Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
80 registered members (55hambone, 4WD, 53' Stude, Aero540T, aba4430, 2010Civic, 6 invisible), 1,768 guests, and 20 spiders.
Topics301,818
Posts5,203,279
Members70,787
Page 1 of 3 1 2 3
Tire pressure question #4109488 05/29/16 06:18 AM
T
Tlhfirelion Offline OP
T
I had some new tires installed recently on a 2014 Toyota Camry and the sidewall said max pressure 51 PSI. I always re-check the tires and the Lugnuts within the hundred or so miles after having new tires put on any vehicle. I checked the tire pressure and all of these tires were set at 34 to 35 psi. I bumped that up to 41 PSI and it made me curious as to how close do you get to the max PSI number to get good performance from your tires without being unsafe so I figured I'd post this question and my favorite forum! Thank you in advance for any helpful feedback
Re: Tire pressure question [Re: Tlhfirelion] #4109492 05/29/16 06:30 AM
K
Kuato Offline
K
From my reading, ideal air pressure is where you get even wear; too low and the outside edges will wear, too high a pressure and the center of the tread will wear. But if you are taking a lot of corners, you may see rapid edge wear on the fronts; but that is taken care of through rotation.
I even read in one automotive magazine where a guy laid patches to insure his tires were correctly inflated, but look up the chalk test....
Thick vs Thin test: 15k / 43k miles complete
Re: Tire pressure question [Re: Tlhfirelion] #4109493 05/29/16 06:30 AM
H
HerrStig Offline
H
I'd use the manual as a guide. My 08 V6 Camry lists 30 PSI for V rated tires. I'm at 32 front 33 rear right now, down from 36, and the ride and handling are both good. In fact the closer I get to the manual rating the better it got. I may drop another pound at each end. 41 PSI will wear the center of your tires and in places like the frozen north, beat the suspension up on the lousy roads. The "max psi" number is put there by the tire company as a high speed, hot weather, and full load max ratings and has nothing to do with what the Toyota engineers have concluded is proper for regular use.
Re: Tire pressure question [Re: Tlhfirelion] #4109501 05/29/16 06:42 AM
rooflessVW Offline
Use whatever pressure is listed in the door jamb.
"Zed's dead baby, Zed's dead."
Re: Tire pressure question [Re: rooflessVW] #4109505 05/29/16 06:49 AM
dave123 Offline
+1
Re: Tire pressure question [Re: rooflessVW] #4109509 05/29/16 06:54 AM
N
NibbanaBanana Offline
N
+1
Correct pressure is on manufacturers sticker in the door jam. Don't over or under inflate.
1993 Ford E350 5.8L, 68K
2002 Ford E150 4.2L, 85K
2006 Chevy Aveo 1.6L 215K
2013 Kia Reo 1.4L, 101K
7500 OCI, M1 5-30 winter, M1 10-30 summer
Re: Tire pressure question [Re: Tlhfirelion] #4109514 05/29/16 06:58 AM
Donald Offline
What is on the sidewall is the MAX pressure. You should inflate to what the sticker on the door jamb says. Thats assuming you have not changed tire sizes.
2015 Ford F-250 w/Powerstroke
Re: Tire pressure question [Re: Tlhfirelion] #4109519 05/29/16 07:04 AM
O
OneEyeJack Offline
O
I ran the original Michelin Cross Terrain's that came on my 03 4Runner at 40psi and got just over 80K miles with very even wear. Then Michelin heard that I really liked those tires and they cancelled them so I could not get another set. Don't you just hate it when this happens with products you like?
Re: Tire pressure question [Re: Tlhfirelion] #4109520 05/29/16 07:05 AM
R
RF Overlord Offline
R
While I agree that the door sticker is good place to start, I don't agree that it is always the BEST pressure. Since the manufacturer has no way of knowing how a car is going to be used, sticker tire pressure is a compromise between ride quality, handling, and wear.
In personal experience, Ford specified 32 lbs F&R for the early build 2003 Mercury Marauder...it was quickly discovered that that number was too low, and they raised the door sticker to 35 lbs for the later builds.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - MC 5W-20 / FL820S
'00 Grand Marquis GS - being resurrected. Slowly.
Re: Tire pressure question [Re: Tlhfirelion] #4109527 05/29/16 07:10 AM
E
Eddie Offline
E
I set my tires overnight cold to the recommended pressure on the drivers door. This is the best compromise pressure with regard to safety, performance and longevity. If you deviate much you will get a trade-off. Ed
2014 CX5 Touring 2.5L :-)
Re: Tire pressure question [Re: Tlhfirelion] #4109541 05/29/16 07:23 AM
E
eljefino Offline
E
This comes up regularly and there's never an absolute consensus.
If you think about it, nothing catastrophic will happen between door jamb pressure and the sidewall max. But a blowout/ overheat etc would if it runs below jamb pressure.
I go a couple pounds over jamb pressure to account for local climate and cold snaps that could lower pressure. Plus air never leaks into a tire, so as I regularly check them, I would be dismayed to find it under the jamb pressure and simply annoyed to find it "down to" it.
Re: Tire pressure question [Re: rooflessVW] #4109548 05/29/16 07:33 AM
4
4wheeldog Offline
4
I would add, use no less than what is on the door jam, and up to 10% over.
Also, elevation makes a difference. My tire store is in town, 2000' lower. That is good for being about 2 PSI low, when I check at home.
Re: Tire pressure question [Re: 4wheeldog] #4109565 05/29/16 07:54 AM
Quattro Pete Offline
Actually, the measured tire PSI increases as you go up in elevation, but it's often offset by pressure decrease due to lower ambient temps at higher elevation, so it may be a wash.
Here is more info on this topic...
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=167
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Tire pressure question [Re: Tlhfirelion] #4109587 05/29/16 08:14 AM
K
KitaCam Offline
K
Different tires have different performance parameters and wear differently...I had what were really summer UHP tires (despite being labeled A/S) and wore perfectly evenly @ 44psi on the Camry spec'd for 29! Their max was 51psi.
The current Cooper CS5 UltraTouring (touring), max rated @ 44psi, are wearing evenly @ 32-34psi...
Should be noted that the Camry's OEM tires were 15"ers, and I'm now running 17" rims so that may account for the difference.
Kitacam is an 05 Camry LE/I4/MT; latest OC: 2/17 @ 142,300....PP 5w-30 with Toyo filter
Re: Tire pressure question [Re: KitaCam] #4109595 05/29/16 08:20 AM
O
OVERKILL Offline
O
Why would you run them at 44 if the placard specs 29? That seems a bit odd shrug
Page 1 of 3 1 2 3
