Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
toro super recycler with b&s engine HomeDepot
by passgas55 - 01/18/20 06:43 PM
75w140?
by mpack88 - 01/18/20 06:00 PM
Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Katdaddy, graphine, Bebo77, 2EHA, jonnyb433
70467 Registered Users
16 registered members (dogememe, earlyre, hpb, harry j, m37charlie, Langanobob, 1 invisible), 524 guests, and 19 spiders.
Topics300,304
Posts5,172,822
Members70,467
Most Online3,728
Jan 11th, 2020
Microgard 51334 cut open #4109203 05/28/16 07:07 PM
dlundblad Offline OP
Happy Memorial Day weekend BITOG. USA
This was ran on a Kubota G1800 diesel for roughly 40 hours with Mobil 1 Turbo Diesel Truck. Note the spring bypass vs. the ADBV/ bypass combo that is normally found on other low tiered WIX filters.
No tears, straight pleats and a soft ADBV.. No complaints whatsoever, but this filter wasn't pushed either.
I am running the same combo on this tractor again. Sadly, the TDT stash is getting dangerously low!
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Microgard 51334 cut open [Re: dlundblad] #4109231 05/28/16 07:33 PM
J
Jimzz Offline
J
Thanks for posting and I have always been happy with my low priced Wix filters.
yup
Re: Microgard 51334 cut open [Re: dlundblad] #4109311 05/28/16 09:00 PM
M
mcgophers Offline
M
Nice! My Elantra takes those same filters and they can be hit or miss in my experience, but I'm glad that they are working well for you.
2015 Sentra: Valvoline Conventional 5W-30 & Valvoline filter
2015 Altima: Dealer maintained
Re: Microgard 51334 cut open [Re: mcgophers] #4109468 05/29/16 05:37 AM
Hit or miss in what sense?
Hyundai had a TSB for using aftermarket filters on their early 2000 models.
I can't help but wonder if that is the reason WIX used the spring bypass design on this model.
Re: Microgard 51334 cut open [Re: dlundblad] #4109632 05/29/16 08:50 AM
Sayjac Offline
Looks good. And as noted this one uses dome bypass. In the new Super Tech line there is no equivalent size, they skip it and go to what's called the ST9688 which is the same size as the 7317/14610 application. It too though uses a separate dome bypass. However, WM in this area having difficulty keeping the ST9688 in stock.
Thanks for pics.
Re: Microgard 51334 cut open [Re: dlundblad] #4110700 05/30/16 04:32 PM
M
mcgophers Offline
M
I have noticed a few times when using SuperTech or Microgard filters that the engine would run at higher RPMs than if I was using an OEM or Wix-branded filter. It is not currently happening with the ProSelect filter I have on and the effect seems to be almost immediate.
Re: Microgard 51334 cut open [Re: dlundblad] #4110745 05/30/16 05:33 PM
T
Tony10s Offline
T
Looks very nice ... thanks for posting this. smile
Re: Microgard 51334 cut open [Re: mcgophers] #4111075 05/31/16 03:21 AM
That is an odd issue indeed.
Re: Microgard 51334 cut open [Re: dlundblad] #4111516 05/31/16 02:43 PM
Z
ZeeOSix Offline
Z
Doubt that it's oil filter related - how could it?
Re: Microgard 51334 cut open [Re: ZeeOSix] #4112789 06/01/16 07:32 PM
M
mcgophers Offline
M
Maybe it was air filter related? I changed the air filter before the end of my last OCI and while I didn't see an immediate improvement in RPMs, it did lower on the current interval. For what it's worth, the SuperTech 9688 that is rated for this vehicle appears to be noticeably smaller than a Fram 9688 or the equivalent Wix-numbered filters.
