Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
28 registered members (Black_Thunder, bbhero, Bailes1992, CB22, 1WildPig, 4 invisible), 1,338 guests, and 25 spiders.
Topics300,415
Posts5,175,286
Members70,497
Small Engine Oil Pressure #4109264 05/28/16 08:06 PM
funflyer Offline OP
Thought I'd get an oil pressure baseline on the new 7000 series Kohler 22HP V=Twin before I test different oils and filters. Oil and filter are genuine Kohler, 10w-30 and 12-050-01S. Engine has 6.5 hours and had the oil/filter changed at 5 hours.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Small Engine Oil Pressure [Re: funflyer] #4109272 05/28/16 08:15 PM
T
tig1 Offline
T
I might be mistaken, but doesn't the pump only pump the oil through the filter, not the entire engine. Isn't the engine itself splash lubricated? I was told that about my 21HP Briggs on my riding mower.
2007 Ford Fusion 252,000 miles
M1 5-20HM
2017 Ford Fusion 85K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Small Engine Oil Pressure [Re: funflyer] #4109305 05/28/16 08:54 PM
N
Nate1979 Offline
N
Where did you install the pressure gauge?
2015 GMC Sierra 2500 6.0L
2010 Subaru Forester 2.5X
Re: Small Engine Oil Pressure [Re: Nate1979] #4109340 05/28/16 09:54 PM
funflyer Offline OP
Not sure.
Installed just above the filter. That's a cooler/heatsink over the filter in the pic.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Small Engine Oil Pressure [Re: funflyer] #4109352 05/28/16 10:07 PM
J
Justin251 Offline
J
Nice. I just got a new cub cadet xt1 with that same engine. So far loving it.
Coming up on an oil change very soon. Almost 5 hours. Got a Supertech filter and some chevron delo 10w30 for it. Though I suspect some regular pcmo 10w30 would be fine in conventional or synthetic.
2014 Ram 5.7 PUPPP 5w20 ultra
2015 Tuscon 2.4 PP 5w20 wix
1996 Ranger 4.0 SuperS 5w30 wix
1989 formula 5.0
Re: Small Engine Oil Pressure [Re: funflyer] #4109354 05/28/16 10:08 PM
T
The_Eric Offline
T
I don't have any pics but I installed a gauge on my Deere L110- it has around 30psi cold at idle, 35psi cold at operating RPM and it'll creep UP to 40psi hot at operating RPM.
Engine is a 17.5hp Kohler Command and oil is whatever leftover synthetic 5w-30 I have.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Small Engine Oil Pressure [Re: Justin251] #4109392 05/28/16 10:51 PM
funflyer Offline OP
Mine is an XT1 also. I was going to compare oil pressure between filters to see which is the least restrictive. I believe the gauge port is on the inlet side of the filter.
Does your engine have hydraulic lifters? That would explain the requirement for higher oil pressure.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Small Engine Oil Pressure [Re: funflyer] #4109395 05/28/16 10:56 PM
DSparks Offline
Big end of rod is pressure lubed through crank just like big engines with full pressure....not 100% sure on front\rear main bearings....actually bushings on kohlers....I have a 20hp command all torn apart I can get pics from.
Re: Small Engine Oil Pressure [Re: funflyer] #4109461 05/29/16 05:23 AM
dave123 Offline
Same series 7000 in my SCAG runs really strong kept OEM filter for first change plug check new RC12YC Champions went in OEM plugs looked great but one gap was way out of spec. Air Filtration will be the biggest key I think at least in the configuration that I have on the SCAG Zero Turn.
Re: Small Engine Oil Pressure [Re: DSparks] #4109585 05/29/16 08:13 AM
funflyer Offline OP
How about the top end? Rockers? I figure the engines with hydraulic lifters oil the top end through the pushrods but on the others ???
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Small Engine Oil Pressure [Re: funflyer] #4109604 05/29/16 08:28 AM
M
motor_oil_madman Offline
M
So now that we know how little oil pressure these engines make, is it a bad idea to use an oil filter with a high bypass valve pressure setting like 14psi?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Small Engine Oil Pressure [Re: motor_oil_madman] #4109979 05/29/16 06:15 PM
funflyer Offline OP
As long as you change the oil and filter as required I doubt there's a chance that the bypass valve would come into play regardless of the PSI setting.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Small Engine Oil Pressure [Re: funflyer] #4111746 05/31/16 06:45 PM
Slick17601 Offline
The Command series does have hydraulic lifers.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
