Oil weight and Oil Grade
by Snagglefoot - 01/21/20 07:11 PM
Which air filter for RAV 4 Hybrid
by NH73 - 01/21/20 06:44 PM
Finding a good "cold weather" vehicle?
by Vern_in_IL - 01/21/20 06:15 PM
Bough NGK Ruthenium sparkplugs
by cronk - 01/21/20 06:07 PM
HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
131 registered members (4WD, 750IX, A310, 67ZL1, 1foxracing, 11 invisible), 2,402 guests, and 25 spiders.
Topics300,410
Posts5,175,151
Members70,497
2010 Hyundai Elantra H/B...oil requirments #4108379 05/27/16 05:27 PM
O
Oregoonian Offline OP
O
Grandaughter.... just purchased the above vehicle....an automatic with 47K on the OD. Paid $9400. Will be driving it down to SoCal (850 miles one way) for college, from Central Oregon, and come home during holidays and summer.
Seeking BITOG'er who have or know about this vehicle.... and opinions both positive and negative.
Also need the recommended oil, filter and ATF needed. (as there is no manual).
Any info you can supply, would be extremely helpful. Thanks.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4108399 05/27/16 05:55 PM
K
Kamele0N Offline
K
40 grade oil...xyW40...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4108491 05/27/16 08:07 PM
K
KCJeep Offline
K
Hyundai's typically spec for 5w20 but manuals quickly allow for 5w30 and 10w30 depending on use. I'd use a good 5w30 in it myself, Magnatec would be a really good choice but there are MANY.
You should easily be able to pick up a manual on ebay.
2018 VW Passat GT VR6 - 22k - Castrol Pro OE 5w40 - VW OEM filter
2012 KIA Sedona 104k - Valvoline Maxlife 5w30
2012 VW Tiguan 105k - Castrol 0w40
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4108512 05/27/16 08:38 PM
V
Vladiator Offline
V
Engine - go with Mobil 1 0w40 or 0w30, will not regret for sure, use year round. Best if matched to an OEM filter, as Huyndais seem to be pretty picky about oil filters.
Transmission - Castrol Full synthetic import, or Valvoline Maxlife ATF, I believe both meet the SP-III fluid requirement.
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4108565 05/27/16 10:20 PM
B
Branson304 Offline
B
I think a 5W-30 would be a good choice for the engine. Amsoil's website has a feature that will show you all the recommended fluids, specs & even some torque specifications for your vehicle. You should check it out since you don't have an owners manual.
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4108635 05/28/16 03:20 AM
crazyoildude Offline
5w30 will be fine its a Hyundai it will keep running.
Check To See That The Oil Jugs You Buy Have The Exact Amount Of Oil In Them And Have An Inner Seal Under The Cap. I Use Mobil 1 And Fram Ultra Filters
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4108903 05/28/16 11:24 AM
T
tnt31 Offline
T
I prefer the Hyundai OEM Oil Filters. I get them from my local dealer for six dollars and some change after tax. May could get cheaper in bulk but I have not asked. Can order via Ebay for close to $4 each in packs of six or more. I would use a quality 5w-30 oil. If looking for value (I know that is subjective) Napa Syn is on sale for $2.99 a quart thru May I believe and QSUD is priced well at Wal-Mart. Your manual would indicate 5w-20 preferred for fuel economy and 5w/30 (for all temps) and 10w-30 (For above 0 degrees)acceptable or something to that effect.
ATF - I believe the spec for yours is SP III. For that spec I have used ENEOS SP (can usually find at Napa) and Valvoline Import Multi-Vehicle. Both seemed to work well in a SP III spec'd 2010 Hyundai Accent.
Antifreeze - I have used Zerex Asian Forumula in a 2010 Hyundai Accent and 2012 Kia Rio with no problems.
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4108907 05/28/16 11:39 AM
53' Stude Offline
QSGB, PP or QSUD 5w30 as we have 5 at work and they are fine on conventional 5w30 and even M1 as my boss' car demonstrated with the M1 filter I cut
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4108997 05/28/16 01:56 PM
O
O
Thanks everyone for your oil and ATF suggestions. I figured a 5w20 or 30 would be suitable for this Elantra.
Using a 5w30 Syn....what would be a reasonable OCI?
Also...what Fram ULTRA or Tough Guard filter (#) does this vehicle take?
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4109071 05/28/16 03:55 PM
K
KCJeep Offline
K
Most of the Hyundai/KIA's take the Fram 9688 size if it is a spin on canister set up. Despite all of the fear of anything non OEM for these cars they work extremely well in my experience and are available just about everywhere.
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4109687 05/29/16 09:56 AM
K
Kamele0N Offline
K
OCI on 15.000kms....10.000 with more sulphur fuel (USA fuel :))
Re: 2010 Hyundai Elantra H/B...oil requirments [Re: Oregoonian] #4109957 05/29/16 05:46 PM
G
Gene K Offline
G
Original manual calls for 60k timing belt replacement.
Online Hyundai calls for 90k belt replacement.
I'm not sure which is correct.
If you have the original 6-7 year old belt I would consider replacement before she leaves for College. However the Elantra not the timing belt eating machine the Accent is.
Gene
2014 Mustang GT 5.0 SC - 675 bhp
ST Synthetic 10W30 / FL500S
2018 F150 4x4 3.5 EB
OEM Oil & Filter
2018 Lincoln MKX 3.7
OEM Oil & Filter
