Fuchs Titan ATF 6400
by Chuckh - 02/27/20 12:52 PM
2018 Ram 2500 with 21k miles. Delo 400 XSP 5w40
by bigbadbowtie - 02/27/20 11:08 AM
For those always asking about tiny Computers
by jayjr1105 - 02/27/20 11:05 AM
Original 2016 VW Passat cabin filter
by Vaca - 02/27/20 11:02 AM
Original 2016 VW Passat air filter
by Vaca - 02/27/20 10:54 AM
Napa Exceptional Customer Service
by Fitz98 - 02/27/20 10:38 AM
Astra 400 ?
by WyrTwister - 02/27/20 09:58 AM
Will thinner oil damage anything when it is burned?
by Fordiesel69 - 02/27/20 09:38 AM
Old news for Hyundai/Kia?
by Farnsworth - 02/27/20 09:33 AM
Looking for AA 25% off coupon code.
by JustChuck - 02/27/20 09:17 AM
New to the LS460 and The World Of Lexus. Questions!
by gr8gatzby - 02/27/20 08:41 AM
New old guy back.
by BJD2020 - 02/27/20 07:45 AM
Help me Decide
by Gebo - 02/27/20 07:36 AM
FWD - Death traps with miss matched tires.
by Fordiesel69 - 02/27/20 07:13 AM
Napa Gold Sale
by Toto - 02/27/20 06:52 AM
2016 or 17 Honda CR-V
by Loogie - 02/27/20 05:20 AM
RIP Clive Cussler
by PimTac - 02/27/20 04:48 AM
Pirelli Cinturato P7 Allseason PLUS "II"
by Char Baby - 02/27/20 03:31 AM
CCI clean .22 ammo - polymer coated HV
by Shannow - 02/27/20 03:23 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
113 registered members (2015_PSD, 1978elcamino, AndyB, ArrestMeRedZ, ARCOgraphite, Amenhotep, 8 invisible), 2,138 guests, and 18 spiders.
Topics301,989
Posts5,206,944
Members70,808
What Ohm antenna wire to use? #4107664 05/26/16 09:46 PM
daves66nova Offline OP
And I always thought it was just a wire connected to the back! I want to use the correct antenna wire but I read about impedance,Ohms,75 or 300 Ohm wire, baluns,etc. Here's Wikipedia with article and formulas too for this;https://en.wikipedia.org/wiki/Twin-lead .I currently share ota t.v. antenna with stereo. I believe I have a balun with the 2 spade prongs connected to antenna and other end is connected to RG6 down to stereo with another balun of same kind. Is there a way better setup? I want the best reception possible,short of buying amps and such.
THIS SPACE FOR RENT, PLEASE PM ME.
Re: What Ohm antenna wire to use? [Re: daves66nova] #4107675 05/26/16 10:11 PM
dishdude Online Content
Online Content
RG-6 is what you want to be using. You'll need a balun up at your antenna and it sounds like inside the house you have a splitter with one line going to the TV and the other going to the stereo? The stereo probably needs another balun if it doesn't have an F connector.
Typically anything with an F connector is 75 ohms and anything with two screw terminals is 300 ohms, don't get too mixed up in that as long as you're using a matching transformer/balun it'll be fine.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: What Ohm antenna wire to use? [Re: dishdude] #4107685 05/26/16 10:47 PM
Matching as in it connects together? At my stereo, I have the coax connected to the cylindrical balun and on the stereo side of it, it has the 2 spade connectors coming out. My stereo has the connections that you push a tab down and insert a wire into it.
Re: What Ohm antenna wire to use? [Re: daves66nova] #4107687 05/26/16 10:55 PM
Online Content
One of these will get the job done. Guessing you have one on the antenna and one at the stereo.
Re: What Ohm antenna wire to use? [Re: daves66nova] #4107700 05/26/16 11:21 PM
yes.
Re: What Ohm antenna wire to use? [Re: daves66nova] #4107826 05/27/16 06:46 AM
R
RF Overlord Offline
R
Bear in mind that coaxial cable (75-ohm) has greater loss than twin-lead (300-ohm). There will also be loss in each balun. If you don't need the shielding of coax for local interference, then twin-lead is better in low-signal applications.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'04 Grand Marquis LS Limited Edition - MC 5W-20 / FL820S
'00 Grand Marquis GS - being resurrected. Slowly.
