Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
99 registered members (alphadog, 69GTX, A310, 2003f7, 4WD, 8 invisible), 2,445 guests, and 36 spiders.
Topics300,411
Posts5,175,228
Members70,497
Kia P0138 Code From Old Amsoil Stabilizer ?? #4108432 05/27/16 06:43 PM
Q
Quadrasteer Offline OP
Q
Used about 1 or 2 ozs. of older (maybe from 2001) Amsoil Fuel Stabilizer in my sons '13 Kia Optima that had a little more than 1/2 a tank of gas and the next day it got a code P0138, do you think it could have caused it? One thing that I noticed was that it does NOT say O2 sensor safe on the bottle. The car only has 32k on it...
P0138 Kia Description
The Heated Oxygen Sensor 2 (HO2S) (Rear O2 Sensor), after three way catalyst (manifold), monitors the oxygen level in the exhaust gas on each bank. For optimum catalyst operation, the air fuel mixture (air-fuel ratio) must be maintained near the ideal stoichiometric ratio. The HO2S output voltage changes suddenly in the vicinity of the stoichiometric ratio. The Engine Control Module (ECM) adjusts the fuel injection time so that the air-fuel ratio is nearly stoichiometric. The HO2S generates a voltage between 0.1 and 0.9 V in response to oxygen in the exhaust gas. If the oxygen in the exhaust gas increases, the air-fuel ratio becomes Lean. The ECM interprets Lean when the HO2S voltage is below 0.45 V. If the oxygen in the exhaust gas decreases, the air-fuel ratio becomes Rich. The ECM interprets Rich when the HO2S voltage is above 0.45 V.
Re: Kia P0138 Code From Old Amsoil Stabilizer ?? [Re: Quadrasteer] #4108436 05/27/16 06:52 PM
R
RedOakRanch Offline
R
15 year old fuel stabilizer? Kind of ironic... LOL
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: Kia P0138 Code From Old Amsoil Stabilizer ?? [Re: Quadrasteer] #4108444 05/27/16 06:57 PM
N
NHGUY Offline
N
Stabilizing fuel that is going to get rapidly used up? Snake oil salesmen can sell anything...
Re: Kia P0138 Code From Old Amsoil Stabilizer ?? [Re: Quadrasteer] #4108486 05/27/16 08:00 PM
E
Eddie Offline
E
To answer your question. NO 1 or 2 oz in ~ 6 gallon would not cause any problems at that ratio.
2014 CX5 Touring 2.5L :-)
Re: Kia P0138 Code From Old Amsoil Stabilizer ?? [Re: Eddie] #4108875 05/28/16 10:36 AM
Q
Q
Probably less stabilizer and more gas than that but that's what I thought too. I'm too cheap to throw the stuff out, I put some in my GMC truck, lawn mower, Audi A4 and my gas cans. Never had any problems before. I bought a case at a Snowmobile show years ago, used it back then too with no problems. Anything's possible though...
Re: Kia P0138 Code From Old Amsoil Stabilizer ?? [Re: Eddie] #4109090 05/28/16 04:15 PM
MolaKule Offline
Global Moderator
Global Moderator
thumbsup
If the fuel stabilizer was stored capped, I cannot see the fuel stabilizer causing this situation.
I think you have a true coincidence here.
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Kia P0138 Code From Old Amsoil Stabilizer ?? [Re: MolaKule] #4109970 05/29/16 06:04 PM
Q
Q
thumbsup
Probably but not to my son with such low mileage on the car...I know that some chemicals degrade after time into other compounds, I've called before about other additives and they tell you to throw them out and not to use them. Whatever, from now on the old stuff goes into the mower...
