Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
22 registered members (bismic1, Bailes1992, dogememe, earlyre, hpb, harry j, 2 invisible), 644 guests, and 21 spiders.
Topics300,304
Posts5,172,822
Members70,467
Most Online3,728
Jan 11th, 2020
Difference between silicone caulking ? #4109935 05/29/16 05:15 PM
M
Merkava_4 Offline OP
M
GE Kitchen and Bathroom Clear
GE Window and Door Clear
What's the difference ? They're both 100% silicone and they're both clear.
I know you guys will know; you guys know everything. smile2
Re: Difference between silicone caulking ? [Re: Merkava_4] #4109937 05/29/16 05:17 PM
simple_gifts Offline
Don't those fitness girls on youtube you've been watching also know about silicone?
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Difference between silicone caulking ? [Re: Merkava_4] #4109951 05/29/16 05:39 PM
J
JayhawkRoy Offline
J
Kitchen and Bath have an increased amount of mold and mildew inhibitors (7 yr mold guarantee). It is also not recommended for exterior use.
Re: Difference between silicone caulking ? [Re: JayhawkRoy] #4109960 05/29/16 05:50 PM
Bandito440 Offline
The GE rep explained to me that it's in the additives. The interior has additional mildew protection. The exterior protects against UV.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Difference between silicone caulking ? [Re: Merkava_4] #4110038 05/29/16 07:23 PM
E
eljefino Offline
E
Re: Difference between silicone caulking ? [Re: Bandito440] #4110063 05/29/16 08:15 PM
M
M
So that means there's not enough room in the chemical equation for BOTH mildew and UV protection. laugh
Re: Difference between silicone caulking ? [Re: Merkava_4] #4110101 05/29/16 09:21 PM
B
BHopkins Offline
B
It means that if they made one product that was good enough for both outdoor and kitchen & bath, you would only buy one tube from them. By making two products, they can get you to buy both. assimilate
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350 M276 - M1 European 0W-40 & Purflux filter
Re: Difference between silicone caulking ? [Re: Bandito440] #4110109 05/29/16 09:37 PM
demarpaint Offline
That's about it. Don't ever plan on painting over it unless it specifically states it can be painted over. Paint will crawl off of it, fish-eye, flake and peel.
God Bless Our Troops
Re: Difference between silicone caulking ? [Re: Merkava_4] #4110111 05/29/16 09:39 PM
R
Reddy45 Offline
R
Do you plan to paint over either? Since it is silicone it won't stick.
I've had better luck using the following:
Interiors: DAP Alex Plus
Exteriors vertical: OSI Quad
Exterior floors: Sikaflex SL
Re: Difference between silicone caulking ? [Re: Reddy45] #4110114 05/29/16 09:47 PM
M
M
I plan on using it at the bottom of the bathroom vanity where it meets the toe-kick. There's a gap there between the two and the bugs from underneath the house are coming up through there. I'm too embarrassed to tell you what kind of bugs they are. I got duct tape on there temporarily.
Re: Difference between silicone caulking ? [Re: Merkava_4] #4110116 05/29/16 09:56 PM
T
turtlevette Offline
T
There is also an architectural grade. I used it to put my windshield in.
Re: Difference between silicone caulking ? [Re: Merkava_4] #4110142 05/29/16 10:29 PM
Nick1994 Offline
Merk, you might want to pull up the vanity and seal around under there too. Even if you seal the, from coming out, they could build a nest underneath and crawl around under there, vanitys are hollow underneath.
2015 Hyundai Genesis 5.0L 55k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: Difference between silicone caulking ? [Re: Merkava_4] #4110213 05/30/16 04:31 AM
demarpaint Offline
It will work fine for that. As long as you don't have to paint it, it will be fine.
Re: Difference between silicone caulking ? [Re: Merkava_4] #4110262 05/30/16 06:01 AM
P
Pop_Rivit Offline
P
That's a bigger problem than any sort of caulking will fix. Do it right and get rid of the infestation in the first place. Since you have an infestation it tells you that something is seriously wrong; bugs don't live where they don't have food and water.
Re: Difference between silicone caulking ? [Re: Merkava_4] #4116289 06/05/16 08:37 PM
E
earlyre Online Sleepy
Online Sleepy
E
My uncle is sales rep for various plumbing and hardware lines, and GE Silicone caulking is one of his lines.
I asked him about this today.
The main Difference, besides the mold/mildew inhibitors, is the Kitchen and Bath has less odor.
He also said the Difference between GE and the other brands is that the GE is still "100% Virgin Silicone", while the others have god knows what added in.
Mine:
13 Ford C-MAX hybrid: Havoline syn 5w20,& Napa Gold 1348
