Chrome Polish
by rrretiree7 - 01/22/20 11:57 PM
2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Mikemac2008, Jeff1024, EricWestland, Brian200001, Phildrum
70507 Registered Users
37 registered members (AZjeff, bradepb, Bailes1992, Black_Thunder, adams355, bbhero, 3 invisible), 1,649 guests, and 22 spiders.
Topics300,451
Posts5,176,094
Members70,507
Motor mount troubles... #4107566 05/26/16 07:58 PM
B
buck91 Offline OP
B
So I'm working on our 2001 Olds Aurora with the 3.5L V6, specifically I am TRYING to replace the front engine mount. Unfortunately, the FSM is of zero help- very much lacking in detail plus, the engine mount it SHOWS isn't even the way this one is built!
Anyways, right now I have the starter dropped and the block jacked up as far as I can get it. The motor mount is unbolted from engine and crossmember but it is still attached to its bracket since I was unable to get a large enough breaker bar in there to bust the 18mm top nut loose. Well, did it with my wrench, but now that shaft is just spinning inside the mount. I'm about one inch short of clearance to be able to get the mount out.
Anybody familiar with this vehicle or FWD in general? Any tips? Thinking about loosening the side motor mounts to see if I can get enough play- but I don't want to take the chance of pulling or crushing something. Ideas?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Motor mount troubles... [Re: buck91] #4107571 05/26/16 08:05 PM
The Critic Offline
I would loosen the side motor mounts and remove the axles. Don't raise the engine/trans too much if the axles are still attached b/c you may separate the inner joints.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Motor mount troubles... [Re: buck91] #4107587 05/26/16 08:21 PM
T
Trav Offline
T
You have to remove the mount bracket first, remove the mount nut on the frame and remove the mount.
You wont get this out with the bracket attached. Is there a problem removing the bracket?
Re: Motor mount troubles... [Re: buck91] #4107627 05/26/16 08:59 PM
M
Merkava_4 Offline
M
The front mount bracket probably goes to the transmission like on my Buick. You gotta support the engine with a block of wood under the transmission pan and then remove the bracket. After that, unbolt the front mount from the subframe.
Re: Motor mount troubles... [Re: buck91] #4107688 05/26/16 10:56 PM
B
buck91 Offline OP
B
Well, FSM shows the bracket as a 4-bolt piece connecting the engine and trans to the mount... Not the case, its a 3- bolt unit and the FSM wasn't helpful. Couldn't get the top nut off the actual mount to remove the bracket in-car because of a lack fo room to fit a 18mm wrench and definitely a lack of room to fit a breaker. On top of that, somehow the mount stud (its a double male stud and the mount fastens to frame with nut on each end) is broken free of the rubber and just spins.
Ended up figuring it out, jimmied it around enough to run a couple extensions vertically (well, more like oblique) and hit it with the impact. This allowed me to separate the mount and bracket in the vehicle to remove each individually.
Definitely a surprising learning curve on a presumably simple job! Doesn't help that I busted my knuckles pretty good early on. Next one will go easier.
2011 F150 4x4 5.0L
Re: Motor mount troubles... [Re: buck91] #4107746 05/27/16 04:06 AM
M
Merkava_4 Offline
M
Mine is a 3-bolt mount too. With mine, the bolts are actually studs with a permanent built in hex nut. I have to first remove the bracket that supports the secondary air injection pump before getting to the bracket for the front mount. By the way, my FSM calls the front center mount a transmission mount. The other 3 mounts are motor mounts.
