Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
98 registered members (angeloc, A310, amblerman, alphadog, 69GTX, 8 invisible), 2,176 guests, and 32 spiders.
Topics300,413
Posts5,175,239
Members70,497
Import Multi-Vehicle, Valvoline vs. Castrol, VI? #4109734 05/29/16 11:36 AM
Samzone Offline OP
I'm trying to decide between Castrol or Valvoline import multi to use in my 2006 Highlander with Aisin 3309/T-IV transmission. I used the Castrol in my Honda Element for 100K miles with zero problems. However, I noticed that the viscosity index for the Castrol is 200, where the Valvoline, a synthetic fluid, is closer to 150. This seems like a huge difference for two products that are essentially the same price. The question I have is, what is better in an ATF, higher or lower VI rating? For reference, the original Mobil 3309 fluid has a VI around 185.
Re: Import Multi-Vehicle, Valvoline vs. Castrol, VI? [Re: Samzone] #4109740 05/29/16 11:41 AM
SatinSilver Offline
I'd go with the Castrol. It's closer to the viscosity of the oem fluid.
Re: Import Multi-Vehicle, Valvoline vs. Castrol, VI? [Re: Samzone] #4109741 05/29/16 11:42 AM
slacktide_bitog Online Content
Online Content
welcome
My choice would be Maxlife
Re: Import Multi-Vehicle, Valvoline vs. Castrol, VI? [Re: Samzone] #4109762 05/29/16 12:17 PM
M
michaelluscher Offline
M
I put Castrol IMV in my Camry's U151E
Biggest mistake ever
It slipped, flared, banged into gear,and just didn't behave like it should've
I think that 6 month 5k time it was in there took some time off its lifespan
I bit the bullet and ordered the case of Mobil 3309 off Amazon, and the second it went in, it worked perfectly
2006 Toyota Camry SE V6
131k
Re: Import Multi-Vehicle, Valvoline vs. Castrol, VI? [Re: Samzone] #4109817 05/29/16 01:38 PM
53' Stude Offline
MaxLife is what's in my 11' Focus
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Import Multi-Vehicle, Valvoline vs. Castrol, VI? [Re: Samzone] #4109860 05/29/16 02:46 PM
P
pbm Online Content
Online Content
P
I D&R'd the ATF in my s-I-l's 2004 Corolla with Castrol IMV @ approx. 140K. She wasn't sure if that was the original fluid but the IMV ran great and still looked cherry red when drained again 40K later. I recommend it in Toyota's that spec. 3309.
Maxlife has ran great in my daughter's Elantra that spec's SPIII.
'Journalism is Dead'
Re: Import Multi-Vehicle, Valvoline vs. Castrol, VI? [Re: Samzone] #4109938 05/29/16 05:17 PM
Samzone Offline OP
In looking at the Valvoline IMV and the Maxlife, I noticed that the Brookfield Viscosity (?) is quite different, IMV is 18000 and Maxlife is 10200. If Brookfield Viscosity means anything, then this is a significant difference, especially since these are both synthetic fluids from the same company. Any thoughts?
