JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
Effects of increasing engine RPM?
by Avery4 - 01/27/20 11:09 AM
New C8-R Vettes at Rolex 24
by racin4ds - 01/27/20 10:39 AM
Thoughts on redline?
by BTLew81 - 01/27/20 10:15 AM
Yak trax
by John_Conrad - 01/27/20 10:00 AM
Castrol GTX 20w50
by VQLT - 01/27/20 09:33 AM
Mevotech Terrain Tought ttx?
by buck91 - 01/27/20 08:54 AM
House electric questions
by supton - 01/27/20 08:37 AM
How an automatic transmission works
by supton - 01/27/20 08:08 AM
AC Delco UPF48R and UPF64R $1.50 rebate at Rock Auto
by Snagglefoot - 01/27/20 07:15 AM
Netgear Nighthawk M1 and Router setup
by Tribe21 - 01/27/20 06:24 AM
Alignment questions: is camber/caster not usually touched?
by FordBroncoVWJeta - 01/26/20 10:47 PM
Pricing used tires
by PumpPusher - 01/26/20 10:21 PM
STP Motor Oil at HF
by kstanf150 - 01/26/20 10:07 PM
9 years for the 4 cylinder Eco-boost
by Snagglefoot - 01/26/20 09:39 PM
So I picked this up..
by Mad_Hatter - 01/26/20 08:49 PM
New here and question about oil.
by Sunstealth - 01/26/20 08:42 PM
Looking for a car for $4k or less
by SVTCobra - 01/26/20 08:09 PM
Burner718, masstrnsprtcmplx, tampasaint, rdmjone, BigGeo
70537 Registered Users
106 registered members (Alfred_B, 2015_PSD, 87sammy, 1978elcamino, 2strokeNorthstar, 6 invisible), 2,791 guests, and 15 spiders.
Topics300,628
Posts5,179,732
Members70,537
'14 Accord - Honda 0W20 - High vis or lab error? #4108724 05/28/16 07:18 AM
V
vvolcano Offline OP
V
Are the viscosity readings most likely an error by the lab? For this OCI and the one prior (10/24/2015) I ran Honda OW20 syn. This is a direct injection engine so that might explain some of the fuel. The wear metals look OK to me. I did find the drop in moly a little curious.. is it normal for additive levels to vary like this even using the exact same oil?
The oil is sitting in a catch pan with brake fluid and other oil, so no chance of a re-test.
Re: '14 Accord - Honda 0W20 - High vis or lab error? [Re: vvolcano] #4108740 05/28/16 07:47 AM
K
Kuato Offline
K
Interesting. At .06cST over, it's just barely out of spec, but I agree it should have been diluted by the high fuel. Is there a VOA of the Honda oil?
Thick vs Thin test: 15k / 43k miles complete
Re: '14 Accord - Honda 0W20 - High vis or lab error? [Re: vvolcano] #4108772 05/28/16 08:18 AM
Danh Offline
If you're sure an 0w-20 was used, I'd bet on lab error. Blackstone relies on human beings watching oil flow through a viscosometer for this measure, which makes error quite possible (same with flashpoint and fuel %, fwiw). If your driving patterns are anything close to those for previous UOAs you would expect considerable shearing.
If you didn't perform the last oil change yourself I suppose the dealer could've used a 5w-30 by mistake. On the bright side, given fuel dilution and how these engines can shear oils, an xxw-30 oil may be a better choice anyway.
Re: '14 Accord - Honda 0W20 - High vis or lab error? [Re: vvolcano] #4108782 05/28/16 08:32 AM
SatinSilver Offline
Are you still getting free oil changes from the dealer?
Originally Posted By: vvolcano
The dealership we bought it from included 6 free oil changes.
Re: '14 Accord - Honda 0W20 - High vis or lab error? [Re: Kuato] #4108787 05/28/16 08:36 AM
Z
zeng Offline
Z
[email protected]*C of xxW30 is 9.3-12.5 cSt.
Appears to me a Blackstone error.. anyway wear rates looks fine. blush
Re: '14 Accord - Honda 0W20 - High vis or lab error? [Re: vvolcano] #4108822 05/28/16 09:23 AM
N
Nate1979 Offline
N
Who changed the oil last time?
2015 GMC Sierra 2500 6.0L
2010 Subaru Forester 2.5X
Re: '14 Accord - Honda 0W20 - High vis or lab error? [Re: Danh] #4108833 05/28/16 09:35 AM
V
vvolcano Offline OP
V
Ah thanks for that information-- makes human error seem like the culprit in this case.
I changed the oil myself this time as well as the previous time. Nothing remarkable about this interval.. around 40 miles roundtrip of daily commuting with a couple of regional trips sprinkled in.
Re: '14 Accord - Honda 0W20 - High vis or lab error? [Re: vvolcano] #4108837 05/28/16 09:42 AM
SatinSilver Offline
Re: '14 Accord - Honda 0W20 - High vis or lab error? [Re: vvolcano] #4109418 05/29/16 12:21 AM
L
LotI Offline
L
Honda is known to use a break in oil that's high in moly so that's just washing out.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
