Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knockers
by user52165. 09/21/18 03:41 PM
Opinion needed....
by Duffyjr. 09/21/18 02:56 PM
2017 nissan sentra
by jahwarrior1423. 09/21/18 02:47 PM
I Need A Safe Space- lol
by Zee09. 09/21/18 02:29 PM
Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
100 registered members (A310, ABomb369, 928, 53' Stude, Ablebody, 10 invisible), 1,672 guests, and 38 spiders.
Topics290,785
Posts4,850,249
Members66,036
Most Online3,590
Jan 24th, 2017
Red Line 10W30 Motorcycle oil particle count #4109205
05/28/16 08:08 PM
05/28/16 08:08 PM
Arizona
bulwnkl Offline OP
bulwnkl  Offline OP
Arizona
This is their MA-rated shared-sump fluid. I did a particle count only, on the new-in-the-bottle fluid. I have a UOA in the motorcycle section, too. Particle count there is noticeably cleaner:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4107645/Honda_NC700X_Red_Line_10W30
4 mic 29178
6 mic 9931
14 mic 497
21 mic 131
38 mic 16
70 mic 6
ISO 22/20/16
Re: Red Line 10W30 Motorcycle oil particle count [Re: bulwnkl] #4109214
05/28/16 08:15 PM
05/28/16 08:15 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Thanks for posting.
That and your UOA provides another really good data point on fiters and their effect.
I'm always going to change the filter a couple of weeks after changing the oil now.
Re: Red Line 10W30 Motorcycle oil particle count [Re: Shannow] #4109280
05/28/16 09:23 PM
05/28/16 09:23 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Originally Posted By: Shannow
Thanks for posting.
Well, yeh....BUT.....the obvious, if naive, questions seem to be...
(a) SHOULD it have so many bits in it out of the bottle?
(b) Is it NORMAL? (similar question, but not the same).
(c) WHAT are they?
My understanding was that 4 microns is too small to be removed by a new standard oil filter, but I suppose a used one might be able to trap them.
Re: Red Line 10W30 Motorcycle oil particle count [Re: bulwnkl] #4109283
05/28/16 09:28 PM
05/28/16 09:28 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Agglomerations?
Re: Red Line 10W30 Motorcycle oil particle count [Re: BrocLuno] #4109290
05/28/16 09:31 PM
05/28/16 09:31 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Originally Posted By: BrocLuno
Agglomerations?
If that's the case, they might go back into solution in use, in which case filter performance is irrelevant.
Re: Red Line 10W30 Motorcycle oil particle count [Re: Shannow] #4109315
05/28/16 10:09 PM
05/28/16 10:09 PM
Arizona
bulwnkl Offline OP
bulwnkl  Offline OP
Arizona
Thanks for posting.
You're welcome. smile
As to the filter change-- Eh... One could do that, and the old filter may filter better than a new one, but then one would 're-contaminate' the sump (in terms of particle count) with the new make-up oil when the filter is changed. It may or may not be worthwhile. For me, it's needlessly fiddly. Perhaps you should share some particle counts from your new strategy. smile
Re: Red Line 10W30 Motorcycle oil particle count [Re: Ducked] #4109319
05/28/16 10:15 PM
05/28/16 10:15 PM
Arizona
bulwnkl Offline OP
bulwnkl  Offline OP
Arizona
(c) WHAT are they?
It is normal. Some blenders or marketers deliver cleaner oil, some dirtier, but it's surprising to most how not-clean 'new' oil is.
Re: Red Line 10W30 Motorcycle oil particle count [Re: bulwnkl] #4109338
05/28/16 10:50 PM
05/28/16 10:50 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Yeah, we learned a long time ago that the hydraulics on the turbine bypass needed filtering down to 5um on the way out of the drum, or we could never keep the system in spec.
Here's some of Stinky Peterson's VOAs with particle count.
Some blenders do a MUCH better job, and some only on their professional range.
Re: Red Line 10W30 Motorcycle oil particle count [Re: bulwnkl] #4109350
05/28/16 11:02 PM
05/28/16 11:02 PM
Arizona
bulwnkl Offline OP
bulwnkl  Offline OP
Arizona
Quite. I believe it is fair to say that we can expect 'run-of-the-mill' consumer motor oils to be fairly dirty.
Re: Red Line 10W30 Motorcycle oil particle count [Re: bulwnkl] #4109400
05/29/16 12:10 AM
05/29/16 12:10 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
So this is "dirt" (which I take to be mostly silica unless from an unusual source) rather than something derived from the oil, as in "agglomerates" above?
I vaguely remember a Morgan driver (I think) long ago saying something like "You don't put THAT stuff in your engine, do you? referring to Castrol GTX straight from the can.
Something about filtering it through chamois leather before use, which I'd have thought would be impossibly slow.
Re: Red Line 10W30 Motorcycle oil particle count [Re: bulwnkl] #4109404
05/29/16 12:20 AM
05/29/16 12:20 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Thus my change the filter some weeks after the OCI...the filter is at it's best filtering at that point, and get the junk from the bottle out ASAP.
the residual has some partially reacted additives in it, so should be better than virgin oil at that point (wear wise, not contaminant)
Re: Red Line 10W30 Motorcycle oil particle count [Re: Shannow] #4109421
05/29/16 01:24 AM
05/29/16 01:24 AM
Indiana
BobFout Offline
BobFout  Offline
Indiana
Isn't this an exercise in diminishing returns? You could change your oil and filter every 3 months / 5,000 km and not have any meaningful additional wear compared to what you describe? Or is this the difference between an engine that requires a rebuild at 500K km vs. 300K km?
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
Re: Red Line 10W30 Motorcycle oil particle count [Re: BobFout] #4109425
05/29/16 02:11 AM
05/29/16 02:11 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Almost certainly...
But it's no skin off my nose if I change the filter a month after the oil...I'll be checking something or pumping tyres at that point anyway.
explained more a few weeks ago
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4096319/New_oil_change_regime_-_half_c
Re: Red Line 10W30 Motorcycle oil particle count [Re: bulwnkl] #4109430
05/29/16 03:08 AM
05/29/16 03:08 AM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
Yes I decided to do a similar thing (though I go 2 oil changes with 1 filter).
I was reading the toilet paper filter thread yesterday. Very interesting and fairly cheap, but there's no rom at all under my hood and I don't want long oil lines external of the engine.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: Red Line 10W30 Motorcycle oil particle count [Re: Ducked] #4109657
05/29/16 10:19 AM
05/29/16 10:19 AM
Arizona
bulwnkl Offline OP
bulwnkl  Offline OP
Arizona
Why would you assume that? Do you see high silicon in short-duration UOAs, but lower in longer-duration ones? I don't.
Some may be 'dirt,' but I suppose a lot of it is 'stuff' in the plumbing, both at the blender and up- and down-stream.
Particle counts are super-inexpensive, so it wouldn't be tough (expensive) to track particle counts across the early portion of an OCI, if a person wanted to _know_, rather than blindly speculating based on non-automotive, non-engine, non-consumer-cost-effective notions. Then again, one would still be speculating as to how much, or even whether, those particle counts were causing any wear or issues that ever would or even could show up in the life of their vehicle.
I did what I did because of the transmission portion of this sump, even though I suspected the filter would 'mask' much of the utility. I then did the count on the clean fluid because, again, it's super cheap, and I don't mind sharing here.
