Shutting Down Threads Because of "Speculation"
by e55amgbenz007 - 02/18/20 10:10 AM
Toyota Sienna
by cb_13 - 02/18/20 10:05 AM
Larger fuel filter on Riding mower?
by dedonderosa - 02/18/20 10:03 AM
Castrol edge 0w40
by VQLT - 02/18/20 08:32 AM
Scrap value of this catalytic converter
by atikovi - 02/18/20 06:10 AM
How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
tpap, ratt, jeffreytmann, boureesub, Bayrim
70737 Registered Users
104 registered members (Astro14, Avery4, aquariuscsm, b1amgm47, ABerns, 9 invisible), 2,231 guests, and 22 spiders.
Topics301,604
Posts5,198,983
Members70,737
Cheap brake fluid tester working properly? #4108630 05/28/16 03:00 AM
L
LucasDK Offline OP
L
Hi,
I bought this tester on Ebay from China:
http://www.amazon.com/Brake-Fluid-Tester...ke+fluid+tester
As you can see from the reviews, people are extremely satisfied with the tester.
I made a test in a bucket of water and it rapidly showed +4% water as it should. But then I tested some old brake fluid which has been on the shelf for 4 years. 4 years ago the container was opened and the plastic screw lid (with no seal) was put on again. It has been resting like this in a shed experiencing summers and cold winters and relative moistures going above 95%.
But my tester shows less than 1% water in the fluid. Which means the fluid should be OK. But can I trust the tester?
PS: I also tried the tester with the brake fluid in my cars brake fluid reservoir and again it showed less than 1%. But I do not know when it was changed the last time because I bought the car 6 months ago (used car).
Lucas
Toyota Hiace 2,4D (2L engine)
Toyota Corolla AE92, (4A-FE engine)
Ford Model A (3,4 liter engine)
Re: Cheap brake fluid tester working properly? [Re: LucasDK] #4108656 05/28/16 04:31 AM
Ducked Offline
In principle, should be easy enough to test.
Buy some fresh brake fluid (which might be date-coded?).
Test a sample, then spike it with steadily increasing known percentages of water to produce a calibration curve.
That's likely to be more specifically informative than anything anyone on here can tell you about your brake fluid tester.
Re: Cheap brake fluid tester working properly? [Re: LucasDK] #4108657 05/28/16 04:31 AM
J
Jetronic Offline
J
why not add 1% water to a sample of the brake fluid, and test again?
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: Cheap brake fluid tester working properly? [Re: LucasDK] #4108669 05/28/16 04:47 AM
L
larryinnewyork Offline
L
I have one of those testers.
How reliable is the accuracy ? I don't know.
I tried it a couple times and now it sits in the basement.
I change my brake fluid every 2 years. So no matter what the Tester would show, I should be good.
I thought it was an interesting purchase and may just use mine for reference or to show a family member how bad their (neglected) fluid is.
Read the instructions. It says:
Dip the test probes into the brake fluid up to the plastic rim of the device.
Check for Repeatability by how far you insert the probe.
This is where I was getting inconsistent readings.
Re: Cheap brake fluid tester working properly? [Re: LucasDK] #4108799 05/28/16 08:58 AM
B
bowlofturtle Offline
B
ive only used strips. It was supplied to me by BG products, i think they were rigged a little since it can help BG sell their brake flush. But what do i know.
Honestly now... i dont care too much. I've seen fluid look like used oil in cars from early 90s, the brakes all work and i wouldn't suggest them do a brake flush. My personal cars, i bleed a little every brake job and i'm not thinking twice.
Maybe your test of 100% water was too much water for the tester, LOL
My toys
-05 Infiniti G35x 140k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 20k
-98 Nissan Maxima 160k
-09 Toyota Camry V6 96k
Re: Cheap brake fluid tester working properly? [Re: LucasDK] #4108964 05/28/16 01:04 PM
N
Nate1979 Offline
N
The dirtiest fluid is always at the calipers. How are these testers measuring anything useful?
2015 GMC Sierra 2500 6.0L
2010 Subaru Forester 2.5X
