Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
23 registered members (Black_Thunder, bbhero, AndyB, adams355, Bailes1992, 2 invisible), 1,617 guests, and 29 spiders.
Topics300,415
Posts5,175,292
Members70,497
High SAPS & DPF Re-Gen #4109824 05/29/16 01:50 PM
U
userfriendly Offline OP
U
Do high saps engine oils trigger dpf re-gens more often than low saps engine oils?
Would a dpf equipped engine need to consume oil before saps become an issue?
Re: High SAPS & DPF Re-Gen [Re: userfriendly] #4109859 05/29/16 02:45 PM
P
Pontual Offline
P
If I recall it right. Some hard ashes from high saps potentially attaches to don't get burned pretty good in a regen, leaving hard residoes that pile up and decrease efficiency of the system. They areharder to burnout, as compared to the trapped soot targeted to the system.
Re: High SAPS & DPF Re-Gen [Re: userfriendly] #4109877 05/29/16 03:14 PM
Bandito440 Offline
Pontual has the right answer, as always.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: High SAPS & DPF Re-Gen [Re: userfriendly] #4109885 05/29/16 03:29 PM
CT8 Offline
What signals the regen?
2015 F150 2.7
2018 F350 6.2
Re: High SAPS & DPF Re-Gen [Re: userfriendly] #4109891 05/29/16 03:54 PM
K
Kamele0N Online Sick
Online Sick
K
If you have engine with DPF system...then full saps engine oil is a big NO NO!
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: High SAPS & DPF Re-Gen [Re: CT8] #4109892 05/29/16 03:55 PM
Bandito440 Offline
I believe there's a back pressure sensor that triggers regen at a certain threshold.
Re: High SAPS & DPF Re-Gen [Re: CT8] #4109963 05/29/16 05:55 PM
2015_PSD Offline
In Ford Powerstrokes and I assume others as well, it is the percent loading of soot in the DPF that triggers it.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: High SAPS & DPF Re-Gen [Re: userfriendly] #4110079 05/29/16 08:50 PM
claluja Offline
Are all oils that meet CJ-4 (such as T6) considered low SAPs?
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: High SAPS & DPF Re-Gen [Re: claluja] #4110082 05/29/16 08:54 PM
E
edyvw Offline
E
No, it depends for what application.
T6 would be considered almost Full SAPS for my BMW.
So, use what your manual says. But I would go with lowest available SAPS oil that your truck(or car) can use it.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: High SAPS & DPF Re-Gen [Re: claluja] #4110084 05/29/16 08:57 PM
G
Garak Offline
G
No, as far as HDEOs go, they are considered mid-SAPS, at least by ACEA standards.
Plain, simple Garak.
Re: High SAPS & DPF Re-Gen [Re: Garak] #4110086 05/29/16 09:01 PM
E
edyvw Offline
E
Yeah, T6 is Mid-SAPS by ACEA standards for that application.
However, it would not be able to meet C3 standard (personal vehicles).
Re: High SAPS & DPF Re-Gen [Re: userfriendly] #4110098 05/29/16 09:17 PM
U
U
I consider CJ-4 engine oils low saps as it applies to domestic Diesel trucks compared to the previous CI-4+ API classification.
Garak, I found an old Mobil product booklet from 2005 that listed Esso branded engine oils. All the XD-3s were 1.49 %/wt SA, TBN 12.
Now the SA is <1.0 in CJ-4, the old CI-4s had 1300p and close to 1500Z.
I had a dozen liters of CH-4 left in 0w30 and tried that in my LML Dmax for 6 months last winter.
The level never changed on the dipstick over 10K km, but it seemed to always be in regen mode.
Maybe the engine "sees" the additive package and ash is going into the exhaust without changing the oil level.
Re: High SAPS & DPF Re-Gen [Re: userfriendly] #4110100 05/29/16 09:20 PM
E
edyvw Offline
E
Do not forget evaporation loss.
DPF will go into regen. mode more often in city driving and using higher SAPS oils.
Try Valvoline 5W40 MST. Has SA level of .76
Re: High SAPS & DPF Re-Gen [Re: userfriendly] #4110107 05/29/16 09:35 PM
U
U
Thanks edyvw;
I save the synthetics for winter, my short winter trip is 80km/day. I hate using a HD truck for grocery getting duties.
The oil gets changed 3x a year; April, July and November.
My April and July engine oil is $4.00/L CF-2 low ash SAE40, M1 303s (?) off the top of my head.
There are so many good 0w40 & 5w40 CJ-4s now, I just might watch for a sale and pick whatever is the cheapest.
Re: High SAPS & DPF Re-Gen [Re: edyvw] #4110127 05/29/16 10:05 PM
G
Garak Offline
G
Originally Posted By: edyvw
Yeah, T6 is Mid-SAPS by ACEA standards for that application. However, it would not be able to meet C3 standard (personal vehicles).
Yes, definitely not the same.
userfriendly: Well, I guess it depends how you compare them, with the legacy stuff still falling under the full-SAPS category. E6 stuff, like Delvac 1 LE 5w-30 and the Delo LE 5w-30 and the Castrol equivalent are considered low-SAPS by the ACEA descriptions. SA is much the same, but sulphur and phosphorus are cut. The E9 designation is for mid-SAPS, whereas the E7 can cover older and newer additive levels, since the maximums are much higher. Delvac 1 ESP 5w-40 is E7, E9, being mid-SAPS, yet still having the enhanced TBN of E7.
