. The problem was that GM had mid year changed from a steel to an aluminum oil pan and the oil required increased by a pint. OM was wrong.
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110551 05/30/16 12:31 PM
T
TeddyVelvet Offline
T
For K series engines, I found that five quarts is the magic number for an oil change with a fresh A02/7317/110-sized filter.
2003 Acura 3.2TL
2003 Acura RSX Type S
2005 Kia Sedona EX
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110564 05/30/16 12:53 PM
N
NormanBuntz Offline
N
Lots of anecdotes here. The only way to be sure is to ask the Honda dealer parts guy for a replacement dipstick, and physically compare it to your friend's dipstick.
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110570 05/30/16 01:01 PM
R
Rand Online Content
Online Content
R
Page 268
http://techinfo.honda.com/rjanisis/pubs/OM/AC0707/AC0707OM.pdf
You just got more to drain than level? was car on ramps?
total capacity is 5.6qts
I'd add a quart to full mark and be done.
Re: Wrong Dipstick? Honda Accord 2.4 Reading Low [Re: ThirdeYe] #4110928 05/30/16 08:27 PM
T
ThirdeYe Offline OP
T
The oil was changed on ramps. Just like ive done every single other oil change ive ever done.
I appreciate others mentioning how much these engines tend to take in their experience as well.
