Shutting Down Threads Because of "Speculation"
by e55amgbenz007 - 02/18/20 10:10 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
107 registered members (94astro, 14Accent, 28oz, Aichiguy, 14 invisible), 2,029 guests, and 19 spiders.
Topics301,604
Posts5,198,941
Members70,737
Page 1 of 3 1 2 3
Water decarbonization, does it work? #4110167 05/30/16 12:56 AM
F
FordCapriDriver Offline OP
F
title says it all, thinking of doing it on my Capri and seeing if it runs better or something, slowly squirting water into the carb
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Repsol Elite Super 20W-50
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110172 05/30/16 01:20 AM
DoubleWasp Offline
Any reason to suspect you have coking going on?
I've done it before, and if you spend time with it, it does work. Little bit at a time will do fine. Use a spray bottle.
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110173 05/30/16 01:24 AM
Marco620 Offline
Use a cheap .99 squirt gun and get somebody to man gas peddle. Driving in 100 % humidity works too if its humid enough.
15' Civic 1.8 i-vtec 310,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110175 05/30/16 01:25 AM
F
F
Well i've been doing a lot of driving inside town lately with quite a bit of idling and when i pulled the plugs out the other day they were pretty dark, even though the carb is 1 year old and i've got it set up pretty well, all the ignition components are also only about 6 months old.
And yes i will use a spray bottle and next month when the temperatures start going up to about 30 to 35c ( 90 or sop F ) i will do it, and yes that's a good idea since i live on an island and it can get up to 80 or 85% on cloudy summer days
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110180 05/30/16 01:52 AM
A
asand1 Offline
A
I would use a garden sprayer to spray a fine mist. Even better would be methanol washer fluid sprayed while under load. I have often thought about buying a wrecking yard washer bottle/pump and irrigation misting nozzle to do a hard install for cleaning/antiknock.
2004 GMC Yukon SLuT
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110183 05/30/16 02:16 AM
F
F
My spray bottle sprays quite a fine mist, and actually what i've seen eric the car guy to is just pour water from a cup right into the engine!
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110208 05/30/16 04:02 AM
Ducked Offline
Worked for me.
I used an IV line into one of the many vacuum hoses, and an intermittent "tap" at idle (which MAY have been pre-ignition) went away, and the car stopped "dieseling" run-on when switched off.
A spray would probably be better though.
Pouring from a cup is asking for a bent con rod.
To state the obvious, you need distilled, deionised water, or at the least, soft water.
Scottish tap water would probably be OK but its far too hard (probably artesian) here.
I used air conditioning condensate, which in the summer is available in huge quantities for free.
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110227 05/30/16 04:58 AM
O
Olas Offline
O
It works but you have to remember to go for a long drive afterwards, or even better change your oil & filter.
I like to use a football needle jammed into the end of a suitable sized vacuum line to restrict the amount of water being ingested.
Cable ties should hold it
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110248 05/30/16 05:32 AM
Donald Online Content
Online Content
I would use Techron fuel additive as per its directions. Its designed for the purpose you mention.
Have you shoved a endoscope down the spark plug holes or pulled a head to know you have carbon deposits?
2015 Ford F-250 w/Powerstroke
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110250 05/30/16 05:37 AM
F
F
No i haven't used an endoscope , bit i am going todo change the oil anyway this summer so i will do ir and then change the oil
Re: Water decarbonization, does it work? [Re: Marco620] #4110257 05/30/16 05:52 AM
H
horse123 Offline
H
If driving in 100% humidity removed carbon then nobody who lives anywhere where it ever rains would have carbon in their engine.
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110276 05/30/16 06:24 AM
R
Robenstein Offline
R
Oh it sure does work. Ever see a cylinder where there was a cracked head or gasket leaking coolant into it?
I have done it on my old small block Chevy. I adjusted he idle screw on the carb so it was idling about 1500 rpm and just misted it through the old rochester carb. If the engine starts to bog like it wants to die....stop and let it recover.
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110309 05/30/16 07:01 AM
T
Trav Offline
T
Your car may be a perfect candidate for a bubbler setup. I don't buy the MPG improvement but I can see the benefit of having moist air going into the engine.
Ideally you would use a ported vacuum source with an inline temperature operated switch. I messed around with one years ago on a old car and it did clean the combustion chambers of all carbon.
Keep in mind while excess carbon is a bad thing a little carbon on the piston heads is a good thing, it helps protect the piston. If you like to tinker this will give you some idea on how to build one.
http://journeytoforever.org/biofuel_library/ethanol_motherearth/me3.html
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110327 05/30/16 07:24 AM
F
F
I'm not really interested in buying fancy cleaning products
Re: Water decarbonization, does it work? [Re: FordCapriDriver] #4110329 05/30/16 07:28 AM
T
Trav Offline
T
Cost to make is a couple of bucks.
Page 1 of 3 1 2 3
