Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Chevron Delo XLE 15W-40 CK4 (semi synthetic)
by HDoilDude - 01/23/20 08:45 PM
Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
3 American Volunteers lost in Oz fires....
by Shannow - 01/23/20 02:13 PM
Need a tire pressure gauge
by nomas - 01/23/20 02:11 PM
Why Waffle Sipes - but very little depth
by Cressida - 01/23/20 02:05 PM
Perseus, AJEwing, Mailman1995, DougCFL, Sayafi
70514 Registered Users
63 registered members (4WD, Black_Thunder, aleneros, Aero540T, bdcardinal, adams355, 4 invisible), 1,238 guests, and 37 spiders.
Topics300,480
Posts5,176,836
Members70,514
Car won't star after new serpentine belt #4109577 05/29/16 08:06 AM
A
AlaninPA Offline OP
A
Hi all, new to forum, hoping I would get some much needed answers.
The car is a 2004 Acura MDX with 110K miles.
First time driving it yesterday after a month. Car won't start up. Finally after some throttle, the car starts up. Today, the car starts up fine but when I was backing out of the driveway, I noticed the steering is gone and so are the brakes.
I look under the hood and noticed that the serpentine belt snapped. I think it's the original one so not too surprised.
I then went to NAPA and got the right belt, installed it but was not successful when I tried to start the car. There is no crank and all when I turn the ignition. Lights light up but no ignition.
Took the new belt off and tried again to see what the problem was. When I crank it this time, the engine fires right up.
So to summerize, with no serpentine belt, car is fine to start up (not drivable of course but it starts). With the new belt, I don't even get a crank...
Strange! Help?!
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109578 05/29/16 08:08 AM
Chris142 Offline
Check the battery cables.probly just a coincidence
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109581 05/29/16 08:12 AM
M
Moutainman31282 Offline
M
Check the ac compressor sounds like it could be locked up and won't let the engine turn over. If it's free check the p/s and alternator
2003 F150 5.4l 201,000 miles
1999 Toyota Corolla 245,00 miles
2001 F150 335,000 miles
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109583 05/29/16 08:13 AM
simple_gifts Offline
The other thing to check is make sure you jiggle the shifter in any no start situation, it might be the ignition lock out mechanism acting up.
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Car won't star after new serpentine belt [Re: simple_gifts] #4109591 05/29/16 08:17 AM
L
larryinnewyork Offline
L
Also check that the steering wheel is not in its Locked Position.
If it is, gently moved the steering wheel back-n-forth while turning the Ignition Key.
Re: Car won't star after new serpentine belt [Re: Moutainman31282] #4109592 05/29/16 08:18 AM
O
OVERKILL Offline
O
This. Sounds like you have some accessory or tensioner that has seized, which likely resulted in the breaking of the previous belt.
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109602 05/29/16 08:27 AM
A
AlaninPA Offline OP
A
Amazing responses guys. Each sounds like a good suggestion.
Here is a diagram of the pulleys http://www.mdxers.org/forums/attachments/maintenance/39774d1228782969-serpentine-belt-img06464.jpg
Everything except the crank pulley spins freely. I assume this is how it should be. When I crank without the belt, Only the crank pulley spins.
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109610 05/29/16 08:33 AM
O
OVERKILL Offline
O
Turn the key on, can you still turn the A/C Compressor pulley?
Re: Car won't star after new serpentine belt [Re: Moutainman31282] #4109617 05/29/16 08:41 AM
W
Warstud Offline
W
This^^^^
Something locked up and caused the belt to break.
Re: Car won't star after new serpentine belt [Re: OVERKILL] #4109629 05/29/16 08:50 AM
Drew99GT Offline
Yes! Perhaps the AC compressor is seized and when the ignition is on, it engages the clutch.
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109633 05/29/16 08:52 AM
K
KzMitch Offline
K
I'd try a different belt.
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109640 05/29/16 09:02 AM
J
JC1 Offline
J
Check the pulleys without the belt on to see if anything has a bad bearing. As mentioned by others check if anything is seized up.
Triple check to make sure you have the correct sized belt.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109643 05/29/16 09:05 AM
A
AlaninPA Offline OP
A
Ok guys. Might have a lead...
I can spin the AC, PS, Tensioner, and another smaller pulley.
The pulley I can't spin is the CS (normal) and alternator which leads me to think the alternator is bad?
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109646 05/29/16 09:05 AM
A
AlaninPA Offline OP
A
Belt is good. Same model as the one that snapped. Gates brand.
Re: Car won't star after new serpentine belt [Re: AlaninPA] #4109647 05/29/16 09:06 AM
O
OVERKILL Offline
O
Yes, there ya go, if you can't spin the alt, it has seized smile
